Help! Rearranging areas
MV
Maurice van Peursem
Sat, Jun 5, 2021 8:29 PM
I've done 'something', and now OpenSCAD is unusable because all areas
are beneath eachother instead of the editor to the left and the model
and console to the right. How do I get back to the default setting,
and where is that documented in the manual? I couldn't find it in the
section on the user interface, where I think it should have been...
Maurice
Hi, I've done 'something', and now OpenSCAD is unusable because all areas are beneath eachother instead of the editor to the left and the model and console to the right. How do I get back to the default setting, and where is that documented in the manual? I couldn't find it in the section on the user interface, where I think it should have been... Maurice
MV
Maurice van Peursem
Sat, Jun 5, 2021 8:34 PM
OK, I've found it, you can grab the window-bar and then rearrange,
but I still think it should be documented in the user interface
section (if it isn't already). Sorry for my panic reaction.
Maurice
have been...
Maurice
OK, I've found it, you can grab the window-bar and then rearrange, but I still think it should be documented in the user interface section (if it isn't already). Sorry for my panic reaction. Maurice >Hi, > >I've done 'something', and now OpenSCAD is unusable because all >areas are beneath eachother instead of the editor to the left and >the model and console to the right. How do I get back to the default >setting, and where is that documented in the manual? I couldn't find >it in the section on the user interface, where I think it should >have been... > >Maurice >_______________________________________________ >OpenSCAD mailing list >To unsubscribe send an email to discuss-leave@lists.openscad.org
