Hello OpenSCAD,
is there a program that will "pretty" up a source listing by giving it a uniform appearance?
So all the indents are even for each level of indentation and the braces are paired off for easy visualation of grouping.
Thanks,
Bob Ros
Best regards,
Bob mailto:roosbob@wybatap.com
i wrote a program like that and promoted it to the list asking if there
is the ability to include such a external code formater into OpenScad.
Did not get any responce till now.
On 11/7/21 7:19 AM, Bob Roos wrote:
Hello OpenSCAD,
Thanks,
Bob Ros
Auf meiner Homepage www.Corpsman.de ist immer was los, ständig wird sie aktualisiert und erweitert. Da ist für jeden was dabei.
Schütze deine Privatsphäre, nutze E-mail Verschlüsselung.
Wie das geht steht z.B. hier :
https://support.mozilla.org/en-US/kb/digitally-signing-and-encrypting-messages#w_installing-gpg-and-enigmail
Hi corpsman,
Even if it were not incorporated into the program itself it would be useful to "spiff" up the code before it is opened in OpenSCAD itself.
I would be interested in having a copy if you would share it.
roos bob at wybatap dot com (remove spaces and adjust key words)
Bob Roos
Hello OpenSCAD,
Thanks,
Bob Ros
have Fun,
I too would appreciate such a tool.
I'm not a programmer but for my electronics hobby last year I got into Arduino.
(Because of its similarities that has made my more recent learning of OpenSCAD a
bit easier.) One tool built into Arduino is Auto Format; the hotkey <Ctrl+t>
applies the sort of changes Bob mentioned.
Terry
Hello OpenSCAD,
Thanks,
Bob Ros
At 50+ years of programming, formatting my code is a compulsion and I do it automatically.
For those of you who aren’t programmers, formatting code for READING is really important. You will read the code many more times than you will write it. Also, though you know what’s going on now, if you return to this code in 4 months you won’t remember everything so put in comments as if someone else was having to read and understand the code. You will be happy you did. “Now why did I add 4/3 of H there?”.
-Bob
Tucson AZ
Terry
Hello OpenSCAD,
Thanks,
Bob Ros
There is a tool that I have used for years to tidy code, mainly C, C++ and C#, and it works well.
You can define your own strategy for a language and I don't think OpenScad would pose any significant problems.
It's called "Uncrustify" and you can find it HERE.
Regards,
Dave
On 08/11/2021 17:03, Bob Carlson wrote:
<pre class="moz-quote-pre" wrap="">At 50+ years of programming, formatting my code is a compulsion and I do it automatically. For those of you who aren’t programmers, formatting code for READING is really important. You will read the code many more times than you will write it. Also, though you know what’s going on now, if you return to this code in 4 months you won’t remember everything so put in comments as if someone else was having to read and understand the code. You will be happy you did. “Now why did I add 4/3 of H there?”. -Bob Tucson AZ On Nov 8, 2021, at 02:36, Terry <a class="moz-txt-link-rfc2396E" href="mailto:terrypingm@gmail.com"><terrypingm@gmail.com></a> wrote: I too would appreciate such a tool. I'm not a programmer but for my electronics hobby last year I got into Arduino. (Because of its similarities that has made my more recent learning of OpenSCAD a bit easier.) One tool built into Arduino is Auto Format; the hotkey <Ctrl+t> applies the sort of changes Bob mentioned. Terry ==================== On Sun, 7 Nov 2021 08:59:33 +0100, you wrote:<pre class="moz-quote-pre" wrap="">i wrote a program like that and promoted it to the list asking if there is the ability to include such a external code formater into OpenScad. Did not get any responce till now. On 11/7/21 7:19 AM, Bob Roos wrote:<pre class="moz-quote-pre" wrap="">Hello OpenSCAD, is there a program that will "pretty" up a source listing by giving it a uniform appearance? So all the indents are even for each level of indentation and the braces are paired off for easy visualation of grouping. Thanks, Bob Ros<pre class="moz-quote-pre" wrap="">-- Auf meiner Homepage <a class="moz-txt-link-abbreviated" href="http://www.Corpsman.de">www.Corpsman.de</a> ist immer was los, ständig wird sie aktualisiert und erweitert. Da ist für jeden was dabei.<pre class="moz-quote-pre" wrap="">_______________________________________________ OpenSCAD mailing list To unsubscribe send an email to <a class="moz-txt-link-abbreviated" href="mailto:discuss-leave@lists.openscad.org">discuss-leave@lists.openscad.org</a> _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to <a class="moz-txt-link-abbreviated" href="mailto:discuss-leave@lists.openscad.org">discuss-leave@lists.openscad.org</a>
There is also a tool to help generate CFG for "uncrustify" and allows you to interactively see the effect you config has.
It's called "UniversalIndentGUI_win32" and you can find it HERE.
Regards,
Dave
Regards,
DaveOn 08/11/2021 17:03, Bob Carlson wrote:
<pre class="moz-quote-pre" wrap="">At 50+ years of programming, formatting my code is a compulsion and I do it automatically. For those of you who aren’t programmers, formatting code for READING is really important. You will read the code many more times than you will write it. Also, though you know what’s going on now, if you return to this code in 4 months you won’t remember everything so put in comments as if someone else was having to read and understand the code. You will be happy you did. “Now why did I add 4/3 of H there?”. -Bob Tucson AZ On Nov 8, 2021, at 02:36, Terry <a class="moz-txt-link-rfc2396E" href="mailto:terrypingm@gmail.com" moz-do-not-send="true"><terrypingm@gmail.com></a> wrote: I too would appreciate such a tool. I'm not a programmer but for my electronics hobby last year I got into Arduino. (Because of its similarities that has made my more recent learning of OpenSCAD a bit easier.) One tool built into Arduino is Auto Format; the hotkey <Ctrl+t> applies the sort of changes Bob mentioned. Terry ==================== On Sun, 7 Nov 2021 08:59:33 +0100, you wrote:<pre class="moz-quote-pre" wrap="">i wrote a program like that and promoted it to the list asking if there is the ability to include such a external code formater into OpenScad. Did not get any responce till now. On 11/7/21 7:19 AM, Bob Roos wrote:<pre class="moz-quote-pre" wrap="">Hello OpenSCAD, is there a program that will "pretty" up a source listing by giving it a uniform appearance? So all the indents are even for each level of indentation and the braces are paired off for easy visualation of grouping. Thanks, Bob Ros<pre class="moz-quote-pre" wrap="">-- Auf meiner Homepage <a class="moz-txt-link-abbreviated" href="http://www.Corpsman.de" moz-do-not-send="true">www.Corpsman.de</a> ist immer was los, ständig wird sie aktualisiert und erweitert. Da ist für jeden was dabei.<pre class="moz-quote-pre" wrap="">_______________________________________________ OpenSCAD mailing list To unsubscribe send an email to <a class="moz-txt-link-abbreviated" href="mailto:discuss-leave@lists.openscad.org" moz-do-not-send="true">discuss-leave@lists.openscad.org</a> _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to <a class="moz-txt-link-abbreviated" href="mailto:discuss-leave@lists.openscad.org" moz-do-not-send="true">discuss-leave@lists.openscad.org</a><pre class="moz-quote-pre" wrap="">_______________________________________________ OpenSCAD mailing list To unsubscribe send an email to <a class="moz-txt-link-abbreviated" href="mailto:discuss-leave@lists.openscad.org">discuss-leave@lists.openscad.org</a>
Amen! I'm often the victim of my own lack of comments. (Despite my
own 60 years of coding)
-Bob
Tucson AZ
Comments are a love letter to your future self.
it automatically.
-Bob
Tucson AZ
