How to I export my .scad file into .stl format?
Does it work the same for a 3D printer?
If anyone has tips on using (step by step) OpenSCAD with a 3D printer it
would be very helpful. Thank you very much.
View this message in context: http://forum.openscad.org/3D-printing-Export-into-STL-Format-tp12004.html
I just use the Export STL in the menu and then send the resulting file
to my printer software. I'm running an Afinia H479 and the software
handles all the slicing functions. Someone using a different printer may
have a different approach.
Curt
Curt Givens GCAC Earthdog Director/GCDOC Barn Hunt Director
"do not meddle in the affairs of dragons for you are crunchy and taste good with ketchup"
Motorcyclist know why dogs hang their heads out of car windows
The .stl format is just one of several possible intermediate
representations, although a very common one. If you limit the 3D
printer" to be the printer hardware, onboard electronics + firmware
only, then your typical 3D printer does not actually understand .stl at all.
The printer firmware expects "G-code" http://en.wikipedia.org/wiki/G-code
After saving your .scad to .stl format (OpeScad: File -> Export -> STL),
you must run it through a slicer program (slic3r, KISSlicer, ...) to
create G-code. Ignoring some differences in startup and shutdown G-code
sequences for different printer hardware, it is the G-code that works
the same for different printers.
I am waiting for my first printer to arrive soon. My idea is to use
OpenSCAD to create models, save to .stl and then create G-code from STL
using KISSlicer, all done on a PC.
I plan to hook my printer up with a Raspberry PI with wireless Wifi to
run OctoPrint. Then it is just a matter of dragging/dropping the
generated G-code file into the Web user interface of OctoPrint to
actually do the 3D-printing, completely independent of the PC, which is
free to do other things as the printing proceeds.
I find such a setup more flexible, clear and attractive than an
"all-in-one" solution where the borders between the PC, software(s) and
printer are made fuzzy and hidden for no good reason (IMHO).
I use Repetier-Host to process my STL files and send them to the
printer. Free, and highly recommended.
at all.
STL), you must run it through a slicer program (slic3r, KISSlicer,
...) to create G-code. Ignoring some differences in startup and
shutdown G-code sequences for different printer hardware, it is the
G-code that works the same for different printers.
STL using KISSlicer, all done on a PC.
is free to do other things as the printing proceeds.
and printer are made fuzzy and hidden for no good reason (IMHO).
Checked by AVG - www.avg.com
Version: 2015.0.5751 / Virus Database: 4306/9297 - Release Date: 03/14/15
