Hi guys,
I am new to openscad and 3d printing. My first project will be a fan mount -
to mount a 120mm fan on a 110mm outside diameter pipe.
I have the fan mount set up but i wonder how I can design something that
will reduce the square 120mm to 110mm round.
Any ideas?
View this message in context: http://forum.openscad.org/Square-to-round-transformation-tp14712.html
Taking the convex hull of a square and a cylinder will give you the basic
shape. Then subtract a smaller version to hollow it out.
On Nov 23, 2015 2:21 PM, "Sebastian Heyn" sebastian.heyn@yahoo.de wrote:
Hi guys,
Any ideas?
Since getting started can be hard, here's a basic implementation of what
it sounds like you want. Note that I didn't use your dimensions; you'll
need to do plenty more work to make a usable part, but it should get you
started. Good luck with your part.
circleRadius = 50;
circleHeight = 5;
squareSize = [100, 100, 5];
height = 80;
cutout = 0;
wallThickness = 10;
// Larger version of the part from which we will cut the hollow
section, thus creating the walls
adapter(
circleRadius = circleRadius + wallThickness,
circleHeight = circleHeight,
squareSize = squareSize + [wallThickness2, wallThickness2, 0],
height = height,
cutout = 0
// Smaller cutout, to create the walls
adapter(
circleRadius = circleRadius,
squareSize = squareSize,
height = height,
cutout = 1
// A generic version of the part that we can reuse multiple times, both
to create walls and if you wanted a different
// sized version in the same SCAD file.
module adapter(
circleRadius,
circleHeight,
squareSize,
height,
cutout
// This creates the primary part -- the hull of a cylinder and a cube
hull() {
translate([0,0,squareSize.z/2]) cube(squareSize, center=true);
translate([0,0,height-circleHeight]) cylinder(r=circleRadius,
h=circleHeight, center=true);
// This extends the cylinder out the top, if that's desired
translate([0,0,height]) cylinder(r=circleRadius,
h=circleHeight+cutout, center=true);
// This extends the square portion below the part if we are a cutout
if (cutout > 0) {
translate([0,0,-cutout]) cube([squareSize.x, squareSize.y,
cutout+squareSize.z], center=true);
nop head mailto:nop.head@gmail.com
November 23, 2015 at 06:53
basic shape. Then subtract a smaller version to hollow it out.
Sebastian Heyn mailto:sebastian.heyn@yahoo.de
November 23, 2015 at 06:20
Hi guys,
mount -
Any ideas?
or work on improving this one
http://www.thingiverse.com/thing:1015874
View this message in context: http://forum.openscad.org/Square-to-round-transformation-tp14712p14729.html
