Hello,
so my previous question was stupid enough :D so i went into looking to
achieve the desired result directly by using the polyhedrons, and here's
the next dumb question:
if you activate the difference on line 36, everything vanishes :(
why?? (same for union BTW....)
l = 3;
dlu = 1.4;
dlo = 2.9;
w= 30;
h= 11.5;
uo = 9;
uxo = 25;
uxu = 27;
module einschubForm(untereBr,obereBr,absend,absanf,abshoehe,hoehe,breite)
obVerjBreite = (obereBr-untereBr)*abshoehe/hoehe+untereBr;
polyhedron(
points=[[-untereBr,0,0], [untereBr,0,0], [untereBr,breite,0],
[-untereBr,breite,0], //unteres Rechteck
[-obereBr,0,hoehe],[obereBr,0,hoehe],
[obVerjBreite,breite,abshoehe],[-obVerjBreite,breite,abshoehe] //oberes
Rechteck
,[-obVerjBreite,absanf,hoehe], [-obVerjBreite,absend, abshoehe],
[obVerjBreite,absend, abshoehe], [obVerjBreite,absanf,hoehe] //Absenkung
,[-untereBr,absanf,0], [-untereBr,absend, 0], [untereBr,absend, 0],
[untereBr,absanf,0]
faces=[
[0,3,2,1], //unten
[5,4,0,1], //stirn links
[1,2,6,10,11,5], //hinten
[2,3,7,6], //stirn rechts
[0,4,8,9,7,3], //vorne
[4,5,11,8], [8,11,10,9], [9,10,6,7] //oben
posx = 11.1;
posy = 0;
posz = 1.71;
translate([posx,posy,posz])
//difference()
einschubForm(dlu,dlo,uxu,uxo,uo,h,w);
color("blue") translate([1,1.5,1])scale(v = [1, .9, .8])
ciao
Bruno
http://bboett.free.fr
http://aikido.zorn.free.fr
The polyhedron is inside out, all faces have the points listed
in reverse order.
See: https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#Why_is_my_model_showing_up_with_F5_but_not_F6?
I did some experimenting with that, as long as it is consistent, openscad
does the right thing. Not sure if the two polyhedra need to be consistent
with each other though
in reverse order.
See:
ok! thanks!
heh, understood the doc inversely....
ciao
Bruno
Am Sa., 20. Juli 2019 um 17:48 Uhr schrieb Torsten Paul <Torsten.Paul@gmx.de
in reverse order.
See:
ciao
Bruno
openscad does the right thing. Not sure if the two polyhedra
need to be consistent with each other thoughÂ
The underlying library doing the CSG operations (libCGAL) might
randomly do the right thing. Relying on that may end in trouble
at any time with any changes of the environment (e.g. changing
to a different machine, using a different OpenSCAD build, or
maybe just because the OS is running for more than 6 days without
reboot).
The expected winding order of polyhedron faces is defined,
anything else may work but the result is in general completely
undefined. So my advice is to always use the winding documented
order.
The face normal defines the direction of void ("out of material"). In
case of an inverted polyhedron with normal pointing inside the volume,
the material is infinite in all directions except inside the polyhedron
volume. One should always make sure a polyhedron is properly defined.
