JJ
Johan Jonker
Sat, Dec 17, 2016 7:59 AM
I found a remarkable difference in version 2016.10.4 using for statement
with increments smaller than 1. Sometimes the end value is not reached.
for (a7=[ 6.8:1/5:7.8]) echo(A7=a7);
for (a=[ 7.2:1/5:8.2]) echo(A=a);
Output is
ECHO: A7 = 6.8
ECHO: A7 = 7
ECHO: A7 = 7.2
ECHO: A7 = 7.4
ECHO: A7 = 7.6
ECHO: A = 7.2
ECHO: A = 7.4
ECHO: A = 7.6
ECHO: A = 7.8
ECHO: A = 8
ECHO: A = 8.2
View this message in context: http://forum.openscad.org/for-statement-doesn-t-do-all-the-steps-sometimes-tp19591.html
Output is
ECHO: A7 = 6.8
ECHO: A7 = 7
ECHO: A7 = 7.2
ECHO: A7 = 7.4
ECHO: A7 = 7.6
ECHO: A = 7.2
ECHO: A = 7.4
ECHO: A = 7.6
ECHO: A = 7.8
ECHO: A = 8
ECHO: A = 8.2
JJ
Johan Jonker
Sat, Dec 17, 2016 8:03 AM
a workaround is:
for (a7=[ 6.8:1/5:7.800001]) echo(A7=a7);
View this message in context: http://forum.openscad.org/for-statement-doesn-t-do-all-the-steps-sometimes-tp19591p19592.html
a workaround is:
Sat, Dec 17, 2016 11:07 AM
1/5 is a recurring fraction in binary so it is not surprising. I never use
floating point steps in a for loop. It is much better to use integer steps
and then scale down the loop index
On 17 December 2016 at 08:03, Johan Jonker <johangjonker@zonnet.nl> wrote:
> a workaround is:
Jerry Davis
Sat, Dec 17, 2016 12:58 PM
It is still that way in the latest snapshot.
I looked at the Documentation, and I consider this a bug.
The Documentation clearly has floating point values in the start, step,
end. And the definitions of start step and end, clearly state that it stops
when the next value would be greater. Clearly, not what this does.
You should put this in as a bug.
Jerry
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
Jerry
*The most exciting phrase to hear in science - the one that heralds new
discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov
>> a workaround is:
Sat, Dec 17, 2016 1:05 PM
Use this to see why it doesn't behave as expected:
for (a7=[ 6.8:1/5:7.800001]) echo(A7=a7 - 7.8);
for (a=[ 7.2:1/5:8.2]) echo(A=a - 7.2);
ECHO: A7 = -1
ECHO: A7 = -0.8
ECHO: A7 = -0.6
ECHO: A7 = -0.4
ECHO: A7 = -0.2
ECHO: A7 = 8.88178e-016
ECHO: A = 0
ECHO: A = 0.2
ECHO: A = 0.4
ECHO: A = 0.6
ECHO: A = 0.8
ECHO: A = 1
As you can see repeatedly adding 0.2 slightly overshoots 7.8. This is
because they are both infinitely recurring binary fractions, not exact
decimal values.
Jerry
use floating point steps in a for loop. It is much better to use integer
steps and then scale down the loop index
ECHO: A7 = -1
ECHO: A7 = -0.8
ECHO: A7 = -0.6
ECHO: A7 = -0.4
ECHO: A7 = -0.2
ECHO: A = 0
ECHO: A = 0.2
ECHO: A = 0.4
ECHO: A = 0.6
ECHO: A = 0.8
ECHO: A = 1
decimal values.
> Jerry
>> wrote:
>>> a workaround is:
Sat, Dec 17, 2016 1:07 PM
Sorry, typo
for (a=[ 7.2:1/5:8.2]) echo(A=a - 8.2);
ECHO: A7 = -1
ECHO: A7 = -0.8
ECHO: A7 = -0.6
ECHO: A7 = -0.4
ECHO: A7 = -0.2
ECHO: A = -1
ECHO: A = -0.8
ECHO: A = -0.6
ECHO: A = -0.4
ECHO: A = -0.2
ECHO: A = 0
ECHO: A7 = -1
ECHO: A7 = -0.8
ECHO: A7 = -0.6
ECHO: A7 = -0.4
ECHO: A7 = -0.2
ECHO: A = 0
ECHO: A = 0.2
ECHO: A = 0.4
ECHO: A = 0.6
ECHO: A = 0.8
ECHO: A = 1
decimal values.
Jerry
Sorry, typo
ECHO: A7 = -1
ECHO: A7 = -0.8
ECHO: A7 = -0.6
ECHO: A7 = -0.4
ECHO: A7 = -0.2
ECHO: A = -1
ECHO: A = -0.8
ECHO: A = -0.6
ECHO: A = -0.4
ECHO: A = -0.2
ECHO: A = 0
> ECHO: A7 = -1
> ECHO: A7 = -0.8
> ECHO: A7 = -0.6
> ECHO: A7 = -0.4
> ECHO: A7 = -0.2
> ECHO: A = 0
> ECHO: A = 0.2
> ECHO: A = 0.4
> ECHO: A = 0.6
> ECHO: A = 0.8
> ECHO: A = 1
> decimal values.
>> Jerry
>>> wrote:
>>>> a workaround is:
Sat, Dec 17, 2016 1:09 PM
echo (6.8 + 0.2 + 0.2 + 0.2 + 0.2 + 0.2 - 7.8);
ECHO: 8.88178e-016
On 17 December 2016 at 13:07, nop head nop.head@gmail.com wrote:
Sorry, typo
ECHO: A7 = -1
ECHO: A7 = -0.8
ECHO: A7 = -0.6
ECHO: A7 = -0.4
ECHO: A7 = -0.2
ECHO: A = -1
ECHO: A = -0.8
ECHO: A = -0.6
ECHO: A = -0.4
ECHO: A = -0.2
ECHO: A = 0
ECHO: A7 = -1
ECHO: A7 = -0.8
ECHO: A7 = -0.6
ECHO: A7 = -0.4
ECHO: A7 = -0.2
ECHO: A = 0
ECHO: A = 0.2
ECHO: A = 0.4
ECHO: A = 0.6
ECHO: A = 0.8
ECHO: A = 1
decimal values.
Jerry
ECHO: 8.88178e-016
On 17 December 2016 at 13:07, nop head <nop.head@gmail.com> wrote:
> Sorry, typo
> ECHO: A7 = -1
> ECHO: A7 = -0.8
> ECHO: A7 = -0.6
> ECHO: A7 = -0.4
> ECHO: A7 = -0.2
> ECHO: A = -1
> ECHO: A = -0.8
> ECHO: A = -0.6
> ECHO: A = -0.4
> ECHO: A = -0.2
> ECHO: A = 0
>> ECHO: A7 = -1
>> ECHO: A7 = -0.8
>> ECHO: A7 = -0.6
>> ECHO: A7 = -0.4
>> ECHO: A7 = -0.2
>> ECHO: A = 0
>> ECHO: A = 0.2
>> ECHO: A = 0.4
>> ECHO: A = 0.6
>> ECHO: A = 0.8
>> ECHO: A = 1
>> decimal values.
>>> Jerry
>>>> wrote:
>>>>> a workaround is:
Sat, Dec 17, 2016 1:23 PM
echo (6.8 + 0.2 - 7.0);
echo (6.8 + 0.2 + 0.2 - 7.2);
echo (6.8 + 0.2 + 0.2 + 0.2 - 7.4);
echo (6.8 + 0.2 + 0.2 + 0.2 + 0.2 - 7.6);
echo (6.8 + 0.4 + 0.4 - 7.6);
echo (6.8 + 0.8 - 7.6);
echo (6.8 + 0.6 - 7.4);
ECHO: 0
ECHO: 0
ECHO: 0
ECHO: 8.88178e-016
ECHO: 8.88178e-016
ECHO: 8.88178e-016
ECHO: 0
ECHO: -8.88178e-016
So you can't ever rely on sums of floating point numbers hitting exact
values. You might not be surprised if you had numbers like 1/3, 1/6, etc,
but in binary most fractions are not exact.
ECHO: 8.88178e-016
Sorry, typo
ECHO: A7 = -1
ECHO: A7 = -0.8
ECHO: A7 = -0.6
ECHO: A7 = -0.4
ECHO: A7 = -0.2
ECHO: A = -1
ECHO: A = -0.8
ECHO: A = -0.6
ECHO: A = -0.4
ECHO: A = -0.2
ECHO: A = 0
ECHO: A7 = -1
ECHO: A7 = -0.8
ECHO: A7 = -0.6
ECHO: A7 = -0.4
ECHO: A7 = -0.2
ECHO: A = 0
ECHO: A = 0.2
ECHO: A = 0.4
ECHO: A = 0.6
ECHO: A = 0.8
ECHO: A = 1
decimal values.
Jerry
ECHO: 0
ECHO: 0
ECHO: 0
ECHO: 8.88178e-016
ECHO: 8.88178e-016
ECHO: 8.88178e-016
ECHO: 0
ECHO: -8.88178e-016
> ECHO: 8.88178e-016
>> Sorry, typo
>> ECHO: A7 = -1
>> ECHO: A7 = -0.8
>> ECHO: A7 = -0.6
>> ECHO: A7 = -0.4
>> ECHO: A7 = -0.2
>> ECHO: A = -1
>> ECHO: A = -0.8
>> ECHO: A = -0.6
>> ECHO: A = -0.4
>> ECHO: A = -0.2
>> ECHO: A = 0
>>> ECHO: A7 = -1
>>> ECHO: A7 = -0.8
>>> ECHO: A7 = -0.6
>>> ECHO: A7 = -0.4
>>> ECHO: A7 = -0.2
>>> ECHO: A = 0
>>> ECHO: A = 0.2
>>> ECHO: A = 0.4
>>> ECHO: A = 0.6
>>> ECHO: A = 0.8
>>> ECHO: A = 1
>>> decimal values.
>>>> Jerry
>>>>> wrote:
>>>>>> a workaround is:
JJ
Johan Jonker
Sat, Dec 17, 2016 3:36 PM
It is the question if it's a bug.
Maybe it is more important to understand it.
I tried to do the same in VBA.
There the same thing happens.
I more like a warning in the on line manual about the proper use of the
statement.
View this message in context: http://forum.openscad.org/for-statement-doesn-t-do-all-the-steps-sometimes-tp19591p19603.html
statement.
Sat, Dec 17, 2016 4:04 PM
It is really proper use of floating point math, nothing OpenSCAD specific.
I always use integer indices and compute everything from those. I think it
has been mentioned before that OpenSCAD could do that internally. I.e.
instead of repeatedly adding it could have a hidden counter that it
multiples the step value by.
echo(6.8 + 5 * 0.2 - 7.8);
ECHO: 0
That would give more accurate results but there would still be caveats.
ECHO: 0
> statement.
