raycewest wrote
But only in one direction (down). I could do a hull of said object and a
linear extrusion of its projection onto the xy plane, but it would result
in unwanted space above the object (concave areas) being filled.
Thoughts?
There are possibly simpler and better way to do it but here you have a
starting point:
epsilon = 0.01;
// a test object
translate([30,0,0]) obj();
// its downward extension
extendown() translate([-10,0,0]) obj();
module extendown()
minkowski() {
mirror([0,0,1])
pillar() children();
// cylindrical envelope of children
minkowski(){
linear_extrude(height=epsilon)
projection() children();
module obj()
translate([0,0,5])
rotate([30,40,0])
{ cube(10);
translate([10,10,0]) cylinder(10,10);
translate([15,0,15]) cube(3);}
// a thin pillar on the origin with height equal to
// the highest point of children
module pillar()
translate([-epsilon/2,-epsilon/2,0])
rotate([-90,0,0])
projection() rotate([0,90,0])
hull()
projection() rotate([90,0,0])
// discard portions of children with negative z
mirror([0,1,0]) translate([-1/epsilon/epsilon/2,0,0])
square(1/epsilon/epsilon);
http://forum.openscad.org/file/n21756/extendown.png
View this message in context: http://forum.openscad.org/Hulling-a-projection-tp21748p21756.html
The module pillar() as previously defined does not work as expected when
children is above the xy plane. The following code corrects that.
module pillar()
rotate([-90,0,0])
hull(){
square(epsilon,center=true);
hull()
mirror([0,1,0])
View this message in context: http://forum.openscad.org/Hulling-a-projection-tp21748p21757.html
