Gadgetmind wrote
Might being able to force the triangulation save rendering time?
I'm not sure you can force a particular triangulation since CGAL does its
own thing.
My triangulator is also very slow and may misbehave unpredictably with bad
input. If the native OpenSCAD version works for you, I would recommend
using that.
Gadgetmind wrote
I'd much prefer that this be in the guts of OpenSCAD rather than in "user
land".
Native solutions are typically better, but there's something to be said for
being able to solve stuff in "user land" so that people aren't so reliant on
the OpenSCAD devs.
own thing.
The logic seems to be there but only used if/when cgal eventually barfs.
If I know it'll barf, then why not provide this information?
the OpenSCAD devs.
Agreed, and I currently triangulate myself, but with a solution that
only work for concave.
Maybe I'll open a feature request. And perhaps also suggest some code ...
Ian
On Feb 22, 2018, at 7:30 AM, Gadgetmind lists@foxhill.co.uk wrote:
On 22/02/18 10:08, nop head wrote:
Polyhedron does triangulate faces with more than three sides. It gives a warning first though and a few recent versions have a bug that makes it an error.
Ah, OK. I've seen the retry warning due to non-planar but, as you say, it's usually followed by an error. Has the bug been fixed?
I don’t think I’m aware of this bug. Has this been reported on the github issue tracker?
I guess Parkinbot refers to the issue #2246. See:
http://forum.openscad.org/Alternate-triangulation-bug-td22938.html
2018-02-23 23:44 GMT-03:00 Marius Kintel marius@kintel.net:
an error.
issue tracker?
