It would be nice if we could take modules as arguments to other modules, a
little bit like children(). Something like this:
module stamp(handleshape,stampshape,faceshape){
union(){
handleshape();
stampshape();
faceshape();
module myhandleshape(length){
//Define handle here
module mylefthandedhandleshape(length){
module mystampshape(){
//Define the shape of the rubber stamp outline here
module myfaceshape(){
//Define the shape of the stamp cutouts here
module mylogofaceshape(){
stamp(myhandleshape(100),mystampshape,myfaceshape);
stamp(mylefthandledhandleshape(100),mystampshape,mylogofaceshape);
This is just a simple example, and I know this example could have been done
differently, in just a little more awkward ways. But, as things get more
complicated, it can really make the code much neater and more modular and
flexible.
The problem is there may also be a function called handleshape() and
because functions and variables have separate namespaces handleshape()
means call that function, not interpret a variable with the same name as a
function reference,
union(){
handleshape();
stampshape();
faceshape();
flexible.
function reference,
Well, that goes for children() as well.
But, that could probably be cleared with some variation of the syntax. It's
just an example. The point is to be able to send objects in as arguments.
Not sure what you mean because children() only takes modules and they have
their own namespace as well.
It's unusual to have different name spaces but it like it as I don't have
to think up three names. I have screw() as a module and often screw as a
variable and possibly a function.
People have suggested being able to pass functions before, even some pull
requests IIRC but they haven't been merged. It gets more complex when you
consider scope. Possible it needs a new variable type to hold a function
reference. A new syntax to assign a function to that variable and a new
syntax to call it.
a
function reference,
union(){
handleshape();
stampshape();
faceshape();
If I understand what you're asking for, you can do this with children( )
today.
module stamp(){
// Children:
handle = 0;
stamp = 1;
face = 2;
union(){
children(handle);
children(stamp);
children(face);
stamp() {
myhandleshape(100);
mystampshape();
myfaceshape();
stamp() {
mylefthandledhandleshape(100);
mystampshape();
mylogofaceshape();
One thing you can't do is pass arguments from the parent to the
children, because what you're passing to the parent are objects, not
function references.
You can pass arguments to children with $variables.
module stamp($handle_size){
// Children:
handle = 0;
stamp = 1;
face = 2;
union(){
children(handle);
children(stamp);
children(face);
stamp(100) {
mylefthandledhandleshape($handle_size);
mystampshape();
mylogofaceshape();
On Tue, 26 Feb 2019 at 19:49, Jordan Brown openscad@jordan.maileater.net
union(){
handleshape();
stampshape();
faceshape();
today.
module stamp(){
// Children:
handle = 0;
stamp = 1;
face = 2;
union(){
children(handle);
children(stamp);
children(face);
stamp() {
myhandleshape(100);
mystampshape();
myfaceshape();
stamp() {
mystampshape();
mylogofaceshape();
One thing you can't do is pass arguments from the parent to the children,
because what you're passing to the parent are objects, not function
references.
Just when I thought I understood OpenSCAD... now my head has exploded.
Who's going to clean up the mess?
Thanks. I don't know if I have any application for this mechanism, but
it's always good when my mental model gets adjusted to be closer to reality.
So it sounds like we're awfully close to being able to do what Troberg
asks, albeit in a way that's ... different ... from how it would be done
in a more conventional language.
Ooh, that's very neat, and takes care of the problem nicely. Thank you!
