battery spring spiral
RT
r.d. terramir
Fri, Sep 7, 2018 10:02 PM
Ok I need to embed a spiral cutout. 17.25mm the biggest diameter  the
next about 14mm then 11.33 then 9.15. distance 6mm for the first 3
spirals then about 4mm although that end won't be in the plastic it's
the wide end. the wire diameter is 1.4mm. I need to know how I would
program this.
terramir
Ok I need to embed a spiral cutout. 17.25mm the biggest diameter the next about 14mm then 11.33 then 9.15. distance 6mm for the first 3 spirals then about 4mm although that end won't be in the plastic it's the wide end. the wire diameter is 1.4mm. I need to know how I would program this. terramir
Fri, Sep 7, 2018 11:11 PM
Good luck. I model battery springs with a cone.
On Fri, 7 Sep 2018, 23:03 r.d. terramir, terramircomputers@gmail.com
program this.
terramir
Good luck. I model battery springs with a cone. On Fri, 7 Sep 2018, 23:03 r.d. terramir, <terramircomputers@gmail.com> wrote: > Ok I need to embed a spiral cutout. 17.25mm the biggest diameter the > next about 14mm then 11.33 then 9.15. distance 6mm for the first 3 > spirals then about 4mm although that end won't be in the plastic it's > the wide end. the wire diameter is 1.4mm. I need to know how I would > program this. > > terramir > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
RT
r.d. terramir
Fri, Sep 7, 2018 11:37 PM
Hmm you got a code example??
terramir
program this.
terramir
Hmm you got a code example?? terramir On Sep 7, 2018 4:12 PM, "nop head" <nop.head@gmail.com> wrote: > Good luck. I model battery springs with a cone. > > On Fri, 7 Sep 2018, 23:03 r.d. terramir, <terramircomputers@gmail.com> > wrote: > >> Ok I need to embed a spiral cutout. 17.25mm the biggest diameter the >> next about 14mm then 11.33 then 9.15. distance 6mm for the first 3 >> spirals then about 4mm although that end won't be in the plastic it's >> the wide end. the wire diameter is 1.4mm. I need to know how I would >> program this. >> >> terramir >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
RT
r.d. terramir
Sat, Sep 8, 2018 6:59 PM
https://plus.google.com/+rdterramir/posts/UPXqFQjo5YS here is the spring
and I would like to put it through the end of the 3d printed plastic
battery holder anyone got any ideas on how to model this please
terramir
program this.
terramir
https://plus.google.com/+rdterramir/posts/UPXqFQjo5YS here is the spring and I would like to put it through the end of the 3d printed plastic battery holder anyone got any ideas on how to model this please terramir On Sep 7, 2018 4:12 PM, "nop head" <nop.head@gmail.com> wrote: > Good luck. I model battery springs with a cone. > > On Fri, 7 Sep 2018, 23:03 r.d. terramir, <terramircomputers@gmail.com> > wrote: > >> Ok I need to embed a spiral cutout. 17.25mm the biggest diameter the >> next about 14mm then 11.33 then 9.15. distance 6mm for the first 3 >> spirals then about 4mm although that end won't be in the plastic it's >> the wide end. the wire diameter is 1.4mm. I need to know how I would >> program this. >> >> terramir >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
RS
Rob Sherwood
Sat, Sep 8, 2018 7:10 PM
I did something similar to this where I created a formula to place a
sequence of n circles along a path, and then did a hull() around each
adjacent pair of circles.  The function I was following was an
involute curve but you should be able to reuse this technique for an
arbitrary path, e.g., your spring.
Here's the relevant code:
                for (i = [1: step: max_angle] ) {
                    point = involute( width, i);        // replace
this function with your own path function
prev_point = involute( width, i - step);  // ditto...
hull() {
translate([ point[0], point[1], 0])
circle(d=circle_diam, center=true);
translate([ prev_point[0], prev_point[1], 0])
Hope this helps,
terramir
program this.
terramir
I did something similar to this where I created a formula to place a sequence of n circles along a path, and then did a hull() around each adjacent pair of circles. The function I was following was an involute curve but you should be able to reuse this technique for an arbitrary path, e.g., your spring. Here's the relevant code: for (i = [1: step: max_angle] ) { point = involute( width, i); // replace this function with your own path function prev_point = involute( width, i - step); // ditto... hull() { translate([ point[0], point[1], 0]) circle(d=circle_diam, center=true); translate([ prev_point[0], prev_point[1], 0]) circle(d=circle_diam, center=true); } } Hope this helps, - Rob . On Sat, Sep 8, 2018 at 12:00 PM r.d. terramir <terramircomputers@gmail.com> wrote: > > https://plus.google.com/+rdterramir/posts/UPXqFQjo5YS here is the spring and I would like to put it through the end of the 3d printed plastic battery holder anyone got any ideas on how to model this please > terramir > > On Sep 7, 2018 4:12 PM, "nop head" <nop.head@gmail.com> wrote: >> >> Good luck. I model battery springs with a cone. >> >> On Fri, 7 Sep 2018, 23:03 r.d. terramir, <terramircomputers@gmail.com> wrote: >>> >>> Ok I need to embed a spiral cutout. 17.25mm the biggest diameter the >>> next about 14mm then 11.33 then 9.15. distance 6mm for the first 3 >>> spirals then about 4mm although that end won't be in the plastic it's >>> the wide end. the wire diameter is 1.4mm. I need to know how I would >>> program this. >>> >>> terramir >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
RT
r.d. terramir
Sat, Sep 8, 2018 8:20 PM
I tried to look up involute as a function of openscad and besides a
gitub involute gears I couldn't really find anything is involute in
your code a function or a variable. I am a little confused about this,
but I did think about something here I dunno if it would work but try
to follow this and maybe give me some suggestions .but I did get a
spiral together with this code the top is sort of inaccurate and I may
have to run a test print or two to tweak it(the z and y factors) but I
think this might just work. the spiral makes 4.5 revolutions but the
top is smushed so I used 1440 as in four revolutions so it wouldn't
effect the height of the bottom revolutions as much and those are the
ones that will have to go through the battery holder.
<code
for (i=[0:0.5:1440]){
translate([0,0,(i/60)])
rotate([90,0,i])
translate([8.75-(i/170),0,0])
cylinder(r=0.9, h=0.4, $fn=32);
</code> terramir Respectfully, R. Daniel Borkan 727 S. Coronado St. 201 Los Angeles, CA 90057 C: (213) 271-6721 All written content of this e-mail is confidential and only intended for the named recipient. This message is subject to copyright and is intellectual property of the sender. All rights reserved (c) 2018
hull() {
Hope this helps,
terramir
program this.
terramir
I tried to look up involute as a function of openscad and besides a gitub involute gears I couldn't really find anything is involute in your code a function or a variable. I am a little confused about this, but I did think about something here I dunno if it would work but try to follow this and maybe give me some suggestions .but I did get a spiral together with this code the top is sort of inaccurate and I may have to run a test print or two to tweak it(the z and y factors) but I think this might just work. the spiral makes 4.5 revolutions but the top is smushed so I used 1440 as in four revolutions so it wouldn't effect the height of the bottom revolutions as much and those are the ones that will have to go through the battery holder. <code for (i=[0:0.5:1440]){ translate([0,0,(i/60)]) rotate([90,0,i]) translate([8.75-(i/170),0,0]) cylinder(r=0.9, h=0.4, $fn=32); } </code> terramir Respectfully, R. Daniel Borkan 727 S. Coronado St. 201 Los Angeles, CA 90057 C: (213) 271-6721 All written content of this e-mail is confidential and only intended for the named recipient. This message is subject to copyright and is intellectual property of the sender. All rights reserved (c) 2018 On Sat, Sep 8, 2018 at 12:10 PM Rob Sherwood <rob.sherwood@gmail.com> wrote: > > I did something similar to this where I created a formula to place a > sequence of n circles along a path, and then did a hull() around each > adjacent pair of circles. The function I was following was an > involute curve but you should be able to reuse this technique for an > arbitrary path, e.g., your spring. > > Here's the relevant code: > > for (i = [1: step: max_angle] ) { > point = involute( width, i); // replace > this function with your own path function > prev_point = involute( width, i - step); // ditto... > hull() { > translate([ point[0], point[1], 0]) > circle(d=circle_diam, center=true); > translate([ prev_point[0], prev_point[1], 0]) > circle(d=circle_diam, center=true); > } > } > > Hope this helps, > > - Rob > . > On Sat, Sep 8, 2018 at 12:00 PM r.d. terramir > <terramircomputers@gmail.com> wrote: > > > > https://plus.google.com/+rdterramir/posts/UPXqFQjo5YS here is the spring and I would like to put it through the end of the 3d printed plastic battery holder anyone got any ideas on how to model this please > > terramir > > > > On Sep 7, 2018 4:12 PM, "nop head" <nop.head@gmail.com> wrote: > >> > >> Good luck. I model battery springs with a cone. > >> > >> On Fri, 7 Sep 2018, 23:03 r.d. terramir, <terramircomputers@gmail.com> wrote: > >>> > >>> Ok I need to embed a spiral cutout. 17.25mm the biggest diameter the > >>> next about 14mm then 11.33 then 9.15. distance 6mm for the first 3 > >>> spirals then about 4mm although that end won't be in the plastic it's > >>> the wide end. the wire diameter is 1.4mm. I need to know how I would > >>> program this. > >>> > >>> terramir > >>> > >>> _______________________________________________ > >>> OpenSCAD mailing list > >>> Discuss@lists.openscad.org > >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >> > >> > >> _______________________________________________ > >> OpenSCAD mailing list > >> Discuss@lists.openscad.org > >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >> > > _______________________________________________ > > OpenSCAD mailing list > > Discuss@lists.openscad.org > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
N
NateTG
Sat, Sep 8, 2018 9:29 PM
This seems like an "extrusion" kind of thing.
This is a little clumsy, but you can replace 'path' with the shape you want
the wire to trace out.
pathextrude.scad http://forum.openscad.org/file/t2140/pathextrude.scad
This seems like an "extrusion" kind of thing. This is a little clumsy, but you can replace 'path' with the shape you want the wire to trace out. pathextrude.scad <http://forum.openscad.org/file/t2140/pathextrude.scad> -- Sent from: http://forum.openscad.org/
RT
r.d. terramir
Sat, Sep 8, 2018 9:53 PM
wow that is alot of code for a spiral I actually got the code into a
function although I would like some help improving the module I am
going to start a new topic, because this is solved now the coding into
a function can begin, but I will need some help to make it more
natural I am having some algebraic function problems someone here
probably can solve in five second flat I probably could too if I
wasn't stuck on it right now. one of those can't see the forest
because of all the trees problems.
Look for the new topic module (maybe function later) spiral()
wow that is alot of code for a spiral I actually got the code into a function although I would like some help improving the module I am going to start a new topic, because this is solved now the coding into a function can begin, but I will need some help to make it more natural I am having some algebraic function problems someone here probably can solve in five second flat I probably could too if I wasn't stuck on it right now. one of those can't see the forest because of all the trees problems. Look for the new topic module (maybe function later) spiral() On Sat, Sep 8, 2018 at 2:30 PM NateTG <nate-openscadforum@pedantic.org> wrote: > > This seems like an "extrusion" kind of thing. > > This is a little clumsy, but you can replace 'path' with the shape you want > the wire to trace out. > > pathextrude.scad <http://forum.openscad.org/file/t2140/pathextrude.scad> > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
N
NateTG
Sat, Sep 8, 2018 10:28 PM
It's a 'generic path extrude' thing that predates list comprehensions, and
uses its own vector functions.  A bunch of that stuff is there to allow
twisting into corners.
It's a 'generic path extrude' thing that predates list comprehensions, and uses its own vector functions. A bunch of that stuff is there to allow twisting into corners. -- Sent from: http://forum.openscad.org/
