I'm historically aware of the use of echo() output to do things like producing a Bill of Material.
And the Command-line output option '-o echo' to log echo statements to a file.
There is a suggestion to change the format (significant digits) of numbers output by echo(), and
probably str().
Will this cause significant issues to such use of the log output?
The two echo postprocessing scripts I have do not process numbers; they
process only strings.
One of them makes a simple BOM by collecting up lines, stripping them a
bit, and counting duplicates using sort and uniq -c.
One of them asks the OpenSCAD program what parts it makes, and whether
to generate STLs or PNGs, and for PNGs what camera angle to use, and
then iterates generating the files.
I use them to create discrete part number listings, which in turn I use to
isolate individual parts for selective display and rendering.
But, I'm reasonably sure I only treat them as strings, and generally only
work with whole numbers, so probably not impacted by a format change of
what you're describing.
On Fri, Dec 5, 2025 at 10:06 PM Michael Marx (spintel) via Discuss <
file.
output by echo(), and probably str().
As a bit more background, the discussion is about whether it's a
significant compatibility break to emit more digits from echo(), so that
(for instance) echoing 0.1234567 would emit 0.1234567 rather than
today's 0.123457, or echoing 1234567 would emit 1234567 or maybe
1.234567e+6 rather than today's 1.23457e+6. (Note that today in both
cases the "67" at the end of the number gets rounded up to "7".)
Am 06.12.25 um 07:06 schrieb Michael Marx (spintel) via Discuss:
probably str().
Just to outline my use-case: I'm using OpenSCAD in a project together
with LaTeX and MetaPost to generate 2D drawings and documentation.
OpenSCAD output is actually the least important, but - as we all know -
the visually most convincing one.
All three of them, LaTeX, MetaPost and OpenSCAD, being three different
languages, need to refer to the same data, im my use-case numbers only
for OpenSCAD & MetaPost and strings only for OpenSCAD & LaTeX. Since
OpenSCAD happens to be my testbed for new ideas, source parameter files
are actually .scad files. These files are simple and linear, but may
contain calculations of dependent parameters and are converted (to
MetaPost) code in a three-step process via pipe:
The resulting MetaPost file contains only simple assignments, no
arithmetics or function calls.
(Translation of OpenSCAD strings to LaTeX code is similar, but the
OpenSCAD source file contains a lot more string-fu as most or the LaTeX
macro generation is done on the OpenSCAD side.)
As long as the suggestion is not about reducing significant digits, I
hope not. But thank's for the heads-up! Something I'll watch out for.
Hm, while MetaPost can handle arbitrary precision values, people might
use other post-processing tools that get hick-up on unexpected precision
or range. So maybe make OpenSCAD's echo(var=var) output format subject
to user-preference? Opening the door to getting rid of that
|v<$!#§^Wexpendable ECHO: prefix ...
Regards,
frechefuchs
There's some thoughts on the table for both of those things.
See issue #6385: New output/formatting suite: print(), quote(), format()
https://github.com/openscad/openscad/issues/6385
