I was wanting to use the projection function conditionally in a module but I
get an error, is there a way to do this? This is the code I have that gets
an error
module draw_circle(param1, param2, param3, flat="no") {
if (flat == "yes") {
projection()
draw shape code goes here
If I take out the if statement like so it does what I want
projection()
This works:
module draw_circle(param1, param2, param3, flat=false) {
module draw_shape() {
sphere(param1);
if (flat) {
projection()
draw_shape();
else
draw_shape();
I
an error
projection()
projection()
Great, thanks. That will require a little re-orgranization of my code
but it will be worth it to have the ability to do.
On 5/2/18, nop head nop.head@gmail.com wrote:
This works:
sphere(param1);
if (flat) {
projection()
draw_shape();
else
draw_shape();
but
I
gets
an error
projection()
projection()
Trevor Orr
FractOrr Computer Services
fractorr.com
541-490-5697
Or something like this should work:
module conditional_project(flat) {
projection() children();
} else {
But I would use a boolean rather than a string for "flat".
