S
stressless
Tue, Dec 6, 2016 11:26 AM
I sliced up a few of my parts (just to see) and noticed that they are full of
voids decided at printing time (slicer) or when exporting to STL. The
position of these voids are not visible in Openscad.
I now need to make a simple circular part that I will have to drill radially
and tap to receive an M3 screw. How do I know that I will not be drilling
into a void ? In other terms, i there a way to insure that a certain portion
of the part will be voidless ? Can Openscad reveal these voids at design
time ?
Thanks in advance for any help.
View this message in context: http://forum.openscad.org/Newbie-How-to-design-a-part-without-voids-tp19488.html
time ?
Tue, Dec 6, 2016 11:55 AM
The voids are there because you (or someone/thing else) specified an
infill percentage < 100. I typically use 20% for most parts, because
they are strong enough at 20%, and because it uses less material and
prints more quickly.
As to drill and tap, I include holes in my designs where I need to tap.
The slicers allow you to specify how many "perimeters" to print
(external layers), so a small hole suddenly is surrounded with solid
material, even if the majority of the part only has 20% infill. I would
recommend designing your holes into your part.
time ?
Checked by AVG - www.avg.com
Version: 2016.0.7924 / Virus Database: 4664/13542 - Release Date: 12/06/16
> time ?
> No virus found in this message.
Tue, Dec 6, 2016 12:00 PM
of voids decided at printing time (slicer) or when exporting to STL. The
radially and tap to receive an M3 screw. How do I know that I will not be
drilling into a void ? In other terms, i there a way to insure that a
certain portion of the part will be voidless ? Can Openscad reveal these
voids at design time ?
When you say "my parts" do you mean things constructed by OpenSCAD code, or
.STL etc you import() into OpenSCAD?
In the former, you create the voids, in the latter they are there as
designed.
I think the answer is NO, not by default.
One option is to use projection(cut=true)
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/3D_to_2D_Projection
with a translate in an animation, it will let you see through the model in
slices
I'm not sure what you mean by "full of voids decided at printing time
(slicer) ".
View this message in context: http://forum.openscad.org/Newbie-How-to-design-a-part-without-voids-tp19488p19490.html
designed.
<https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/3D_to_2D_Projection>
slices
(slicer) ".
S
stressless
Tue, Dec 6, 2016 5:56 PM
Thanks Jon. If the infill percentage is to be set on the printer, I cannot do
anything about it because I don't own a printer. I order my parts at a 3rd
party's. If it can be specified within Openscad, please instruct me.
As for the drill and tap, I will follow your advice and design holes into my
parts
Dan
full of
radially
portion
time ?
parts
Dan
> Jon
>> full of
>> radially
>> portion
>> time ?
> Discuss@.openscad
>> 12/06/16
> Discuss@.openscad
View this message in context: http://forum.openscad.org/Newbie-How-to-design-a-part-without-voids-tp19488p19491.html
S
stressless
Tue, Dec 6, 2016 6:18 PM
Thanks MichaelAtOz,
I actually cut up real printed parts that were designed with Openscad to see
what was "inside". And no, I did not design these voids. When I say "voids",
I mean empty spaces within the parts where no material was deposited. This
probably has to do with the infill factor mentioned by Jon (above message).
When I design parts in Openscad, I just see a solid fully filled piece
(unless I difference() ). When I receive the part from my 3rd party printer,
the part has a large number of non-designed voids in between the outer
walls. That's fine with me because the part is strong enough but it's a
bother if, in my case, I need to drill and tap a hole.
I just wanted to know if it is possible to see and control the number and
position of these voids at design time. They come as a surprise when I
receive the part from my remote printer.
Sorry for not being clear in my first message.
View this message in context: http://forum.openscad.org/Newbie-How-to-design-a-part-without-voids-tp19488p19492.html
Thanks MichaelAtOz,
AC
Alan Cox
Tue, Dec 6, 2016 6:29 PM
Thanks MichaelAtOz,
Talk to your printer. If there are voids in your product and not in your
STL then they are adding them (which is normal for a lot of 3D companies,
generally the right thing to do, but a disaster if you are are doing
anything structural).
Alan
On Tue, 6 Dec 2016 11:18:35 -0700 (MST)
stressless <wintoweb@gmail.com> wrote:
> Thanks MichaelAtOz,
Alan
Stefan Peter
Tue, Dec 6, 2016 6:52 PM
Hi Dan
What 3rd party especially? You may be able to supply a model describing
the general shape of your model and one describing the areas that need
to be filled 100%. It depends on the sclicer used by the 3rd party and
the effort they want to put into the job.
With kind regards
Stefan Peter
There is no system but GNU, and Linux is one of its kernels.
Hi Dan
With kind regards
Stefan Peter
Tue, Dec 6, 2016 6:55 PM
stressless,
It is usual to specify infill and perimeters values when you order a 3D
printing. If you don't they set them to standard values. Talk to them: 20%
is fine for non-structural parts, as jon wrote, and 3 to 4 perimeters is
enough if you will tap some part hole.
stressless,
JL
Joseph Lenox
Tue, Dec 6, 2016 7:23 PM
Slic3r's Modifier meshes will let you set the infill to 100% selectively,
fyi. I have a pull request open to generate those meshes on the fly and
position them in Slic3r.
--Joseph Lenox
On Tue, Dec 6, 2016 at 12:55 PM, Ronaldo Persiano rcmpersiano@gmail.com
--Joseph Lenox
On Tue, Dec 6, 2016 at 12:55 PM, Ronaldo Persiano <rcmpersiano@gmail.com>
> stressless,
S
stressless
Thu, Dec 8, 2016 5:49 PM
Thanks to all for your valuable replies.
I feel a bit smarter now and will put the advice to good use.
Regards,
Dan
View this message in context: http://forum.openscad.org/Newbie-How-to-design-a-part-without-voids-tp19488p19509.html
Regards,
Dan
