Re: [OpenSCAD] Discuss Digest, Vol 38, Issue 19
jim.klessig
Sat, Jan 20, 2018 6:25 PM
Charlie wrote"What I really need is a function that allows the input of randomly spaced 3Dpoints and produces a 3D mesh surface."
I don't think such a function is even theoretically possible. It doesn't have sufficient constraints.It might be possible if you defined a subset of those points as a boundary edge, and constrained the surface to be limited in,some other fashion.
As an example if your random point cloud is defined as the corners of a cube, there are i think 18 different open non self intersecting surfaces that could be formed, at least 3 self intersecting ones, and all possible combinations of those. There is one closed surface ( the cube) and its combinations with the self intersecting surfaces.
Sent from my U.S. Cellular® Smartphone
-------- Original message --------From: discuss-request@lists.openscad.org Date: 1/20/18  9:00 AM  (GMT-08:00) To: discuss@lists.openscad.org Subject: Discuss Digest, Vol 38, Issue 19
Send Discuss mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
discuss-owner@lists.openscad.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Discuss digest..."
Today's Topics:
   1. Re: Head light bezel (cbernhardt)
   2. Re: F5 works, but F6 gives: ERROR: CGAL error in
      CGAL_Nef_polyhedron3(): (Parkinbot)
   3. Re: F5 works, but F6 gives: ERROR: CGAL error in
      CGAL_Nef_polyhedron3(): (Chris Camacho)
   4. Re: F5 works, but F6 gives: ERROR: CGAL error in
      CGAL_Nef_polyhedron3(): (Ronaldo Persiano)
Message: 1
Date: Fri, 19 Jan 2018 13:38:36 -0700 (MST)
Subject: Re: [OpenSCAD] Head light bezel
Message-ID: 1516394316092-0.post@n5.nabble.com
Content-Type: text/plain; charset=us-ascii
algotruneman wrote
Something beginning like this?
I used your suggestion and got close (see attached picture).
points and produces a 3D mesh surface.  Is there such a function?
Thanks,
Charles
http://forum.openscad.org/file/t1309/beze2.jpg
Message: 2
Date: Fri, 19 Jan 2018 14:00:15 -0700 (MST)
Subject: Re: [OpenSCAD] F5 works, but F6 gives: ERROR: CGAL error in
Message-ID: 1516395615471-0.post@n5.nabble.com
Content-Type: text/plain; charset=UTF-8
JordanBrown wrote
I don't use polyhedra very much.? My top-level comment was that generating
STL files that don't follow the rules is rude.
If you buy a product or pay a lot money for the licence, the word "rude"
might apply ...
And a side comment that by a common-sense definition, a list of points
that's not coplanar is not a polyhedron face.
If you want constructive help it is a good idea to show some code that
misbehaves and - again - to test it with the latest development snapshot
first.
Message: 3
Date: Fri, 19 Jan 2018 21:05:56 +0000
Message-ID: 5021efab-04b0-b9bf-5dde-b6f2890194d8@bedroomcoders.co.uk
Content-Type: text/plain; charset=utf-8; format=flowed
might apply ...
On the contrary if its free (as in beer) and open source then it would
be "rude" to make some inappropriate output to a STL file, if not at
least because you're sure gonna get called out on it... in public... so
better to do it right....
Message: 4
Date: Fri, 19 Jan 2018 21:13:38 -0200
Message-ID:
CA+i9EaBiRqTp2iGCK6PKVG3pav38hRTyiW4LeRLB+e5aHcWghg@mail.gmail.com
Content-Type: text/plain; charset="utf-8"
2018-01-19 3:52 GMT-02:00 Jordan Brown openscad@jordan.maileater.net:
?Most non-trivial sets of more than 3 points are not planar ?due to
floating point approximations. And some measure is necessary to cope with
the different number representations of OpenSCAD and CGAL. As far as I
know, OpenSCAD triangulates every polyhedron facet with more that 3
vertices precisely to avoid non-planarity issues. It can be argued that its
triangulation is not "optimal" in some sense but we cannot blame it for
doing this.
Polyhedron is a very flexible primitive. It is possible to define a
non-manifold and/or singular surfaces even with borders or multiple shells
with polyhedron. If degenerated faces are avoided, you can render it
nevertheless while no boolean operations is performed. That may be a hell
or a heaven depending on what you are doing or want to do.
What Uwe's workaround brought up is that the hull operator may "heal"
(most) defective polyhedron generating a valid solid with a manifold shell:
the convex hull of the polyhedron face vertices. That is nice, because
mathematically the hull operation does not require any structure linking
the points.
I don't think there is anything wrong with the current processing of
polyhedron. But...
Consider the following:
e = 5;
p = [ [0,0,   0],[10, 0,   0],[0,10,  0],[0,0,  10],
      [0,0,10+e],[10,10,10+e],[0,10,0+e],[10,0,0+e] ];
faces1 = [[0,1,2],
          [0,2,3],
          [0,3,1],
          [1,3,2]];
faces2 = [[4,6,5],
          [4,5,7],
          [4,7,6],
          [5,6,7]];
polyhedron(p, concat(faces1,faces2));
This polyhedron is really the union of a pair of tetrahedra provided that
the parameter e is positive. It can be boolean operated with another
primitive and renders fine. However, when I set the parameter e to 1e-6 and
union it with a cube, my 01.06 version running on Windows crashes. Worst
than that, setting e to 1e-5 I am able to render it unioned with a cube and
generate a STL file. Although the file is not defective (it represents
exactly the two tetrahedra with a small gap of about 1e-05) OpenSCAD
crashes when I try to import it.
Summarizing, my points are:
a) it is fine to define polyhedra that cannot be boolean operated because
they are not manifold;
b) it is fine that those polyhedra produce STL files that are not manifold
provided a warning is issued;
c) it is not fine that a STL file representing a manifold exported by
OpenSCAD cannot be imported by OpenSCAD.
Charlie wrote"What I really need is a function that allows the input of randomly spaced 3Dpoints and produces a 3D mesh surface." I don't think such a function is even theoretically possible. It doesn't have sufficient constraints.It might be possible if you defined a subset of those points as a boundary edge, and constrained the surface to be limited in,some other fashion. As an example if your random point cloud is defined as the corners of a cube, there are i think 18 different open non self intersecting surfaces that could be formed, at least 3 self intersecting ones, and all possible combinations of those. There is one closed surface ( the cube) and its combinations with the self intersecting surfaces. Sent from my U.S. Cellular® Smartphone -------- Original message --------From: discuss-request@lists.openscad.org Date: 1/20/18 9:00 AM (GMT-08:00) To: discuss@lists.openscad.org Subject: Discuss Digest, Vol 38, Issue 19 Send Discuss mailing list submissions to discuss@lists.openscad.org To subscribe or unsubscribe via the World Wide Web, visit http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org or, via email, send a message with subject or body 'help' to discuss-request@lists.openscad.org You can reach the person managing the list at discuss-owner@lists.openscad.org When replying, please edit your Subject line so it is more specific than "Re: Contents of Discuss digest..." Today's Topics:    1. Re: Head light bezel (cbernhardt)    2. Re: F5 works, but F6 gives: ERROR: CGAL error in       CGAL_Nef_polyhedron3(): (Parkinbot)    3. Re: F5 works, but F6 gives: ERROR: CGAL error in       CGAL_Nef_polyhedron3(): (Chris Camacho)    4. Re: F5 works, but F6 gives: ERROR: CGAL error in       CGAL_Nef_polyhedron3(): (Ronaldo Persiano) ---------------------------------------------------------------------- Message: 1 Date: Fri, 19 Jan 2018 13:38:36 -0700 (MST) From: cbernhardt <charlie@carols62.com> To: discuss@lists.openscad.org Subject: Re: [OpenSCAD] Head light bezel Message-ID: <1516394316092-0.post@n5.nabble.com> Content-Type: text/plain; charset=us-ascii algotruneman wrote > Something beginning like this? I used your suggestion and got close (see attached picture). What I really need is a function that allows the input of randomly spaced 3D points and produces a 3D mesh surface.  Is there such a function? Thanks, Charles <http://forum.openscad.org/file/t1309/beze2.jpg> -- Sent from: http://forum.openscad.org/ ------------------------------ Message: 2 Date: Fri, 19 Jan 2018 14:00:15 -0700 (MST) From: Parkinbot <rudolf@parkinbot.com> To: discuss@lists.openscad.org Subject: Re: [OpenSCAD] F5 works, but F6 gives: ERROR: CGAL error in CGAL_Nef_polyhedron3(): Message-ID: <1516395615471-0.post@n5.nabble.com> Content-Type: text/plain; charset=UTF-8 JordanBrown wrote > I don't use polyhedra very much.? My top-level comment was that generating > STL files that don't follow the rules is rude. If you buy a product or pay a lot money for the licence, the word "rude" might apply ... > And a side comment that by a common-sense definition, a list of points > that's not coplanar is not a polyhedron face. If you want constructive help it is a good idea to show some code that misbehaves and - again - to test it with the latest development snapshot first. -- Sent from: http://forum.openscad.org/ ------------------------------ Message: 3 Date: Fri, 19 Jan 2018 21:05:56 +0000 From: Chris Camacho <chris@bedroomcoders.co.uk> To: discuss@lists.openscad.org Subject: Re: [OpenSCAD] F5 works, but F6 gives: ERROR: CGAL error in CGAL_Nef_polyhedron3(): Message-ID: <5021efab-04b0-b9bf-5dde-b6f2890194d8@bedroomcoders.co.uk> Content-Type: text/plain; charset=utf-8; format=flowed On 19/01/18 21:00, Parkinbot wrote: > If you buy a product or pay a lot money for the licence, the word "rude" > might apply ... On the contrary if its free (as in beer) and open source then it would be "rude" to make some inappropriate output to a STL file, if not at least because you're sure gonna get called out on it... in public... so better to do it right.... ------------------------------ Message: 4 Date: Fri, 19 Jan 2018 21:13:38 -0200 From: Ronaldo Persiano <rcmpersiano@gmail.com> To: OpenSCAD general discussion <discuss@lists.openscad.org> Subject: Re: [OpenSCAD] F5 works, but F6 gives: ERROR: CGAL error in CGAL_Nef_polyhedron3(): Message-ID: <CA+i9EaBiRqTp2iGCK6PKVG3pav38hRTyiW4LeRLB+e5aHcWghg@mail.gmail.com> Content-Type: text/plain; charset="utf-8" 2018-01-19 3:52 GMT-02:00 Jordan Brown <openscad@jordan.maileater.net>: > And a side comment that by a common-sense definition, a list of points > that's not coplanar is not a polyhedron face. > ?Most non-trivial sets of more than 3 points are not planar ?due to floating point approximations. And some measure is necessary to cope with the different number representations of OpenSCAD and CGAL. As far as I know, OpenSCAD triangulates every polyhedron facet with more that 3 vertices precisely to avoid non-planarity issues. It can be argued that its triangulation is not "optimal" in some sense but we cannot blame it for doing this. Polyhedron is a very flexible primitive. It is possible to define a non-manifold and/or singular surfaces even with borders or multiple shells with polyhedron. If degenerated faces are avoided, you can render it nevertheless while no boolean operations is performed. That may be a hell or a heaven depending on what you are doing or want to do. What Uwe's workaround brought up is that the hull operator may "heal" (most) defective polyhedron generating a valid solid with a manifold shell: the convex hull of the polyhedron face vertices. That is nice, because mathematically the hull operation does not require any structure linking the points. I don't think there is anything wrong with the current processing of polyhedron. But... Consider the following: e = 5; p = [ [0,0,   0],[10, 0,   0],[0,10,  0],[0,0,  10],       [0,0,10+e],[10,10,10+e],[0,10,0+e],[10,0,0+e] ]; faces1 = [[0,1,2],           [0,2,3],           [0,3,1],           [1,3,2]]; faces2 = [[4,6,5],           [4,5,7],           [4,7,6],           [5,6,7]]; polyhedron(p, concat(faces1,faces2)); This polyhedron is really the union of a pair of tetrahedra provided that the parameter e is positive. It can be boolean operated with another primitive and renders fine. However, when I set the parameter e to 1e-6 and union it with a cube, my 01.06 version running on Windows crashes. Worst than that, setting e to 1e-5 I am able to render it unioned with a cube and generate a STL file. Although the file is not defective (it represents exactly the two tetrahedra with a small gap of about 1e-05) OpenSCAD crashes when I try to import it. Summarizing, my points are: a) it is fine to define polyhedra that cannot be boolean operated because they are not manifold; b) it is fine that those polyhedra produce STL files that are not manifold provided a warning is issued; c) it is not fine that a STL file representing a manifold exported by OpenSCAD cannot be imported by OpenSCAD.
C
cbernhardt
Tue, Jan 23, 2018 2:16 AM
Actually it is possible, but probably not inside OpenSCAD.  Many years ago I
was in the land surveying business and I wrote a routine to take randomly
spaced 3D points and turn them into a topo (contour) map.  This was done
inside of AutoCAD.  I saved my headlight bezel as an STL file and imported
it into AutoCAD, then drew some 3D POINTS to represent the area I needed to
fill.  The program I wrote produces a TIN (Triangulated Irregular Network)
of the surface defined by the 3D points.  This particular TIN has 4315 3D
points.  I converted the TIN to an STL and added it to the OpenSCAD file.
See the area circled in red in the attached picture.
http://forum.openscad.org/file/t1309/tin_fillet.jpg
jim_klessig wrote > I don't think such a function is even theoretically possible. It doesn't > have sufficient constraints.It might be possible if you defined a subset > of those points as a boundary edge, and constrained the surface to be > limited in,some other fashion. > As an example if your random point cloud is defined as the corners of a > cube, there are i think 18 different open non self intersecting surfaces > that could be formed, at least 3 self intersecting ones, and all possible > combinations of those. There is one closed surface ( the cube) and its > combinations with the self intersecting surfaces. Actually it is possible, but probably not inside OpenSCAD. Many years ago I was in the land surveying business and I wrote a routine to take randomly spaced 3D points and turn them into a topo (contour) map. This was done inside of AutoCAD. I saved my headlight bezel as an STL file and imported it into AutoCAD, then drew some 3D POINTS to represent the area I needed to fill. The program I wrote produces a TIN (Triangulated Irregular Network) of the surface defined by the 3D points. This particular TIN has 4315 3D points. I converted the TIN to an STL and added it to the OpenSCAD file. See the area circled in red in the attached picture. <http://forum.openscad.org/file/t1309/tin_fillet.jpg> -- Sent from: http://forum.openscad.org/
