John David
Mon, Feb 10, 2025 10:56 PM
I want to write some generic text (similar to echo statements) to a user
defined output file. My interest in this is to use it in conjunction with
the timing tests to output the results from dozens of tests. In the past,
I have used stuff like this to output the configuration of a simulation, so
I know what all the parameters were.
I see in the GitHub issues "Allow OpenSCAD to open and write out text files
#3400" https://github.com/openscad/openscad/issues/3400 that some folks
were looking to use the same functionality to be able to output their CAM
G-Code.
Was this functionality ever implemented? If so, where/how?
If not, are there any objections to me implementing something like this and
requesting a PR?
EBo --
#3400" <https://github.com/openscad/openscad/issues/3400> that some folks
G-Code.
requesting a PR?
EBo --
Mon, Feb 10, 2025 11:05 PM
and requesting a PR?
For OpenSCAD scripts, the situation has not changed. Those can't
have a write() function.
I still hope we can get the Python support integrated eventually,
that would allow such things without extra work. With no help
moving that topic forward, there's no timeline though.
Tue, Feb 11, 2025 1:44 AM
To amplify on that a bit... this is a deliberate design decision. It
should be safe for you to download an OpenSCAD program and run it,
without fear that it will scribble on your files.
Tue, Feb 11, 2025 2:09 AM
On Feb 10, 2025, at 2:56 PM, John David via Discuss discuss@lists.openscad.org wrote:
I want to write some generic text (similar to echo statements) to a user defined output file. My interest in this is to use it in conjunction with the timing tests to output the results from dozens of tests. In the past, I have used stuff like this to output the configuration of a simulation, so I know what all the parameters were.
I see in the GitHub issues "Allow OpenSCAD to open and write out text files #3400" https://github.com/openscad/openscad/issues/3400 that some folks were looking to use the same functionality to be able to output their CAM G-Code.
You cannot write to a file with OpenSCAD. At all. This is for safety reasons. Wouldn’t want to have a malicious OpenSCAD script installing malware on your machine. Python in OpenSCAD theoretically could, though.
However, you CAN run OpenSCAD from the command-line and redirect its console text into a file, then post-process it with a script to remove unwanted cruft.
-Revar
> On Feb 10, 2025, at 2:56 PM, John David via Discuss <discuss@lists.openscad.org> wrote:
> I see in the GitHub issues "Allow OpenSCAD to open and write out text files #3400" <https://github.com/openscad/openscad/issues/3400> that some folks were looking to use the same functionality to be able to output their CAM G-Code.
-Revar
Tue, Feb 11, 2025 2:10 AM
Wow. Every other programming language I know of (and I've been writing
code since the late 60s) has been able to write files. Were those
languages considered insecure or dangerous?
How about we allow file writes with a global Setting that defaults to
Cannot Write but the user can change to Allow Writes. That way, everyone
is safe, right until they agree to allow Writes?
I imagine this is not the first time this conversation has occurred, and
I am about to get the Wisdom of the Ages descend upon me...
Tue, Feb 11, 2025 2:24 AM
writing code since the late 60s) has been able to write files. Were
those languages considered insecure or dangerous?
Er... Yes. Do you run random Python/C/Perl/shell programs that you
download from sites like Thingiverse?
Or: when you open and print a Word document or an Excel spreadsheet,
can it scribble on your disk?
everyone is safe, right until they agree to allow Writes?
Plausible. (Maybe even require confirmation on every open-for-write.)
and I am about to get the Wisdom of the Ages descend upon me...
It all depends on how paranoid you are about security issues. I'm not
the authority so my opinion doesn't really matter, but it's not a can of
worms that I would open.
Tue, Feb 11, 2025 2:25 AM
*However, you CAN run OpenSCAD from the command-line and redirect its
unwanted cruft. *
Plus (at least on recent builds), you can right-click in the Console pane,
and save the interactive log to a file and post-process it. Personally, I
have no problem with OpenSCAD's lack of file writing capabilities. But,
that is probably because I DO know a little bit of Python and Regular
Expressions, and grep; so post-processing is relatively painless for me.
On Mon, Feb 10, 2025 at 8:11 PM Revar Desmera via Discuss <
CAM G-Code.
unwanted cruft.
-Revar
unwanted cruft. *
> CAM G-Code.
> unwanted cruft.
> -Revar
JJ
jon jonbondy.com
Tue, Feb 11, 2025 2:34 AM
I download programs off of the internet ALL OF THE TIME. They usually
write to the files that I ask them to write to (Save, Save As). Even
OpenSCAD itself writes to my hard drive. I do not avoid OpenSCAD
because it can write to my hard drive. What is the difference between a
program or an app and a script?
Sure, Word documents should not write to arbitrary places, because I do
not think of them as programs. But OpenSCAD scripts are programs but do
not get executed unless I cause them to be executed. The onus is on me
to check or trust.
I like my proposal that writes be allowed in the language, but
preventable by the user.
Of course I like my proposal! It is mine!
of worms that I would open.
to check or trust.
WF
William F. Adams
Tue, Feb 11, 2025 2:50 AM
If not, are there any objections to me implementing something like this and requesting a PR?
On Monday, February 10, 2025 at 05:56:51 PM EST, John David via Discuss <discuss@lists.openscad.org> wrote:
No, it wasn't implemented, there are sort-of work-arounds.
If you are willing to use PythonSCAD/OpenPythonSCAD:
https://pythonscad.org/
then writing out files works as expected.
I've been working on that at:
which is pretty much working.
Tue, Feb 11, 2025 3:00 AM
The question is whether the 5th percentile OpenSCAD user, who is running
it to get to the Customizer, understands that an OpenSCAD program could
scribble on their disk. (Or even what it would mean for it to scribble
on their disk.) These are precisely the people who should never
download programs except from app stores, because they have no idea how
to vet the trustworthiness of the supplier.
There are any number of stories of social engineering people to click
through warnings.
The only thing that would save us from a CNN minute would be that there
are very few OpenSCAD users, and so it's a small target (so villains
won't bother) and the sample size for gullibility is small (and so even
if the villains bother, they won't get very many one-in-a-thousand victims).
through warnings.
