I made the following polyhedron:
p1 = [10,10,0];
p2 = [10,-10,0];
p3 = [-10,-10,0];
p4 = [-10,10,0];
p5 = [0,0,15];
polyhedron(points = [ p1, p2, p3, p4, p5], faces = [ [0,1,4], [1,2,4],
[2,3,4], [3,0,4], [0,1,2,3] ]);
Is there a way that we can know if the above object when printed, will be
hollow or filled?
If it is hollow, how to fill it?
Is cube(10) hollow or solid?
Thanks
View this message in context: http://forum.openscad.org/Hollow-or-solid-model-tp14175.html
Von: sukrit_gupta sukritgg@gmail.com
hollow or filled? If it is hollow, how to fill it?
From the model perspective it's solid. How it's actually printed will be up
to the CAM software (e.g. cura or slic3r for 3D printing).
like Paul Torsten said, the model is solid.
We have a MakerBot at the library, where I print stuff.
There is a parameter called infill that has a percentage number. The higher
the number the denser the object will be.
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
I
Anonymous
excellent code requires no comments at all!- Ken Thompson
To quote from OpenSCAD.org, "OpenSCAD is a software for creating solid 3D
CAD objects. "
Polyhedron and cube create solid objects.
p1 = [10,10,0];
p2 = [10,-10,0];
p3 = [-10,-10,0];
p4 = [-10,10,0];
p5 = [0,0,15];
hollow or filled?
Thanks
