Thanks to the discussion about intersection I added some checks and that
cause the top corners of the object to look much better. Thanks!!
http://forum.openscad.org/file/n17335/Naamloos.jpg
View this message in context: http://forum.openscad.org/getting-craxy-from-f5-f6-issues-tp17323p17335.html
Hello Johan
I have discussed the self intersecting stuff before here
http://forum.openscad.org/Splines-for-drawing-fan-blades-tp16784p17265.html
and you might be also interested in this thread
http://forum.openscad.org/Polygon-Offset-Function-tp17186.html , where I
also answer the number of points per polygon in a sweep question - if is not
feasable to you to use a common N, skin() will be your friend. Further have
a look into the simple polygon discussion.
Concering the trajectory, best always look at linear_extrude().
linear_extrude(height = 100, twist = 0)
square (10, center = true);
and
linear_extrude(height = 100, twist = 360)
and
square (10, center = false);
same shape, even same trajectories (the first two, the third one has
internally a translation), but different results.
No self intersection can happen on a linear_extrude, that's why it is in
language. But imagine the trajectory would be an 8, which can easily be done
with a sweep. Even if F6 will output it (falsely), boolean operations will
fail.
About the licensing: The rules are easy to respect.
If you wanna go commercial contact me and get a license for what you intend
to do.
If you publish your code using my library, refer to its origin.
Refrain from copying my library code partly into your own scad files, if not
forced by a bug in my code.
Use the same (or an even stronger) licensing model for your code, if it uses
mine.
View this message in context: http://forum.openscad.org/getting-craxy-from-f5-f6-issues-tp17323p17336.html
