Thu, Aug 22, 2024 4:48 PM
Hmmm.... I just tried to use the Measure feature in OpenSCAD version
2024.08.05 (git 8119ad428) and I cannot seem to get it to work.
After clicking on the measure button, am I meant to see something on the
display when I click on places to measure?
Where is the result displayed?
Thanks!
On Mon, Aug 5, 2024 at 2:21 PM larry via Discuss discuss@lists.openscad.org
On Mon, 2024-08-05 at 15:57 +0100, Raymond West via Discuss wrote:
OpenSCAD version 2024.02.19 (git 5cfd4dbe0) windows 11
Just realised, from another post that measuring was now incorporated.
Any description of its use? It seems that I can only measure once,
then 'Esc' then select from menu again and measure.
Or you can use the 'buttons' at the bottom of the graphic window.
Distance is:
| 10 |
Angle is:
\ 45 /
Click onc, select two place, get measurement, click 'button' again.
Play with it. Neat feature.
'D' seems to be not ahot key. It does not work on f5 rendering, but
the greying out is not very much different from normal text in
general.
Thanks!
On Mon, Aug 5, 2024 at 2:21 PM larry via Discuss <discuss@lists.openscad.org>
> Distance is:
> | 10 |
> Angle is:
> \ 45 /
> > general.
> > OpenSCAD mailing list
Thu, Aug 22, 2024 6:59 PM
On Thu, 2024-08-22 at 11:48 -0500, Leonard Martin Struttmann via
the display when I click on places to measure?
incorporated.
once,
Distance is:
| 10 |
Angle is:
\ 45 /
but
general.
Try a render first.
> Thanks!
> > > incorporated.
> > > once,
> > Distance is:
> > | 10 |
> > Angle is:
> > \ 45 /
> > > but
> > > general.
Thu, Aug 22, 2024 8:42 PM
incorporated.
once,
Distance is:
| 10 |
Angle is:
\ 45 /
but
general.
Ahhhh! Thanks!
On Thu, Aug 22, 2024 at 2:00 PM larry via Discuss <
> Try a render first.
> > Thanks!
> > > > incorporated.
> > > > once,
> > > Distance is:
> > > | 10 |
> > > Angle is:
> > > \ 45 /
> > > > but
> > > > general.
Thu, Aug 22, 2024 9:30 PM
Well, if the Measure button fails when F6 has not been pressed, then
maybe an informative message is in order.
On 8/22/2024 4:42 PM, Leonard Martin Struttmann via Discuss wrote:
Ahhhh! Thanks!
incorporated.
once,
Distance is:
| 10 |
Angle is:
\ 45 /
but
general.
> Ahhhh! Thanks!
> version
> Try a render first.
> > Thanks!
> > > > incorporated.
> > > > once,
> > > Distance is:
> > > | 10 |
> > > Angle is:
> > > \ 45 /
> again.
> rendering,
> > > > but
> > > > general.
MF
mike.fraser.1945+osc@gmail.com
Tue, Sep 10, 2024 11:55 AM
Well, I still get no results with Measure in Build 2023.08.30 by either <Design><Measure> or clicking the buttons in the 3D toolbar. Is there any documentation?
Tue, Sep 10, 2024 3:26 PM
On Tue, 2024-09-10 at 11:55 +0000, mike.fraser.1945+osc--- via Discuss
You need to render it first.
