Is there a neat hack to multiply all the numbers in a list other than
recursive methods?
recursive methods?
If you're goal is "avoid recursion" I think you could do it with a C-style
for loop. However, in my experience, the C-style for loops are slower than
recursion, so their only potential advantage would be avoiding recursion
depth limits.
You could take the log of the items in the list, multiply by a vector of all
ones to sum, and then apply exp.
function prod(v) =
let(
logv = [for(item=v) ln(item)],
ones = [for(i=[0:1:len(v)-1]) 1]
exp(logv*ones);
Thanks
function prod(v) = exp([for(i=v) ln(i)]* [for(i=v) 1]);
Sure does satisfy neat if not speed. :)
TLC123 wrote
Thanks
I've done tons of timing tests on OpenSCAD code and I'm pretty sure this is
the fastest way to compute a product. The question is whether you care
about speed, actually. Also, how long is your list? Because products of
long lists are either zero or infinity unless they are very specially formed
lists.
I did a quick time test against the recursive approach to demonstrate this
(and I'm not at all surprised to see that this code is about 4-6 times
faster than the recursive approach):
On length 100k lists:
recursive method: 450 ms
log method: 80ms
On length 1000 lists:
recursive: 4ms
log method: 0.8 ms
length 10 lists:
recursive: 50 microseconds
log method: 12 microseconds
The real issue I see with this code is accuracy and of course the inability
to handle inputs less than zero. It can produce non-integer output for
integer input, for example. (Note, it appears that exp(log(0))=0. Does
that always work?)
