WA
William Adams
Tue, Apr 16, 2019 3:44 PM
Has anyone come across this before?
https://www.floodeditor.com
I'm flabbergasted that it doesn't seem to have made more of a splash.
Tue, Apr 16, 2019 4:50 PM
Hadn't seen this one before. Looks nice, but it has the standard critical flaw of a visual programming system. Visual programming is nice for small projects, but becomes very unwieldy when you start adding complexity. The density of code/information of a visual language is necessarily far lower than a text language, due to connectors, block/window titles, etc.
There is a trap here, that seems to come up from time to time. Someone will look at text programming languages and say "This is cryptic and not self documenting! I don't know what the inputs or outputs are, without delving into arcane documentation! We can do better!" So they go and break everything down into small pieces that they can represent in small GUI windows where all the inputs and outputs are visually represented and obvious. You can hover over them to see pop-up windows explaining the them. Connections between parts are obvious. It's like making flow charts to document your program, but they actually run. The wonder of this visual paradigm is obvious with rather small demos that look gorgeous. But no complex demos. Because that's all that'll fit on the screen. Every bit of it takes up massive amounts of screen real-estate. If complex demos exist, you have to zoom out to illegibility, then scroll about, then zoom back in.
To specify the number 20, takes up 300x45 pixels, including the connector linking it to the next node. The actual number itself is about 15x15 pixels on the screen, including spacing around the digits. That is a density difference factor of 60 times. Let's not even get into nodes for add and subtract.
The other big flaw of visual programming is that it forces you to move between your keyboard and mouse constantly. Instead of continuous typing of code, you keep having to select and place new nodes, add connectors, etc. You have to target and select various buttons and pay a lot of attention to positioning your mouse on the screen. Pure text programming, on the other hand, can be done blindfolded. Or, at the least, with far less spatial attention required. With three keystrokes I can add 9*7. In a visual paradigm, I have to select and place three nodes. Something like 4 clicks, scrolling, and a drag per node. Then two more clicks and drags to connect the nodes.
Not to bash Flood, because it does look nice. But, like pretty much all visual languages, it just isn't very practical for anything non-trivial.
To specify the number `20`, takes up 300x45 pixels, including the connector linking it to the next node. The actual number itself is about 15x15 pixels on the screen, including spacing around the digits. That is a density difference factor of 60 times. Let's not even get into nodes for add and subtract.
The other big flaw of visual programming is that it forces you to move between your keyboard and mouse constantly. Instead of continuous typing of code, you keep having to select and place new nodes, add connectors, etc. You have to target and select various buttons and pay a lot of attention to positioning your mouse on the screen. Pure text programming, on the other hand, can be done blindfolded. Or, at the least, with far less spatial attention required. With three keystrokes I can add `9*7`. In a visual paradigm, I have to select and place three nodes. Something like 4 clicks, scrolling, and a drag per node. Then two more clicks and drags to connect the nodes.
- Revar
> https://www.floodeditor.com <https://www.floodeditor.com/>
> William
Doug Moen
Tue, Apr 16, 2019 5:02 PM
It looks very slick. I like that you can tweak any numeric literal using a slider and get dynamic feedback. Or click on the node for a solid and it is highlit.
The node based visual programming UI seems clumsy, and the set of shape types and shape operations is pretty limited. I don't think I could be productive using it, in its current state. I get that it isn't designed for me, but even for beginners, I think the UI could be better designed. It is marked "beta" of course.
I was thinking about providing the author with more detailed feedback, but the last code change was June 2015, and there's only one contributor, so it looks moribund.
I will still be pointing novices at TinkerCAD first, and OpenSCAD if they want to write programs.
> William
KT
Kevin Toppenberg
Tue, Apr 16, 2019 5:03 PM
I agree with what you have said. But it would also be cool if it had the
ability to use either the graphical mode OR a text mode. Some of the
graphics engines have this visual interface -- but one can also use
traditional programming methods.
Kevin
add and subtract.
the nodes.
Kevin
> add and subtract.
> the nodes.
> - Revar
> William
Doug Moen
Tue, Apr 16, 2019 5:16 PM
Flood has a "script" object where you can type in an expression.
It would be interesting to see a graphics editor that lets you view and edit the same program as either text or a flowchart. Has anybody used software that works this way? Links?
On Tue, Apr 16, 2019, at 1:04 PM, Kevin Toppenberg wrote:
I agree with what you have said. But it would also be cool if it had the ability to use either the graphical mode OR a text mode. Some of the graphics engines have this visual interface -- but one can also use traditional programming methods.
Kevin
> Kevin
>> - Revar
>>> William
>>> _______________________________________________
WA
William Adams
Tue, Apr 16, 2019 5:33 PM
Apparently the developer has been busy with a startup (higharc.com)
A 3rd view where you could hide everything except for designated numerical
inputs would work for me, and using the "script" objects allows one to hide
a lot of the complexity.
If I could just figure out how to do a difference, I'd be ready to start on
at least a small project.
Kevin
add and subtract.
the nodes.
> Kevin
> add and subtract.
> the nodes.
> - Revar
> William
Doug Moen
Tue, Apr 16, 2019 5:55 PM
According to the source code, SolidSubtract should be a difference, but it doesn't work for me.
A 3rd view where you could hide everything except for designated numerical inputs would work for me, and using the "script" objects allows one to hide a lot of the complexity.
If I could just figure out how to do a difference, I'd be ready to start on at least a small project.
__
Kevin
> William
>> __
>>> Kevin
>>>> - Revar
>>>>> William
Tue, Apr 16, 2019 6:12 PM
I have not actually used it myself, but ICEStudio works
that way (https://github.com/FPGAwars/icestudio) - which
is a visual editor for Verilog.
WA
William Adams
Tue, Apr 16, 2019 6:22 PM
Thanks! That was my interpretation as well, but I was stymied by it not
working either --- guess I'll have to raise an issue on github.
Kevin
add and subtract.
the nodes.
> William
> Kevin
> add and subtract.
> the nodes.
> - Revar
> William
WA
William Adams
Tue, Apr 16, 2019 6:27 PM
Arguably Illustrator is a visual tool for PostScript --- or Inkscape for
SVG.
There are some graphical tools for the various TeX related drawing tools
such as xasy for Asymptote and metagraf for METAPOST.
It's discussions like this which make me miss Display PostScript and Altsys
Virtuoso's custom PS fills and strokes.
I wish that Solvespace could be a visual editor for OpenSCAD files though.
SVG.
> ciao,
> Torsten.
