To get rid of warnings I changed my assigns to assignment inside braces but
it doesn't work if the braces are otherwise redundant. I.e. braces don't
create a new scope, only control statements like if and for. Surely this is
wrong?
module test() {
assign(x = 0) echo(x);
assign(x = 1) echo(x);
test();
module test2() {
{ x = 0; echo(x); }
{ x = 1; echo(x); }
test2();
module test3() {
if(1){ x = 0; echo(x); }
if(1){ x = 1; echo(x); }
test3();
DEPRECATED: The assign() module will be removed in future releases. Use a
regular assignment instead.
ECHO: 0
ECHO: 1
ECHO: 1 <==== should be 0
ECHO: 1
ECHO: 0
ECHO: 1
My workaround is to use for in place of assign. It seems to be an exact
replacement when the values is a scalar.
but it doesn't work if the braces are otherwise redundant. I.e. braces
don't create a new scope, only control statements like if and for. Surely
this is wrong?
module test() {
test();
module test2() {
{ x = 0; echo(x); }
{ x = 1; echo(x); }
test2();
module test3() {
test3();
ECHO: 0
ECHO: 1
ECHO: 1
ECHO: 0
ECHO: 1
inside braces but it doesn't work if the braces are otherwise
redundant. I.e. braces don't create a new scope, only control
statements like if and for. Surely this is wrong?
I think the key is "backward compatibility". It was used in
scripts before to group variables. Introducing a new scope
now, would break all those scripts.
I guess otherwise it would indeed be the preferred way to
create a new scope.
This is mentioned in the manual as "anonymous scopes"
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/General#Scope_of_variables
I discovered this earlier in the year. I agree it's a bug. OpenSCAD copies
it's syntax from the C-like family of languages, and in those languages,
{..} introduces a new scope. But some people discovered the bug, started
treating it as a feature (for grouping variables). And now the wiki
documents this as a feature.
Nop Head mentions that for(x=1,y=2) {...} is a substitute for introducing a
scope. I think this is another bug: we should report an error if you try to
iterate over something that is not a list or range.
So are we now going to update the wiki, recommending that people replace
assign(x=1,y=2){...} with for(x=1,y=2){...}? Yuck.
If we are going down this path, then I request that we add a let statement,
consistent with the let expression, so that you can use let(x=1,y=2){...}
instead of abusing the for statement.
create a new scope.
Perhaps assign should not have been deprecated then as I now have to
replace them with for and there is no way of assigning a list.
create a new scope.
add a let statement, consistent with the let expression,
so that you can use let(x=1,y=2){...} instead of abusing
the for statement.
Good point. With having let() executing the assignments
sequentially, that would also prevent that nesting which
is needed for assign() if the variables are dependent.
This is included in the OpenSCAD2 proposal already, right?
It should be trivial to add to the existing version too.
The difference between 'assign' and 'let' is that 'let' supports
"sequential scoping", so you can write let(x=1,y=x*2).
I know that Marius is keen to support sequential scoping everywhere that it
makes sense, and I think that may be a motivation for deprecating assign.
create a new scope.
A bit premature then to deprecate it before adding let.
it makes sense, and I think that may be a motivation for deprecating assign.
create a new scope.
let statement, consistent with the let expression, so that you
can use let(x=1,y=2){...} instead of abusing the for statement.
There it is https://github.com/openscad/openscad/pull/1549
To confirm/clarify:
The anonymous scopes was a design mistake in early OpenSCAD, where scopes didn’t have a function.
I don’t know how often people use that feature to group variables, so I haven’t dared changing that yet, but I do agree that ideally this should be a true scope.
Deprecating assert() was indeed a bit premature, but it functions well as a way of telling people to avoid using it.
The parallel assignment behavior was an extra motivator to deprecate it. Adding let() makes sense to me and that would also be another baby step towards OpenSCAD2 :)
