a curve logo
JJ
Johan Jonker
Mon, Dec 21, 2015 12:57 PM
I like to have a handwritten logo in my 3D printed objects.
With surface it is possible to convert a png file into a 3D logo that you
can add or substract from flat surfaces. But I liked to have to logo on a
curved object.
So I made a curved logo in this way:
http://forum.openscad.org/file/n15260/democurvedlogo.png
The code is as follows:
// module to make a curved logo from a png file
curvedlogo(20,20);
module curvedlogo(diameter,lenght)
$fn=60;
translate([0,0,-diameter/2])
intersection()
        // create a tube with 2* lenght and diameter
            rotate(90,[1,0,0])
              translate([0,0,-lenght])
cylinder(lenght*2,diameter/2+4,diameter/2+4,center=false);
rotate(90,[1,0,0])
translate([0,0,-lenght-0.1])
cylinder(lenght2+0.2,diameter/2,diameter/2,center=false);
// create a 3D logo with height diameter
2
translate([0,0,diameter])
resize([lenght, lenght, diameter])
surface(file = "logob.png", center = true, invert=true,
convexity = 5);
View this message in context: http://forum.openscad.org/a-curve-logo-tp15260.html
I like to have a handwritten logo in my 3D printed objects. With surface it is possible to convert a png file into a 3D logo that you can add or substract from flat surfaces. But I liked to have to logo on a curved object. So I made a curved logo in this way: <http://forum.openscad.org/file/n15260/democurvedlogo.png> The code is as follows: //------------------------------------------------ // module to make a curved logo from a png file //------------------------------------------------ curvedlogo(20,20); module curvedlogo(diameter,lenght) { $fn=60; translate([0,0,-diameter/2]) intersection() { // create a tube with 2* lenght and diameter difference() { rotate(90,[1,0,0]) translate([0,0,-lenght]) cylinder(lenght*2,diameter/2+4,diameter/2+4,center=false); rotate(90,[1,0,0]) translate([0,0,-lenght-0.1]) cylinder(lenght*2+0.2,diameter/2,diameter/2,center=false); } // create a 3D logo with height diameter*2 translate([0,0,diameter]) resize([lenght, lenght, diameter]) surface(file = "logob.png", center = true, invert=true, convexity = 5); } } -- View this message in context: http://forum.openscad.org/a-curve-logo-tp15260.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Dec 21, 2015 2:06 PM
Good approach! If there was a function importing data into a matrix, one
could do really crazy things!
View this message in context: http://forum.openscad.org/a-curve-logo-tp15260p15261.html
Good approach! If there was a function importing data into a matrix, one could do really crazy things! -- View this message in context: http://forum.openscad.org/a-curve-logo-tp15260p15261.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Dec 21, 2015 2:31 PM
curved object.
surface() tends to be very slow.
A better approach would be to trace the png into a vector outline.
We’re working on such a built-in function, see here: https://github.com/openscad/openscad/pull/1110
There are also external tools for this:
http://aggregate.org/MAKE/TRACE2SCAD/
http://chaaawa.com/stencil_factory_js/
> On Dec 21, 2015, at 07:57 AM, Johan Jonker <johangjonker@zonnet.nl> wrote: > > I like to have a handwritten logo in my 3D printed objects. > With surface it is possible to convert a png file into a 3D logo that you > can add or substract from flat surfaces. But I liked to have to logo on a > curved object. surface() tends to be very slow. A better approach would be to trace the png into a vector outline. We’re working on such a built-in function, see here: https://github.com/openscad/openscad/pull/1110 There are also external tools for this: http://aggregate.org/MAKE/TRACE2SCAD/ http://chaaawa.com/stencil_factory_js/ -Marius
JJ
Johan Jonker
Mon, Dec 21, 2015 3:44 PM
That right it is very slow. It helped when I reduced the complexity of the
logo and first made and slt file of the logo, simplified it using Meshlab
and then import it.
Here is the result:
http://forum.openscad.org/file/n15263/barrel_met_logo.png
View this message in context: http://forum.openscad.org/a-curve-logo-tp15260p15263.html
That right it is very slow. It helped when I reduced the complexity of the logo and first made and slt file of the logo, simplified it using Meshlab and then import it. Here is the result: <http://forum.openscad.org/file/n15263/barrel_met_logo.png> -- View this message in context: http://forum.openscad.org/a-curve-logo-tp15260p15263.html Sent from the OpenSCAD mailing list archive at Nabble.com.
N
Neon22
Mon, Dec 21, 2015 7:28 PM
Looks good. Another approach is to use Inkscape and its tools, to vectorise
your bitmap, and then export to openSCAD using a special extension.
  • in inkscape the tool is under the Path menu and is called "Trace bitmap".
    (POTrace does the work and its code is avilable for other projects to
    include).
  • The Extension is under "Generate from Paths" / "Paths to openSCAD".
  • you need to install the Inkscape extension from here:
View this message in context: http://forum.openscad.org/a-curve-logo-tp15260p15270.html
Looks good. Another approach is to use Inkscape and its tools, to vectorise your bitmap, and then export to openSCAD using a special extension. - in inkscape the tool is under the Path menu and is called "Trace bitmap". (POTrace does the work and its code is avilable for other projects to include). - The Extension is under "Generate from Paths" / "Paths to openSCAD". - you need to install the Inkscape extension from here: - http://www.thingiverse.com/thing:1065500 -- View this message in context: http://forum.openscad.org/a-curve-logo-tp15260p15270.html Sent from the OpenSCAD mailing list archive at Nabble.com.
