There's a glitch with my dimensions...
G
gounthar
Wed, Jul 24, 2019 12:20 PM
Hi there,
I'm a total beginner with OpenSCAD, and a novice regarding CAD.
I used to work with a pencil and a piece of paper, and it was during the
last century...
Anyway, I spent some time with onShape and produced  this
https://github.com/gounthar/MerryKombo/blob/CAD/Box%20Base%20With%20Raspi%20Before%20Router%20Addition%20Drawing%201.pdf
I'd like to do the same kind of thing with OpenSCAD, so I started with a
small part of this design, the lens support.
Here is my source file:
https://github.com/gounthar/MerryKombo/blob/CAD/camera-support.scad
https://github.com/gounthar/MerryKombo/blob/CAD/camera-support.scad  .
I should maybe have started with the center and used mirror(), but anyway,
it is what it is.
The problem I have is that I was expecting the pillars to be 3.6mm high, but
they're not, something around 2mm high (see  there
https://github.com/gounthar/MerryKombo/blob/CAD/camera-support.png  ).
I must have missed something essential with OpenSCAD, because it can't be a
bug, it has to be a huge misunderstanding on my side.
So... what did I do wrong?
Thanks in advance,
Bruno
Hi there, I'm a total beginner with OpenSCAD, and a novice regarding CAD. I used to work with a pencil and a piece of paper, and it was during the last century... Anyway, I spent some time with onShape and produced this <https://github.com/gounthar/MerryKombo/blob/CAD/Box%20Base%20With%20Raspi%20Before%20Router%20Addition%20Drawing%201.pdf> . I'd like to do the same kind of thing with OpenSCAD, so I started with a small part of this design, the lens support. Here is my source file: https://github.com/gounthar/MerryKombo/blob/CAD/camera-support.scad <https://github.com/gounthar/MerryKombo/blob/CAD/camera-support.scad> . I should maybe have started with the center and used mirror(), but anyway, it is what it is. The problem I have is that I was expecting the pillars to be 3.6mm high, but they're not, something around 2mm high (see there <https://github.com/gounthar/MerryKombo/blob/CAD/camera-support.png> ). I must have missed something essential with OpenSCAD, because it can't be a bug, it has to be a huge misunderstanding on my side. So... what did I do wrong? Thanks in advance, Bruno -- Sent from: http://forum.openscad.org/
Wed, Jul 24, 2019 12:40 PM
I think it is because you have centered the cylinder, so only half is below
the origin and the other half embedded in the block.
On Wed, 24 Jul 2019 at 13:21, gounthar gounthar@gmail.com wrote:
Hi there,
last century...
it is what it is.
but
Thanks in advance,
Bruno
I think it is because you have centered the cylinder, so only half is below the origin and the other half embedded in the block. On Wed, 24 Jul 2019 at 13:21, gounthar <gounthar@gmail.com> wrote: > Hi there, > > I'm a total beginner with OpenSCAD, and a novice regarding CAD. > I used to work with a pencil and a piece of paper, and it was during the > last century... > Anyway, I spent some time with onShape and produced this > < > https://github.com/gounthar/MerryKombo/blob/CAD/Box%20Base%20With%20Raspi%20Before%20Router%20Addition%20Drawing%201.pdf> > > . > I'd like to do the same kind of thing with OpenSCAD, so I started with a > small part of this design, the lens support. > Here is my source file: > https://github.com/gounthar/MerryKombo/blob/CAD/camera-support.scad > <https://github.com/gounthar/MerryKombo/blob/CAD/camera-support.scad> . > I should maybe have started with the center and used mirror(), but anyway, > it is what it is. > > The problem I have is that I was expecting the pillars to be 3.6mm high, > but > they're not, something around 2mm high (see there > <https://github.com/gounthar/MerryKombo/blob/CAD/camera-support.png> ). > > I must have missed something essential with OpenSCAD, because it can't be a > bug, it has to be a huge misunderstanding on my side. > > So... what did I do wrong? > > Thanks in advance, > > Bruno > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
VB
Verachten Bruno
Wed, Jul 24, 2019 12:47 PM
Thanks for the tip, I will change it and see what happens.
Hi there,
last century...
it is what it is.
but
a
Thanks in advance,
Bruno
Bruno Verachten
Thanks for the tip, I will change it and see what happens. On Wed, Jul 24, 2019 at 2:41 PM nop head <nop.head@gmail.com> wrote: > I think it is because you have centered the cylinder, so only half is > below the origin and the other half embedded in the block. > > On Wed, 24 Jul 2019 at 13:21, gounthar <gounthar@gmail.com> wrote: > >> Hi there, >> >> I'm a total beginner with OpenSCAD, and a novice regarding CAD. >> I used to work with a pencil and a piece of paper, and it was during the >> last century... >> Anyway, I spent some time with onShape and produced this >> < >> https://github.com/gounthar/MerryKombo/blob/CAD/Box%20Base%20With%20Raspi%20Before%20Router%20Addition%20Drawing%201.pdf> >> >> . >> I'd like to do the same kind of thing with OpenSCAD, so I started with a >> small part of this design, the lens support. >> Here is my source file: >> https://github.com/gounthar/MerryKombo/blob/CAD/camera-support.scad >> <https://github.com/gounthar/MerryKombo/blob/CAD/camera-support.scad> . >> I should maybe have started with the center and used mirror(), but anyway, >> it is what it is. >> >> The problem I have is that I was expecting the pillars to be 3.6mm high, >> but >> they're not, something around 2mm high (see there >> <https://github.com/gounthar/MerryKombo/blob/CAD/camera-support.png> ). >> >> I must have missed something essential with OpenSCAD, because it can't be >> a >> bug, it has to be a huge misunderstanding on my side. >> >> So... what did I do wrong? >> >> Thanks in advance, >> >> Bruno >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > -- Bruno Verachten
G
gounthar
Wed, Jul 24, 2019 12:55 PM
I changed the pillar module, and it now works:module pillar() {
translate([PANEL_THICKNESS,HOLE_CENTER_TO_SIDE,HOLE_CENTER_TO_SIDE])
rotate(a=90, v=[0,1,0]) cylinder(h=PILLAR_HEIGHT,r=PILLAR_RADIUS,
center=false, $fn=200);
rotate(a=90, v=[0,1,0]) cylinder(h=PILLAR_HEIGHT + 0.1,r=HOLE_RADIUS,
center=false, $fn=200);    }}
http://forum.openscad.org/file/t2607/Untitled.png
I changed the pillar module, and it now works:module pillar() { difference() { translate([PANEL_THICKNESS,HOLE_CENTER_TO_SIDE,HOLE_CENTER_TO_SIDE]) rotate(a=90, v=[0,1,0]) cylinder(h=PILLAR_HEIGHT,r=PILLAR_RADIUS, center=false, $fn=200); translate([PANEL_THICKNESS,HOLE_CENTER_TO_SIDE,HOLE_CENTER_TO_SIDE]) rotate(a=90, v=[0,1,0]) cylinder(h=PILLAR_HEIGHT + 0.1,r=HOLE_RADIUS, center=false, $fn=200); }} <http://forum.openscad.org/file/t2607/Untitled.png> -- Sent from: http://forum.openscad.org/
