Gene Heskett
Fri, Aug 6, 2021 1:47 AM
The preview window in the upper right corner has gotten extremely laggy,
like 4 or 5 seconds to update even a 10 pixel move. I shut it down after
making sure the work was saved, and restarted it, but the problem
remains. I just did a powerdown reboot, but that didn't fix it either.
The rest of it remains as quick as always.
Ideas to try, anybody?
Thanks.
Cheers, Gene Heskett
-Ed Howdershelt (Author)
Thanks.
- Louis D. Brandeis
FH
Father Horton
Fri, Aug 6, 2021 3:23 AM
If you have a complex model, especially with a lot of CSG or a high value
for $fn, this is what you'll see.
Thanks.
> Thanks.
> - Louis D. Brandeis
Gene Heskett
Fri, Aug 6, 2021 4:30 AM
value for $fn, this is what you'll see.
The model is getting complex as theres 10 major parts to print, and
around 15 modules declared. $fn varies from 3 to 720 depending on the
module. and in 2 modules its both. I keep thinking of ways to make it
more versatile. If I put in a switch to control the length of the input
armatures extended hub, I can also make is as a direct mount right on
the face of the motor, which should expand its usage to the small to
medium sized cnc machine user for slow but quite accurate angle setting.
I am reminded of a very old saying about a program that says the only way
a program is ever really finished, is when somebody shoots the
programmer. I think that was written in Dr. Dobb's Journal in about
1979? Discounting comments, this thing is around 500 active LOC now.
Its been fun but I should post it on my web page and see if you folks
can spot mistakes, cuz there has to be a bunch of them. Over the weekend
maybe. I'll post it and post about it here when its pullable.
Thanks Father Horton.
- Louis D. Brandeis
Fri, Aug 6, 2021 9:23 AM
In the development snapshots you can turn on vertex-object-renderers in
thePreferences / Features tab. That makes the preview very responsive even
with very complicated models.
> - Louis D. Brandeis
Gene Heskett
Fri, Aug 6, 2021 11:16 AM
in thePreferences / Features tab. That makes the preview very
responsive even with very complicated models.
Unfortunately:
gene@coyote:~/AppImages$ openscad (Is a softlink to 07.25 86_64 AppImage I just downloaded)
/tmp/.mount_opensc7wmGaY/AppRun.wrapped: /lib/x86_64-linux-gnu/libm.so.6: version GLIBC_2.27' not found (required by /tmp/.mount_opensc7wmGaY/usr/bin/../lib/libQt5Gui.so.5) /tmp/.mount_opensc7wmGaY/AppRun.wrapped: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.25' not found (required
by /tmp/.mount_opensc7wmGaY/usr/bin/../lib/libQt5Core.so.5)
/tmp/.mount_opensc7wmGaY/AppRun.wrapped: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.27' not found (required by /tmp/.mount_opensc7wmGaY/usr/bin/../lib/libpulsecommon-11.1.so) /tmp/.mount_opensc7wmGaY/AppRun.wrapped: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.25' not found (required
by /tmp/.mount_opensc7wmGaY/usr/bin/../lib/libsystemd.so.0)
/tmp/.mount_opensc7wmGaY/AppRun.wrapped: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.27' not found (required
And my stretch libc appears to be 02.24
So I'll move this to a buster install and try it. It runs but isn't any
faster with that first one enabled, AND it freezes this machine while
the new preview render is in progress, which is indeed odd, about 10
secs or more. I'll stop this instance and go run it from its own monitor.
There, I find that all of the vertex-object-renderers must be checked,
and that raising its memory to 500 megs for both buffers brings it down
to about 1 second to update the preview. Since that machine has 16GB
of dram, I'll raise those work buffers to a couple gigs each, but this
is now a lot more usable.
Thank you nop-head
Unfortunately:
/tmp/.mount_opensc7wmGaY/AppRun.wrapped: /lib/x86_64-linux-gnu/libm.so.6: version `GLIBC_2.27' not found (required
/tmp/.mount_opensc7wmGaY/AppRun.wrapped: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.25' not found (required
Thank you nop-head
- Louis D. Brandeis
