OpenSCAD - FAQ
Fri, Feb 6, 2015 7:51 PM
I'm not aware of an existing FAQ, so I've collected some of the latest
questions there:
https://github.com/openscad/openscad/wiki/Frequently-Asked-Questions
What other questions/answers should be added?
(In case it starts growing too big, I'll probably move it somewhere
in the Manual as Wikibooks can handle bigger pages a bit better)
I'm not aware of an existing FAQ, so I've collected some of the latest questions there: https://github.com/openscad/openscad/wiki/Frequently-Asked-Questions What other questions/answers should be added? (In case it starts growing too big, I'll probably move it somewhere in the Manual as Wikibooks can handle bigger pages a bit better) ciao, Torsten.
MD
Michele Denber
Fri, Feb 6, 2015 8:14 PM
How about "Why am I getting "no top level geometry to render"?"
On 02-06-2015 2:51 PM, Torsten Paul wrote: > > What other questions/answers should be added? > How about "Why am I getting "no top level geometry to render"?"
Fri, Feb 6, 2015 8:20 PM
Right, that's certainly a FAQ too. I guess the answer is basically the same as
https://github.com/openscad/openscad/wiki/Frequently-Asked-Questions#why-is-my-imported-stl-file-only-showing-up-with-f5-but-not-f6
And talking about errors, the line number problem is probably also worth to mention.
On 02/06/2015 09:14 PM, Michele Denber wrote: > How about "Why am I getting "no top level geometry to render"?" > Right, that's certainly a FAQ too. I guess the answer is basically the same as https://github.com/openscad/openscad/wiki/Frequently-Asked-Questions#why-is-my-imported-stl-file-only-showing-up-with-f5-but-not-f6 And talking about errors, the line number problem is probably also worth to mention. ciao, Torsten.
