My current(*) design generates the following warning:
DEPRECATED: Using ranges of the form [begin:end] with begin value greater than the end value is deprecated.
This doesn't help me find where this happens. (no line number)
(Ceterum autem censeo Carthaginem esse delendam)
I also want to say that I don't agree with this: Often the 0...0 case
means: one copy and 0...-1 means zero copies. Simple.
Say I want to make n fenceposts:
for (i=[0:n-1])
translate ([pitch*i,0,0]) onepost ();
That works, even for one fencepost.
But now the first fencepost needs to be a bit different:
onepost (first=true);
for (i=[1:n-1])
translate ([pitch*i,0,0]) onepost (first=false);
Now the one-fence-post case will trigger the warning. To prevent the
warning I need to special case the "regular posts" to the condition
that there ARE regular posts.
(*) I created the design a while ago, I'm mostly a "user" of the
design now. Last time I built some object-A this time I'm building
object-b and somewhere in there there this warning is triggered.
Add a step size to get rid of the warming. E.g. for (i=[1 : 1 : n-1])
for (i=[0:n-1])
for (i=[1:n-1])
OK! Thanks for the tip. Where in the code?
Actually, its relatively easy: The code is only 282 lines long.
And there are only three for loops:
240: for (i=[0:nx-1]) {
241: for (j=[0:ny-1]) {
257: for (i=[0:180:180])
nx and ny are both "2" today.
P.S. I just tried adding the implicit :1 and it makes the whole thing
stop working. Without the :1 I get the 4 modules, with the added :1 I
get nothing.
Here is my code:
module m4 (nx=2, ny=2, model=0)
p=75;
for (i=[0:nx-1]) { // this is line 240.
for (j=[0:ny-1]) {
translate ([ip,jp,0]) mymodule (model);
m4 (nx=2, ny=2, 0);
Note: The m4 module started out doing 2x2 or 4 modules as I'm
rendering/printing today, but since then I added the parameters but
have not changed the name.
get nothing.
I just implemented a "full program" that shows this problem.
Below is the code, no warning, not working, remove the :1 and
it does what I expect of it.
module mymodule (model)
cylinder (d=65,h=10);
p=75;
for (i=[0:1:nx-1]) { // this is line 240.
for (j=[0:ny-1]) {
m4 (nx=2, ny=2, 0);
Sorry, in your case nx is zero so it is looping from 0 to -1, so a negative
step would get rid of the warning.
I think you meant to set model to 0 but it is actually setting nx to zeo.
get nothing.
p=75;
for (j=[0:ny-1]) {
m4 (nx=2, ny=2, 0);
So me redundantly specifying the name of the first and second
parameter causes the third parameter (of the call) to overwrite the
just explicitly specified-by-name first parameter (of the called
module)?????? You're shitting me, right?
Now that's something what might warrant a warning if not a rewrite to
change that behaviour....
m4 (nx=2, ny=2, 0);
Yes the first unnamed parameter is assigned to position 1 and so on. In
Python you get "SyntaxError: positional argument follows keyword argument"
negative
m4 (nx=2, ny=2, 0);
That would be good. But the historical behavior is that it just
reverses the two endpoints. Pretty much everybody agrees that's not
desirable, hence the warning.
for (i=[3:1]) echo(i);
ECHO: 1
ECHO: 2
ECHO: 3
(test - pls ignore)
From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of Jordan Brown
Sent: Sun, 9 Aug 2020 13:20
To: OpenSCAD general discussion; Rogier Wolff
Subject: Re: [OpenSCAD] Useless warning....
deprecated.
That would be good. But the historical behavior is that it just reverses the two endpoints.
Pretty much everybody agrees that's not desirable, hence the warning.
deprecated.
ECHO: 1
ECHO: 2
ECHO: 3
Yes, the new behaviour makes more sense as I can't remember a writing a
loop where I wanted to go in both directions. And now we don't need an if
to test for the empty case.
I.e.
if(n) for(i = [0 : n - 1]) ...
becomes
for(i = [0 : 1 : n - 1]) ...
and in Rogier's case the warning found another bug, because the loop was
actually running 0, -1 instead of 0, 1
On Sun, 9 Aug 2020 at 07:40, OzAtMichael oz.at.michael@gmail.com wrote:
(test - pls ignore)
*Jordan Brown
the two endpoints. Pretty much everybody agrees that's not desirable,
hence the warning.
ECHO: 1
ECHO: 2
ECHO: 3
<#m_-8701791307388534068_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
