Sat, Feb 17, 2018 9:03 PM
What would be helpful to me (and perhaps to others?) is a facility
something like this:
I define a list of 2D (or 3D?) points of arbitrary length (like pts = [[1,
2], [3, 4], [5, 6], [7, 8], [9, 10], [11, 12]];)
I call a function (F()) passing in the points and a number between 0 and
- It is important that the points are passed in: if the points are
referenced as a global, I can only do this once in a program. Or I would
have to create multiple copies of the code with minor variations in
variable names.
The function (F()) returns a point somewhere along the curve. So, if I
call F(0) I get [1, 2]; if I call F(1) I get [11, 12]; and if I call F(0.5)
I get the point between [5, 6] and [7, 8] (where "between" takes into
account the curve smoothing). The curve smoothing algorithm could be
Bezier, but I suppose that it could be something else (polynomial
regression).
What you seem to want is some kind of interpolation.
I don't believe that polynomial regression or higher degree Bezier curves
are the best way to go. There is many interpolation schemes but, unless
you need a smooth curve (with continuous curvature), a Hermite
interpolation might be satisfactory. It will give you tangent continuity.
In the following, I will give you a specific way to do it based on the
subdivBezier3() function I mentioned before [1].
Given a list of points p to be interpolated, the following function
computes a list of points in a Hermite interpolation curve of those points:
function IntepolHerm(p, n=4) =
let( tgts = [ (p[1]-p[0])/3 ,
each [for(i=[1:len(p)-2]) p[i+1]-p[i-1] ]/6,
(p[len(p)-1]-p[len(p)-2])/3 ])
subdivBezier3([for(i=[0:len(p)-2]) each [ p[i], p[i]+tgts[i],
p[i+1]-tgts[i+1]], p[len(p)-1] ]);
The number of generated points by InterpHerm() depends exponentially on n
so keep it low: 3 or 4 should be enough.
An adequate parametrization of that curve in the interval [0,1] is the
following:
function F(t,pc) =
let( k = floor((len(pc)-1)*t),
s = (len(pc)-1)t - k )
k==len(pc)-1 ?
pc[len(pc)-1]
: pc[k](1-s) + pc[k+1]*s;
Given any t in the interval [0,1] and a Hermite interpolation pc computed
by InterpHerm(), the function F() produces a point in the curve such that:
F(0,pc) == pc[0] and
F(1,pc) == pc[len(pc)-1]
So, typically you should compute
pc = IntepolHerm(p) once and call F(t,pc) with as many values of t as you
want or need.
Note that with this setting, the input points p of IntepolHerm(p) may be
not only 2D or 3D points but may be any uniform list of lists of numbers.
So, you may define p such that:
p[i] = [ [ x[i], y[i], z[i] ], r[i], ang[i] ]; // the same structure for
all i
where [x,y,z] is a 3D point, r is a radius and ang is an angle. The
resulting "point" generated by F(t,pc) will have the same structure: a 3D
point, a radius and an angle. This way you can interpolate many different
parameter values in one go.
[1] http://forum.openscad.org/OpenSCAD-programming-question-
recursion-functions-and-modules-tp23197p23217.html
2018-02-16 12:21 GMT-02:00 jon <jon@jonbondy.com>:
> 1. It is important that the points are passed in: if the points are
> variable names.
> regression).
following:
function F(t,pc) =
s = (len(pc)-1)*t - k )
k==len(pc)-1 ?
pc[len(pc)-1]
: pc[k]*(1-s) + pc[k+1]*s;
want or need.
all i
Sun, Feb 18, 2018 8:04 AM
What would be helpful to me (and perhaps to others?) is a facility something like this:
I define a list of 2D (or 3D?) points of arbitrary length (like pts = [[1, 2], [3, 4], [5, 6], [7, 8], [9, 10], [11, 12]];)
I call a function (F()) passing in the points and a number between 0 and 1. It is important that the points are passed in: if the points are referenced as a global, I can only do this once in a program. Or I would have to create multiple copies of the code with minor variations in variable names.
The function (F()) returns a point somewhere along the curve. So, if I call F(0) I get [1, 2]; if I call F(1) I get [11, 12]; and if I call F(0.5) I get the point between [5, 6] and [7, 8] (where "between" takes into account the curve smoothing). The curve smoothing algorithm could be Bezier, but I suppose that it could be something else (polynomial regression).
What you seem to want is some kind of interpolation. I don't believe that polynomial regression or higher degree Bezier curves are the best way to go. There is many interpolation schemes but, unless you need a smooth curve (with continuous curvature), a Hermite interpolation might be satisfactory. It will give you tangent continuity. In the following, I will give you a specific way to do it based on the subdivBezier3() function I mentioned before [1].
Given a list of points p to be interpolated, the following function computes a list of points in a Hermite interpolation curve of those points:
subdivBezier3([for(i=[0:len(p)-2]) each [ p[i], p[i]+tgts[i], p[i+1]-tgts[i+1]], p[len(p)-1] ]);
The number of generated points by InterpHerm() depends exponentially on n so keep it low: 3 or 4 should be enough.
An adequate parametrization of that curve in the interval [0,1] is the following:
function F(t,pc) =
k==len(pc)-1 ?
pc[len(pc)-1]
Given any t in the interval [0,1] and a Hermite interpolation pc computed by InterpHerm(), the function F() produces a point in the curve such that:
So, typically you should compute pc = IntepolHerm(p) once and call F(t,pc) with as many values of t as you want or need.
Note that with this setting, the input points p of IntepolHerm(p) may be not only 2D or 3D points but may be any uniform list of lists of numbers. So, you may define p such that:
p[i] = [ [ x[i], y[i], z[i] ], r[i], ang[i] ]; // the same structure for all i
where [x,y,z] is a 3D point, r is a radius and ang is an angle. The resulting "point" generated by F(t,pc) will have the same structure: a 3D point, a radius and an angle. This way you can interpolate many different parameter values in one go.
[1] http://forum.openscad.org/OpenSCAD-programming-question-recursion-functions-and-modules-tp23197p23217.html
If it’s helpful for you, I just tweaked my BOSL library’s bezier.scad to accept N-order beziers by giving an N= argument to the related bezier functions and modules.
Library code:
https://github.com/revarbat/BOSL/
Relevant docs:
https://github.com/revarbat/BOSL/wiki/paths.scad
https://github.com/revarbat/BOSL/wiki/beziers.scad
Some modules still have problems extruding concave paths, though. I’m having troubles getting a good function working to triangulate the end faces. Functional programming is like pulling teeth for this sort of thing. *shakes fist impotently* Any pointers would be appreciated, if anybody has done this.
- Revar
> On Feb 17, 2018, at 1:03 PM, Ronaldo Persiano <rcmpersiano@gmail.com> wrote:
> function F(t,pc) =
> k==len(pc)-1 ?
> pc[len(pc)-1]
Sun, Feb 18, 2018 10:37 AM
I don't see how a line-oriented interpolation scheme operating over a
sequence of N-points will result in a vase, unless the N-points are fed into
some generator function, which Jon seemingly wants to avoid.
- For the description of a 2-manifold some 2D-interpolation scheme
operating over a grid, a sequence of polygons or similar is needed.
- Further, boundary conditions are of interest whenever a sequence is not
circular. E.g. to describe the bottom and the top of the vase.
- With an interpolation scheme you can only describe smooth surfaces. This
is not always wanted. Therefore a Bezier-base approach is richer ...
1. For the description of a 2-manifold some 2D-interpolation scheme
2. Further, boundary conditions are of interest whenever a sequence is not
3. With an interpolation scheme you can only describe smooth surfaces. This
N
NateTG
Sun, Feb 18, 2018 2:47 PM
faces.
Detecting self-intersection is a bit of a chore. Detecting 0-length
segments is easy. Once you have those two pieces worked out, polyhedron
accepts faces with more than 3 edges now.
faces.
Sun, Feb 18, 2018 11:10 PM
Sadly, CGAL will barf frequently even with known good coplanar face points. CGAL is only really reliable with triangles, in my experience.
- Revar
> faces.
Mon, Feb 19, 2018 4:36 AM
In OpenSCAD, we work around this by first giving CGAL the know good coplanar face, and if it throws an exception, we send it a triangulated version.
N
NateTG
Mon, Feb 19, 2018 10:15 AM
> - Revar
FWIW I did write a face triangulator:
triangulate.scad <http://forum.openscad.org/file/t2140/triangulate.scad>
It's not particularly clever or efficient, but it should work.
Mon, Feb 19, 2018 3:45 PM
It seems that your ear clipping method doesn't work properly in some cases:
face = [[20, 0], [15.5279, 8.96503], [10, 17.3205], [0, 8.85357], [-10,
17.3205], [-31.0929, 17.9515], [-20, 0], [-33.2343, -19.1878], [-10,
-17.3205], [0, -14.4569], [10, -17.3205], [19.0507, -10.9989]]
face = [[20, 0], [31.8838, 18.4081], [10, 17.3205], [0, 7.34213], [-10,
17.3205], [-27.7456, 16.019], [-20, 0], [-5.22655, -3.01755], [-10,
-17.3205], [0, -29.8851], [10, -17.3205], [4.12534, -2.38177]]
face = [[20, 0], [24.6573, 14.2359], [10, 17.3205], [0, 6.03876], [-10,
17.3205], [-20.8959, 12.0643], [-20, 0], [-19.3807, -11.1895], [-10,
-17.3205], [0, -27.649], [10, -17.3205], [11.166, -6.44668]]
2018-02-19 7:15 GMT-03:00 NateTG nate-openscadforum@pedantic.org:
2018-02-19 7:15 GMT-03:00 NateTG <nate-openscadforum@pedantic.org>:
N
NateTG
Mon, Feb 19, 2018 7:06 PM
cases:face = [[20, 0], [15.5279, 8.96503], [10, 17.3205], [0, 8.85357],
[-10,17.3205], [-31.0929, 17.9515], [-20, 0], [-33.2343, -19.1878],
[-10,-17.3205], [0, -14.4569], [10, -17.3205], [19.0507, -10.9989]]face =
[[20, 0], [31.8838, 18.4081], [10, 17.3205], [0, 7.34213], [-10,17.3205],
[-27.7456, 16.019], [-20, 0], [-5.22655, -3.01755], [-10,-17.3205], [0,
-29.8851], [10, -17.3205], [4.12534, -2.38177]]face = [[20, 0], [24.6573,
14.2359], [10, 17.3205], [0, 6.03876], [-10,17.3205], [-20.8959, 12.0643],
[-20, 0], [-19.3807, -11.1895], [-10,-17.3205], [0, -27.649], [10,
-17.3205], [11.166, -6.44668]]...
Thanks for the test cases. This should be fixed: triangulate.scad
Mon, Feb 19, 2018 8:50 PM
Nice but I still have caught some other cases with this test code:
b = 20;
seed =floor(rands(0,10000,1)[0]); // some problematic seeds: 2517, 4041,
2033
echo(seed=seed); // to reproduce problematic cases
a = rands(b/5, 2*b, 12,seed);
star = [ for(i=[0:30:360-1]) (i%60 ? a[i/30]:b)*[cos(i), sin(i)] ];
color("red")
translate([0,0,-5])
polygon(star);
star3 = to3d(star);
polyhedron( star3, triangulate_face(star3,[for(i=[0:len(star)-1]) i ]));
2018-02-19 16:06 GMT-03:00 NateTG nate-openscadforum@pedantic.org:
cases: face = [[20, 0], [15.5279, 8.96503], [10, 17.3205], [0, 8.85357],
[-10, 17.3205], [-31.0929, 17.9515], [-20, 0], [-33.2343, -19.1878], [-10,
-17.3205], [0, -14.4569], [10, -17.3205], [19.0507, -10.9989]] face = [[20,
0], [31.8838, 18.4081], [10, 17.3205], [0, 7.34213], [-10, 17.3205],
[-27.7456, 16.019], [-20, 0], [-5.22655, -3.01755], [-10, -17.3205], [0,
-29.8851], [10, -17.3205], [4.12534, -2.38177]] face = [[20, 0], [24.6573,
14.2359], [10, 17.3205], [0, 6.03876], [-10, 17.3205], [-20.8959, 12.0643],
[-20, 0], [-19.3807, -11.1895], [-10, -17.3205], [0, -27.649], [10,
-17.3205], [11.166, -6.44668]] ...
at Nabble.com.
b = 20;
2033
color("red")
translate([0,0,-5])
polygon(star);
star3 = to3d(star);
2018-02-19 16:06 GMT-03:00 NateTG <nate-openscadforum@pedantic.org>:
> at Nabble.com.
