Re: [OpenSCAD] rotate_extrude : many doubt
Thu, Dec 29, 2016 1:54 PM
Again your code example is not complete!
  1. did you read the wiki well? It says: *angle [Note: Requires version
    2016.XX] *
  2. You can't render a 2D object together with a 3D object.
  3. Your parametrization might be the reason for a singularity at the axis -
    but I guess this complex has been fixed meanwhile.
View this message in context: http://forum.openscad.org/rotate-extrude-many-doubt-tp19812p19815.html
Again your code example is not complete! 1. did you read the wiki well? It says: *angle [Note: Requires version 2016.XX] * 2. You can't render a 2D object together with a 3D object. 3. Your parametrization might be the reason for a singularity at the axis - but I guess this complex has been fixed meanwhile. -- View this message in context: http://forum.openscad.org/rotate-extrude-many-doubt-tp19812p19815.html Sent from the OpenSCAD mailing list archive at Nabble.com.
E
eexpss
Fri, Dec 30, 2016 7:26 AM
OK, seems it comes all due to the version problem.
View this message in context: http://forum.openscad.org/rotate-extrude-many-doubt-tp19812p19827.html
OK, seems it comes all due to the version problem. -- View this message in context: http://forum.openscad.org/rotate-extrude-many-doubt-tp19812p19827.html Sent from the OpenSCAD mailing list archive at Nabble.com.
