CGAL errors when combining two correct STL's
CA
Wed, Jan 27, 2016 4:23 PM
On 27. jan. 2016 17:18, nop head wrote:
Yes you can't guaranteed an STL from another program is valid but can
guarantee to write valid ones and be able to read ones that are valid.
From what I said before it is clear this is not a sufficient requirement.
Anyway, I just shared some thoughts, you are of course free to ignore them.
http://arnholm.org
On 27. jan. 2016 17:18, nop head wrote: > Yes you can't guaranteed an STL from another program is valid but can > guarantee to write valid ones and be able to read ones that are valid. From what I said before it is clear this is not a sufficient requirement. Anyway, I just shared some thoughts, you are of course free to ignore them. Carsten Arnholm http://arnholm.org
JJ
Johan Jonker
Wed, Jan 27, 2016 4:37 PM
thanks for discussing my problem.
It is still not solved. I get the idea that I am doing things that openscad
is not suitable for?
Mayby good to explain what I am doing.
http://forum.openscad.org/file/n15940/mp.jpg
The picture shows the mouthpiece outside.
The mouthpiece is build in the following parts:
  • the tenon, the cylindrical part, in the pictures shown on the top
    • this is simply made by a stack of cylinders
  • the body, this is a cylinder for tenon to top of which the diameter is a
    complex function. So I made this using Nspline and sweep functions. This has
    to be quite accurate, so I use 40 steps for the Nspline and 120 for the
    circles.
    -- the flat part on the left picture is called the table. The last part of
    it is curved.
    I made several version of this one. The previous one was a separte object
    that I subtracted from the body.
    -- the curve top on the right pciture is called the beak.
    I made it from two cylinders that are substracted using the difference
    functions. Then rotated and then with the difference function cut from the
    body.
It works using F5 but takes quite long when I increase the accuracy.
It often refused to render using F6 giving all the known fault codes.
I can use correction using Meshlab but they don't work always.
So the question is: is Openscad the right tool to design this?
View this message in context: http://forum.openscad.org/CGAL-errors-when-combining-two-correct-STL-s-tp15909p15940.html
thanks for discussing my problem. It is still not solved. I get the idea that I am doing things that openscad is not suitable for? Mayby good to explain what I am doing. <http://forum.openscad.org/file/n15940/mp.jpg> The picture shows the mouthpiece outside. The mouthpiece is build in the following parts: - the tenon, the cylindrical part, in the pictures shown on the top - - this is simply made by a stack of cylinders - the body, this is a cylinder for tenon to top of which the diameter is a complex function. So I made this using Nspline and sweep functions. This has to be quite accurate, so I use 40 steps for the Nspline and 120 for the circles. -- the flat part on the left picture is called the table. The last part of it is curved. I made several version of this one. The previous one was a separte object that I subtracted from the body. -- the curve top on the right pciture is called the beak. I made it from two cylinders that are substracted using the difference functions. Then rotated and then with the difference function cut from the body. It works using F5 but takes quite long when I increase the accuracy. It often refused to render using F6 giving all the known fault codes. I can use correction using Meshlab but they don't work always. So the question is: is Openscad the right tool to design this? -- View this message in context: http://forum.openscad.org/CGAL-errors-when-combining-two-correct-STL-s-tp15909p15940.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Jan 27, 2016 4:48 PM
Have you considered creating these 3 parts as a single OpenSCAD
operation, rather than as 3 separate ones?  Is the issue that they each
take a long time to calculate, so you are trying to pre-compute some of
them to save time?  Perhaps we can help you optimize some of the code so
that re-calculating each one is more tolerable.
    circles.
    it is curved.
    body.
Checked by AVG - www.avg.com
Version: 2016.0.7357 / Virus Database: 4522/11495 - Release Date: 01/27/16
Have you considered creating these 3 parts as a single OpenSCAD operation, rather than as 3 separate ones? Is the issue that they each take a long time to calculate, so you are trying to pre-compute some of them to save time? Perhaps we can help you optimize some of the code so that re-calculating each one is more tolerable. Jon On 1/27/2016 11:37 AM, Johan Jonker wrote: > thanks for discussing my problem. > It is still not solved. I get the idea that I am doing things that openscad > is not suitable for? > > Mayby good to explain what I am doing. > <http://forum.openscad.org/file/n15940/mp.jpg> > > The picture shows the mouthpiece outside. > The mouthpiece is build in the following parts: > - the tenon, the cylindrical part, in the pictures shown on the top > - - this is simply made by a stack of cylinders > - the body, this is a cylinder for tenon to top of which the diameter is a > complex function. So I made this using Nspline and sweep functions. This has > to be quite accurate, so I use 40 steps for the Nspline and 120 for the > circles. > -- the flat part on the left picture is called the table. The last part of > it is curved. > I made several version of this one. The previous one was a separte object > that I subtracted from the body. > -- the curve top on the right pciture is called the beak. > I made it from two cylinders that are substracted using the difference > functions. Then rotated and then with the difference function cut from the > body. > > It works using F5 but takes quite long when I increase the accuracy. > It often refused to render using F6 giving all the known fault codes. > I can use correction using Meshlab but they don't work always. > > So the question is: is Openscad the right tool to design this? > > > > -- > View this message in context: http://forum.openscad.org/CGAL-errors-when-combining-two-correct-STL-s-tp15909p15940.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2016.0.7357 / Virus Database: 4522/11495 - Release Date: 01/27/16 > >
Wed, Jan 27, 2016 4:56 PM
It isn't a good tool for reading STL files. If you create all the geometry
in OpenScad and then write an STL it should be fine.
    has
    circles.
    it is curved.
    body.
It isn't a good tool for reading STL files. If you create all the geometry in OpenScad and then write an STL it should be fine. On 27 January 2016 at 16:37, Johan Jonker <johangjonker@zonnet.nl> wrote: > thanks for discussing my problem. > It is still not solved. I get the idea that I am doing things that openscad > is not suitable for? > > Mayby good to explain what I am doing. > <http://forum.openscad.org/file/n15940/mp.jpg> > > The picture shows the mouthpiece outside. > The mouthpiece is build in the following parts: > - the tenon, the cylindrical part, in the pictures shown on the top > - - this is simply made by a stack of cylinders > - the body, this is a cylinder for tenon to top of which the diameter is a > complex function. So I made this using Nspline and sweep functions. This > has > to be quite accurate, so I use 40 steps for the Nspline and 120 for the > circles. > -- the flat part on the left picture is called the table. The last part of > it is curved. > I made several version of this one. The previous one was a separte object > that I subtracted from the body. > -- the curve top on the right pciture is called the beak. > I made it from two cylinders that are substracted using the difference > functions. Then rotated and then with the difference function cut from the > body. > > It works using F5 but takes quite long when I increase the accuracy. > It often refused to render using F6 giving all the known fault codes. > I can use correction using Meshlab but they don't work always. > > So the question is: is Openscad the right tool to design this? > > > > -- > View this message in context: > http://forum.openscad.org/CGAL-errors-when-combining-two-correct-STL-s-tp15909p15940.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Wed, Jan 27, 2016 5:02 PM
I agree with this.
Also, we’ll eventually get this fixed, so the future will be brighter :)
I agree with this. Also, we’ll eventually get this fixed, so the future will be brighter :) -Marius > On Jan 27, 2016, at 11:56 AM, nop head <nop.head@gmail.com> wrote: > > It isn't a good tool for reading STL files. If you create all the geometry in OpenScad and then write an STL it should be fine. >
JJ
Johan Jonker
Wed, Jan 27, 2016 5:51 PM
I tried to do the outside in one STL. But that results in errors.
It would be great when you can help me. But it is quite complex.
Here are the main files. I suppose the libraries are known.
mp_parameters.scad
http://forum.openscad.org/file/n15945/mp_parameters.scad
mouthpiece_outside_v11.scad
http://forum.openscad.org/file/n15945/mouthpiece_outside_v11.scad
View this message in context: http://forum.openscad.org/CGAL-errors-when-combining-two-correct-STL-s-tp15909p15945.html
I tried to do the outside in one STL. But that results in errors. It would be great when you can help me. But it is quite complex. Here are the main files. I suppose the libraries are known. mp_parameters.scad <http://forum.openscad.org/file/n15945/mp_parameters.scad> mouthpiece_outside_v11.scad <http://forum.openscad.org/file/n15945/mouthpiece_outside_v11.scad> -- View this message in context: http://forum.openscad.org/CGAL-errors-when-combining-two-correct-STL-s-tp15909p15945.html Sent from the OpenSCAD mailing list archive at Nabble.com.
JJ
Johan Jonker
Wed, Jan 27, 2016 7:26 PM
In the program I tried to reduce calculation time by making the shapes that
are subtracted from the main body as small as possible. In an earlier
version the beak shape were two cylinders and I modified that into on
quarter of these. That appears to be a more complex function.
I put it back to the cylindrical version again. Now this part renders with
F6 and $fn=80.
http://forum.openscad.org/file/n15946/mp.jpg
Now I'll try to add the inside in the same scad.
View this message in context: http://forum.openscad.org/CGAL-errors-when-combining-two-correct-STL-s-tp15909p15946.html
In the program I tried to reduce calculation time by making the shapes that are subtracted from the main body as small as possible. In an earlier version the beak shape were two cylinders and I modified that into on quarter of these. That appears to be a more complex function. I put it back to the cylindrical version again. Now this part renders with F6 and $fn=80. <http://forum.openscad.org/file/n15946/mp.jpg> Now I'll try to add the inside in the same scad. -- View this message in context: http://forum.openscad.org/CGAL-errors-when-combining-two-correct-STL-s-tp15909p15946.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Rob Ward
Wed, Jan 27, 2016 8:00 PM
Isn't this a very good argument for the idea of an openSCAD format cache of objects, and the ability to programatically  load/save individuals shapes from a list of shapes? These two concepts have been discussed at length in other threads and deserve consideration as a valuable in house feature if not of universal use to the 3-D community as a whole? Or have I oversimplified it all?
On 28 January 2016 2:11:21 AM AEDT, Carsten Arnholm arnholm@arnholm.org wrote:
On 27. jan. 2016 14:23, nop head wrote:
It is a sad fact that OpenScad can't import a lot of the STLs it
makes
itself. I think it re-quantises vertices and they collapse. It also
doesn't detect invalid meshes until you do a CGAL operation on them.
Regardless of how OpenSCAD treats the STL files on import (it probably
could be improved), it shows that STL is the wrong format for
intermediate storage of parts when the intention is re-import for
assembly.
Why is it the wrong format? Because STL files do not contain any
topology at all, so when you import the STL for further use in boolean
operations, the topology must be guessed and reconstructed using unsafe
coordinate comparisons. It is inefficient and bound to fail in many
cases, and it does. By 'fail' I mean the reconstructed topology is not
exactly the same as the original.
A better solution for this purpose would probably be to store one or
more computed polyhedrons to a file (assuming one takes an approach
native to OpenSCAD). The idea would be to allow such polyhedron files
to
be re-imported as an alternative to STL. It would guarantee that the
imported object is the same as the exported object, it would be more
compact since each vertex is mentioned only once, and it would be
faster
to process because no vertex matching would have to be done. You could
think of it as ready made 'parts' files that needs to be imported into
openscad as in the original mouthpiece example, just using a different
format for intermediate storage.
If you don't want to introduce another format for this purpose, perhaps
AMF could serve the same purpose, although the present (2015.03-2)
implementation of AMF export does not seem to separate between
independent bodies. I just tested it with a model containing several
bodies and they were written to AMF as a single <object>. For AMF to
work as intermediate format the way I described, each <object> on AMF
would have to be a valid polyhedron. AMF is an XML format so you could
perhaps add a property to the object type to indicate it is indeed a
polyhedron:
<object id="0" type="polyhedron">
Just my thoughts.
Sent from my Android device with K-9 Mail. Please excuse my brevity.
Isn't this a very good argument for the idea of an openSCAD format cache of objects, and the ability to programatically load/save individuals shapes from a list of shapes? These two concepts have been discussed at length in other threads and deserve consideration as a valuable in house feature if not of universal use to the 3-D community as a whole? Or have I oversimplified it all? On 28 January 2016 2:11:21 AM AEDT, Carsten Arnholm <arnholm@arnholm.org> wrote: >On 27. jan. 2016 14:23, nop head wrote: >> It is a sad fact that OpenScad can't import a lot of the STLs it >makes >> itself. I think it re-quantises vertices and they collapse. It also >> doesn't detect invalid meshes until you do a CGAL operation on them. > >Regardless of how OpenSCAD treats the STL files on import (it probably >could be improved), it shows that STL is the wrong format for >intermediate storage of parts when the intention is re-import for >assembly. > >Why is it the wrong format? Because STL files do not contain any >topology at all, so when you import the STL for further use in boolean >operations, the topology must be guessed and reconstructed using unsafe > >coordinate comparisons. It is inefficient and bound to fail in many >cases, and it does. By 'fail' I mean the reconstructed topology is not >exactly the same as the original. > >A better solution for this purpose would probably be to store one or >more computed polyhedrons to a file (assuming one takes an approach >native to OpenSCAD). The idea would be to allow such polyhedron files >to >be re-imported as an alternative to STL. It would guarantee that the >imported object is the same as the exported object, it would be more >compact since each vertex is mentioned only once, and it would be >faster >to process because no vertex matching would have to be done. You could >think of it as ready made 'parts' files that needs to be imported into >openscad as in the original mouthpiece example, just using a different >format for intermediate storage. > >If you don't want to introduce another format for this purpose, perhaps > >AMF could serve the same purpose, although the present (2015.03-2) >implementation of AMF export does not seem to separate between >independent bodies. I just tested it with a model containing several >bodies and they were written to AMF as a single <object>. For AMF to >work as intermediate format the way I described, each <object> on AMF >would have to be a valid polyhedron. AMF is an XML format so you could >perhaps add a property to the object type to indicate it is indeed a >polyhedron: ><object id="0" type="polyhedron"> > >Just my thoughts. > >Carsten Arnholm > > > > > > > > > > > > >_______________________________________________ >OpenSCAD mailing list >Discuss@lists.openscad.org >http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- Sent from my Android device with K-9 Mail. Please excuse my brevity.
JJ
Johan Jonker
Wed, Jan 27, 2016 8:05 PM
Yes, rendered with f6 and $fn=120 in 3 minutes.
Thanks for helping me out.
Conclusion: better a simple structure than a smalll structure?
http://forum.openscad.org/file/n15949/mp.png
View this message in context: http://forum.openscad.org/CGAL-errors-when-combining-two-correct-STL-s-tp15909p15949.html
Yes, rendered with f6 and $fn=120 in 3 minutes. Thanks for helping me out. Conclusion: better a simple structure than a smalll structure? <http://forum.openscad.org/file/n15949/mp.png> -- View this message in context: http://forum.openscad.org/CGAL-errors-when-combining-two-correct-STL-s-tp15909p15949.html Sent from the OpenSCAD mailing list archive at Nabble.com.
