engelvleugel_v9mid.stl
http://forum.openscad.org/file/n19123/engelvleugel_v9mid.stl
engelvleugel_v9.stl
http://forum.openscad.org/file/n19123/engelvleugel_v9.stl
I tried a lot a different ways to substract two objects. But not one of them
seems to work.
The meshes are OK in meshlab.
What is wrong then?
http://forum.openscad.org/file/n19123/Naamloos.jpg
This is the code:
View this message in context: http://forum.openscad.org/Can-t-find-what-s-wrong-here-use-import-stl-and-difference-tp19123.html
http://forum.openscad.org/file/n19125/Johan4.png
View this message in context: http://forum.openscad.org/Can-t-find-what-s-wrong-here-use-import-stl-and-difference-tp19123p19125.html
Oh sorry. I could have seen that myself. Meshlab and Nettfab are not strict
enough.
I fixed it and that solves 50% of my problem
I make several parts of this thing with the sweep function. And each time
there are problems in combining them. So I did some test to find out the
cause.
Test 1: The object in its entirety
Output:
Test 2 The same object in two parts (overlapping 0.1mm)
Output:
Test 3: same as 2 but not overlapping
Output:
test 4: same as 3 but the second part is the beginning of another shape and
so another sweep
test 5: same as 4 but a larger part of the second sweep is added:
Code:
Output:
http://forum.openscad.org/file/n19140/Naamloos.jpg
http://forum.openscad.org/file/n19140/Naamloos2.jpg
Is the problem caused by the large amount of non-planar faces?
View this message in context: http://forum.openscad.org/Can-t-find-what-s-wrong-here-use-import-stl-and-difference-tp19123p19140.html
Is there a possibility to force sweep to make triangles?
View this message in context: http://forum.openscad.org/Can-t-find-what-s-wrong-here-use-import-stl-and-difference-tp19123p19141.html
You can go into sweep, but poking around in its knitting routine is not very
delightful. (I can say that, because I just went into it yesterday to allow
also for designs that need closing like toric stuff.)
Anyway, I doubt that it is the knitting. In 99% the cause of purple
triangles is self-intersection or non-simple polygons. So better have a look
at your polygons and the extrusion path they describe (i.e. how you
transform them from 2D to 3D).
For the rest: There is some possiblity that vertices get somehow too close
and the export/import via STL runs into numerical problems. We have seen
this kind of faults being discussed here many times. In this case, you could
try to scale your design up before export and down after import. But first
try, whether the difference works without an STL involved at all.
View this message in context: http://forum.openscad.org/Can-t-find-what-s-wrong-here-use-import-stl-and-difference-tp19123p19144.html
2016-11-16 11:38 GMT-02:00 Parkinbot rudolf@parkinbot.com:
very
Rudolf,
CGAL works with very strict testings. But it collapses vertices that are
equal or very very near. So, for things like a torus, I define the form as
a bi-dimensional matrix of points where the first column equals the last
one and the first line equal the last one. To define the vertex list of the
polyhedron I just flatten the matrix. This vertex list will have
repetitions. The face definitions ignores all that and just scan the quads.
So, a border quad in the extreme left of the matrix will refer to vertex
indices different from the extreme right quad of the same line but some of
those indexed vertices will have the same coordinates. This way, the vertex
definitions and the knitting of faces is much more simple even in more
complex cases.
Johan,
I have a simple polygon check function for planar polygons. If you need I
can provide the code.
@parkinbot
I can imagine that going into sweep is not easy
I have an object without purple triangels. See the last wireframe I put in
the message.
Of this part I am quite sure that it has non planar faces. I think all the
quads in the curved sides are non planar.
I am also quite sure that the vertices are not very close.
The distance between the layers is .2 mm.
The curved corner makes has a radius of 1.25 mm and steps of 5 degrees.
But I can try to scale the design by a factor 100 and see what happens.
@ronaldo
The function to check for non planar polygons is interesting to use, but the
question is what to do when the object has non planar polygons. I have one
now. Is there a way to prevent them?
View this message in context: http://forum.openscad.org/Can-t-find-what-s-wrong-here-use-import-stl-and-difference-tp19123p19148.html
My library contains functions to project non-planar polygons in a fitting
plane, check if they are simple polygons and triangulate them if you need.
2016-11-16 13:17 GMT-02:00 Johan Jonker johangjonker@zonnet.nl:
@ronaldo
If your polygons are not "too much non-planar", sweep should work fine.
Problems arise if the polygon are not simple.
I am very interested to try that!
View this message in context: http://forum.openscad.org/Can-t-find-what-s-wrong-here-use-import-stl-and-difference-tp19123p19152.html
