accepted by the mailing list yet", so nobody gets it unless they look.
You need to subscribe to the mailing list
Eric Buijs wrote
Hi, while doing a simple tutorial I encountered a possible bug in
OpenScad's renderer.
Below is the code. The outer cube should have a circular holes on every
side of the cube but after pressing F6 some of the holes aren't fully
circular (the preview mode is ok). Even worse the stl file has the same
mistake. Any idea what causes this problem?
cube([90,90,90], center =true);
union()
cube([80,80,80], center =true);
cylinder(r = 27.5, h = 90, center = true);
rotate([90,0,0]) cylinder(r = 27.5, h = 90, center = true);
rotate([0,90,0]) cylinder(r = 27.5, h = 90, center = true);
P.S: I work in OSX (10.10.5), OpenScad 2015.03-03
View this message in context: http://forum.openscad.org/Bug-in-OpenScad-rendering-tp16396p16397.html
