Sun, Sep 5, 2021 8:40 AM
It breaks topology when points get merged that shouldn't be, for example
two surfaces that are close but not touching collapse and make a
non-manifold that CGAL will barf on.
On Sun, 5 Sept 2021 at 09:40, Gareth Chen garethenator@gmail.com wrote:
I'm pretty sure the imprecision with floating point numbers is irrelevant,
because OpenSCAD merges points that are within ~0.00003 of each other.
On Sat, Sep 4, 2021, 6:57 PM Doug Moen doug@moens.org wrote:
Okay, let's introduce some notation. "~0.1" means the closest binary
approximation of the number 0.1 in IEEE 64 bit floating point. It's not
exactly equal to "0.1", it is actually
0.1000000000000000055511151231257827021181583404541015625
Now suppose we start at 0, and repeatedly add ~0.1 to our total. But we
will do the addition using IEEE floating point arithmetic, which does not
produce exact results.
The first numbers in our sequence are ~0, ~0.1, ~0.2
Because of the binary representation of floating point, x+x is always
exactly the same as 2*x, there is no rounding or floating point imprecision
in the result.
But when we add ~0.1 a third time, we get an imprecise result. ~0.1 +
~0.2 == ~0.30000000000000004. When we added ~0.1 to our running total, our
total did not increase by ~0.1, it instead increased by a slightly larger
value, ~0.10000000000000003, and this is due to floating point imprecision.
Here is the same numeric sequence printed in a less ambiguous format:
0.00000000000000000000000000000000000000000000000000000000
0.10000000000000000555111512312578270211815834045410156250
0.20000000000000001110223024625156540423631668090820312500
0.30000000000000004440892098500626161694526672363281250000
If the final addition had been performed exactly, the final value would
have instead been:
0.30000000000000001665334536937734810635447502136230468750
This means that the individual cubes in your stack do not all have the
same height.
On Sat, Sep 4, 2021, at 8:48 PM, Jordan Brown wrote:
On 9/4/2021 3:33 PM, Doug Moen wrote:
On Fri, Sep 3, 2021, at 2:00 PM, Jordan Brown wrote:
Remember that while 0.1 cannot be represented precisely, it can be
represented repeatably.
If you made a stack of 0.1 cubes by successively adding 0.1, I'd expect
all to be well because the top Z values of the cubes would have been
calculated using the same values as the bottom Z values of the next cubes
up.
That's not true because of the representation of geometry in OpenSCAD. In
that stack of cubes, the height of each cube is not represented by the
number 0.1, it is represented by a difference in Z coordinates. OpenSCAD's
64 bit floating point numbers have a fixed number of bits of precision (53
bits), so as the magnitude of a number gets larger, bits of precision are
lost at the low end. There are more floating point numbers between 0.0 and
0.1 than there are between 10.0 and 10.1, so in the latter case, the
difference of 0.1 is represented by fewer bits of precision. 10.1 - 10.0 ==
0.09999999999999964, which is different from 0.1.
All of that is true, except for the "that's not true" part. :-)
I set up a very special case: a stack of cubes, stacked by successively
adding 0.1.
Yes, the first cube starts at Z=0 and ends at Z=0.09999999999999964. But
the next cube starts at Z=0.09999999999999964, and continues to
0.09999999999999964 + 0.09999999999999964. And so on. The top face of
each cube will precisely match the bottom face of the next cube. The
binary representation of 0.1 is not equal to 0.1, and the binary
representation of 0.1 plus itself is not equal to 0.2 (and may not be equal
to the binary representation of 0.2), but it is equal to a separately
calculated sum of the binary representation of 0.1 and the binary
representation of 0.1.
That is, 0.1+0.1 may or may not be equal to 0.2, but is always equal to
0.1+0.1.
But see below for the more general answer.
It's a little trickier if you made a stack of cubes by multiplying the
cube number by 0.1, but I think all would still be well, even without grid
snap. All of the top Z values would have been calculated using the same
numbers, as would all of the bottom Z values. Those top Z values would
either all be the same as the bottom Z values of the next layer, or would
all be different. In either case, you're OK.
Multiplication will give you more accurate results than iterative
addition of 0.1.
10*0.1 == 1 while iteratively adding 0.1 ten times gives you a different
number, 0.9999999999999999
Yes. Say that you stack ten 0.1 unit cubes by successively adding 0.1.
Indeed, the top face of the topmost cube may well be at something like
0.9999999999999999.
Now you place an eleventh cube at Z=1. That cube extends from Z=1 to
Z=~1.1. With these numbers, that means that there is a microscopic gap (or
actually an attoscopic gap :-) between the tenth and the eleventh.
But we shouldn't assume that the representation is always a tiny bit less
than the true number. Perhaps it is sometimes a tiny bit more.
You are still OK, because all of the corner points in the top face of the
tenth cube are at some particular Z value (call it Z1), and all of the
corner points in the bottom face of the eleventh cube are at some
particular Z value (call it Z2). If Z1 and Z2 are the same, you're OK
because the two faces precisely match. If they are different, you are OK
because they either do not touch, or they overlap. Grid snap doesn't
affect that, because (I assume) grid snap will snap all of the points the
same way - again, they will either all match, or not touch, or overlap.
You should be OK with any stack of cuboids (of constant X-Y dimensions,
aligned in X and Y), no matter what the heights of the cuboids are and no
matter how they are spaced, because the top and bottom faces of each cuboid
are perfectly parallel with the XY plane. You can never get just one edge
shared; either none of the edges are shared or they are all shared.
I'm pretty sure that this behavior is preserved across translation and
scaling - again, the points will either all match, or will all not match,
because the top and bottom faces remain perfectly parallel to the XY
plane. I'm pretty sure that it is not preserved across rotation or
skewing; while points that match will stay matched, points that are not
matched might become matched, and that result could be different for
different corners of the cubes.
>> in the result.
>> have instead been:
>> same height.
>> Remember that while 0.1 cannot be represented *precisely*, it can be
>> represented *repeatably*.
>> up.
>> adding 0.1.
>> to the binary representation of 0.2), but it *is* equal to a separately
>> 0.1+0.1.
>> addition of 0.1.
>> 0.9999999999999999.
>> plane. I'm pretty sure that it is *not* preserved across rotation or
>> skewing; while points that match will stay matched, points that are *not*
>> matched might *become* matched, and that result could be different for
>> OpenSCAD mailing list
GC
Gareth Chen
Sun, Sep 5, 2021 9:10 AM
Yeah that makes sense, it just doesn't have anything to do with floating
point precision
irrelevant, because OpenSCAD merges points that are within ~0.00003 of each
other.
in the result.
have instead been:
same height.
up.
In that stack of cubes, the height of each cube is not represented by the
adding 0.1.
But the next cube starts at Z=0.09999999999999964, and continues to
0.1+0.1.
addition of 0.1.
0.9999999999999999.
less than the true number. Perhaps it is sometimes a tiny bit more.
the tenth cube are at some particular Z value (call it Z1), and all of the
point precision
>> other.
>>> in the result.
>>> have instead been:
>>> same height.
>>> up.
>>> adding 0.1.
>>> 0.1+0.1.
>>> addition of 0.1.
>>> 0.9999999999999999.
Sun, Sep 5, 2021 9:12 AM
No but it is the consequence of grid snap that is trying to mitigate
point precision
other.
in the result.
have instead been:
same height.
up.
0.1+0.1.
addition of 0.1.
different number, 0.9999999999999999
0.1. Indeed, the top face of the topmost cube may well be at something
like 0.9999999999999999.
> point precision
>>> other.
>>>> in the result.
>>>> have instead been:
>>>> same height.
>>>> up.
>>>> 0.1+0.1.
>>>> addition of 0.1.
Michael Möller
Sun, Sep 5, 2021 12:11 PM
as in "damned if you do, and damned if you don't"
Msquare
søn. 5. sep. 2021 11.14 skrev nop head nop.head@gmail.com:
point precision
other.
we will do the addition using IEEE floating point arithmetic, which does
not produce exact results.
in the result.
would have instead been:
same height.
expect all to be well because the top Z values of the cubes would have been
up.
to 0.1+0.1.
addition of 0.1.
dimensions, aligned in X and Y), no matter what the heights of the cuboids
are and no matter how they are spaced, because the top and bottom faces of
each cuboid are perfectly parallel with the XY plane. You can never get
just one edge shared; either none of the edges are shared or they are all
shared.
Msquare
søn. 5. sep. 2021 11.14 skrev nop head <nop.head@gmail.com>:
>> point precision
>>>> other.
>>>>> in the result.
>>>>> same height.
>>>>> up.
>>>>> to 0.1+0.1.
>>>>> addition of 0.1.
>>>>> shared.
Sun, Sep 5, 2021 5:28 PM
each other.
I don't know the details of the grid snap algorithm, but it doesn't seem
like it can solve all of the problems.
Say that you have two points that are close enough that they would snap
together. Now add a third, along the same line, at the same distance.
Do all three snap together? Add a fourth, et cetera. Eventually it
needs to break the chain, snapping one set one way and another set the
other way. If the algorithm is an obvious rounding algorithm, even the
original pair might snap apart if they span a rounding boundary. (Using
conventional rounding as an analogy, 1.49 and 1.51 are very close
together, but one rounds to 1 and the other to 2.) Grid snap will hide
floating point inaccuracy, until the floating point inaccuracy causes
two points that really should match up to snap to different grid points.
> each other.
Doug Moen
Sun, Sep 5, 2021 5:31 PM
Grid snap is not a perfect solution. One of the problems is that it can perturb the mesh and introduce self-intersections, which can cause CGAL (union, etc) to fail.
I'm pretty sure the imprecision with floating point numbers is irrelevant, because OpenSCAD merges points that are within ~0.00003 of each other.
I don't know the details of the grid snap algorithm, but it doesn't seem like it can solve all of the problems.
Say that you have two points that are close enough that they would snap together. Now add a third, along the same line, at the same distance. Do all three snap together? Add a fourth, et cetera. Eventually it needs to break the chain, snapping one set one way and another set the other way. If the algorithm is an obvious rounding algorithm, even the original pair might snap apart if they span a rounding boundary. (Using conventional rounding as an analogy, 1.49 and 1.51 are very close together, but one rounds to 1 and the other to 2.) Grid snap will hide floating point inaccuracy, until the floating point inaccuracy causes two points that really should match up to snap to different grid points.
