MB
Max Bond
Tue, Dec 10, 2019 6:40 PM
I was wondering if I could get some guidance. I'm writing a model with a
recursive module, and I want to operate on the children with some
transformations. However, whenever I try to operate on the children, they
fail to render.
Here is a simplified test case:
module test(d=5) {
if(d>0) {
test(d-1)
circle();
test();
Commenting out the union causes the circles to render. While the union does
nothing here, the same goes for things like rotate that I rather need.
I'm using 2019.05.
Thanks,
Max
fail to render.
module test(d=5) {
if(d>0) {
test(d-1)
circle();
test();
I'm using 2019.05.
Thanks,
Max
Tue, Dec 10, 2019 6:48 PM
I think you need else children(); after the if or the result will be
nothing.
fail to render.
module test(d=5) {
if(d>0) {
test(d-1)
circle();
test();
does nothing here, the same goes for things like rotate that I rather need.
I'm using 2019.05.
Thanks,
Max
nothing.
On Tue, 10 Dec 2019 at 18:40, Max Bond <max.o.bond@gmail.com> wrote:
> Hi,
> fail to render.
> module test(d=5) {
> if(d>0) {
> test(d-1)
> union() {
> circle();
> children();
> test();
> I'm using 2019.05.
> Thanks,
> Max
MB
Max Bond
Tue, Dec 10, 2019 6:52 PM
D'oh! You're right.
Thanks!
nothing.
fail to render.
module test(d=5) {
if(d>0) {
test(d-1)
circle();
test();
I'm using 2019.05.
Thanks,
Max
D'oh! You're right.
Thanks!
> nothing.
>> Hi,
>> fail to render.
>> module test(d=5) {
>> if(d>0) {
>> test(d-1)
>> union() {
>> circle();
>> children();
>> test();
>> I'm using 2019.05.
>> Thanks,
>> Max
AC
A. Craig West
Tue, Dec 10, 2019 6:56 PM
Not sure why that is necessary, particularly since children() is empty...
On Tue, Dec 10, 2019 at 1:49 PM nop head nop.head@gmail.com wrote:
I think you need else children(); after the if or the result will be nothing.
I was wondering if I could get some guidance. I'm writing a model with a recursive module, and I want to operate on the children with some transformations. However, whenever I try to operate on the children, they fail to render.
module test(d=5) {
if(d>0) {
test(d-1)
circle();
test();
Commenting out the union causes the circles to render. While the union does nothing here, the same goes for things like rotate that I rather need.
I'm using 2019.05.
Thanks,
Max
>> Hi,
>> module test(d=5) {
>> if(d>0) {
>> test(d-1)
>> union() {
>> circle();
>> children();
>> test();
>> I'm using 2019.05.
>> Thanks,
>> Max
AC
A. Craig West
Tue, Dec 10, 2019 6:57 PM
never mind, I missed the obvious...
module test(d=5) {
if(d>0) {
test(d-1)
circle();
test();
I'm using 2019.05.
Thanks,
Max
> >> Hi,
> >> module test(d=5) {
> >> if(d>0) {
> >> test(d-1)
> >> union() {
> >> circle();
> >> children();
> >> test();
> >> I'm using 2019.05.
> >> Thanks,
> >> Max
MB
Max Bond
Tue, Dec 10, 2019 7:00 PM
fail to render.
module test(d=5) {
if(d>0) {
test(d-1)
circle();
test();
need.
You and I both :)
> nothing.
> > >> Hi,
> fail to render.
> > >> module test(d=5) {
> > >> if(d>0) {
> > >> test(d-1)
> > >> union() {
> > >> circle();
> > >> children();
> > >> test();
> need.
> > >> I'm using 2019.05.
> > >> Thanks,
> > >> Max
