Re: [OpenSCAD] Rounded Polygon
CA
Sat, Apr 27, 2019 6:53 PM
On 27.04.2019 15:09, jon wrote:
I would be curious to see examples and timings comparing AngelCAD and
OpenSCAD.  I believe you've presented some in the past. Perhaps there
are specific situations in which AngelCAD should be preferred.
Here is the "manyballs" performance example compared for N=5, i.e. 5x5x5
balls with OpenSCAD & AngelCAD source codes.
https://gist.github.com/arnholm/98b007bb960e328ef9a986a96b412607
You are welcome to try higher numbers of N or suggest other comparisons.
Carsten
On 27.04.2019 15:09, jon wrote: > I would be curious to see examples and timings comparing AngelCAD and > OpenSCAD.  I believe you've presented some in the past. Perhaps there > are specific situations in which AngelCAD should be preferred. > > Jon Here is the "manyballs" performance example compared for N=5, i.e. 5x5x5 balls with OpenSCAD & AngelCAD source codes. https://gist.github.com/arnholm/98b007bb960e328ef9a986a96b412607 You are welcome to try higher numbers of N or suggest other comparisons. Carsten
