CPU and RAM Resources Allocations Increase for OpenSCAD
Mon, May 21, 2018 11:23 AM
Yes I know it can easily be optimised but OpenSCAD uses the CGAL library
and that doesn't seem to optimise for speed. Also it does all the maths in
rational notation, so simple operations take at least three orders of
magnitude longer than I would expect. Coupled with the at least O(N)
explosion and it gets impractically slow with large numbers of 3D vertices.
On 21 May 2018 at 10:56, Rogier Wolff R.E.Wolff@bitwizard.nl wrote:
On Mon, May 21, 2018 at 10:16:37AM +0100, nop head wrote:
I think union time is proportional to the square of the number of facets
of
the two items being unioned. With a "number" of spheres with 61738
facets I
don't think it will finish in a life time.
The way to estimatet how long it will take is to run it with $fn set to
small numbers and look at how the time increases with $fn. Then you can
predict how long it will be for $fn=250. It will be a gross
underestimation
because it doesn't take into account swapping, etc. But I am sure it will
show you it is totally impractical to work with such values of $fn in
Weeeelllll....
This means to me that there is work to be done. Is unioning inherently
quadratic?
Well,  yes it is: You have to check for each pair of triangles if they
intersect. Right?
Wrong! For example, you can split up the working space is small
cubes. Go through the list of triangles once, and those that are small
and land in 1 or two of those cubes, you place in a "bin" for that
cube. The big trangles and those that are unlucky go into a bin for
"other". Now from a theoretical point-of-view, the algorithm will
probably still be O(N^2) But from a practical point-of-view, in say
the case where you are unioning a bunch of near-perfect spheres, you
will be able to handle 90 or 99% of the items in O(N) time. This
improves the "feasable dataset size" by a big margin.
In practise, I work at low $fn, until for the final render I increase
it.
**    Delftechpark 26 2628 XH  Delft, The Netherlands. KVK: 27239233    **
Yes I know it can easily be optimised but OpenSCAD uses the CGAL library and that doesn't seem to optimise for speed. Also it does all the maths in rational notation, so simple operations take at least three orders of magnitude longer than I would expect. Coupled with the at least O(N) explosion and it gets impractically slow with large numbers of 3D vertices. On 21 May 2018 at 10:56, Rogier Wolff <R.E.Wolff@bitwizard.nl> wrote: > On Mon, May 21, 2018 at 10:16:37AM +0100, nop head wrote: > > I think union time is proportional to the square of the number of facets > of > > the two items being unioned. With a "number" of spheres with 61738 > facets I > > don't think it will finish in a life time. > > > > The way to estimatet how long it will take is to run it with $fn set to > > small numbers and look at how the time increases with $fn. Then you can > > predict how long it will be for $fn=250. It will be a gross > underestimation > > because it doesn't take into account swapping, etc. But I am sure it will > > show you it is totally impractical to work with such values of $fn in > > Weeeelllll.... > > This means to me that there is work to be done. Is unioning inherently > quadratic? > > Well, yes it is: You have to check for each pair of triangles if they > intersect. Right? > > Wrong! For example, you can split up the working space is small > cubes. Go through the list of triangles once, and those that are small > and land in 1 or two of those cubes, you place in a "bin" for that > cube. The big trangles and those that are unlucky go into a bin for > "other". Now from a theoretical point-of-view, the algorithm will > probably still be O(N^2) But from a practical point-of-view, in say > the case where you are unioning a bunch of near-perfect spheres, you > will be able to handle 90 or 99% of the items in O(N) time. This > improves the "feasable dataset size" by a big margin. > > In practise, I work at low $fn, until for the final render I increase > it. > > Roger. > > -- > ** R.E.Wolff@BitWizard.nl ** http://www.BitWizard.nl/ ** +31-15-2600998 ** > ** Delftechpark 26 2628 XH Delft, The Netherlands. KVK: 27239233 ** > *-- BitWizard writes Linux device drivers for any device you may have! --* > The plan was simple, like my brother-in-law Phil. But unlike > Phil, this plan just might work. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
G
Gadgetmind
Mon, May 21, 2018 11:28 AM
On 20/05/18 16:58, Still_learning wrote:
My laptop computer is currently crunching numbers for an OpenSCAD STL file
which can be described as including a number of spheres, with an $fn=250
setting.
Ouch, I never go above $fn=120 and even that can be very slow.
I also don't use $fn but instead use $fs and $fa.
My logic is complex because I do the high quality from make files, but
it boils down to -
fn=60;     // or 120 for HQ
$fa=360/fn;
fs=0.5;    // or 0.1 for HQ
On 20/05/18 16:58, Still_learning wrote: > My laptop computer is currently crunching numbers for an OpenSCAD STL file > which can be described as including a number of spheres, with an $fn=250 > setting. Ouch, I never go above $fn=120 and even that can be very slow. I also don't use $fn but instead use $fs and $fa. My logic is complex because I do the high quality from make files, but it boils down to - fn=60;     // or 120 for HQ $fa=360/fn; fs=0.5;    // or 0.1 for HQ
CA
Mon, May 21, 2018 12:05 PM
it.
There was a discussion about "unioning a bunch of near-perfect spheres"
last year
http://forum.openscad.org/Performance-test-manyballs-td21455.html
In comparison with OpenSCAD 2018.04.19.nightly on Linux Kubuntu with 4
CPUs and 32GB ram and referring to a case of only 7x7x7 intersecting
spheres, booleans with https://github.com/arnholm/xcsg are now ~69x
faster, as OpenSCAD only uses one CPU and xcsg using all 4 CPUs plus
generating geodesic spheres (fewer triangles).
Defining 16x16x16 intersecting spheres
https://gist.github.com/arnholm/23739f7e0fb48f477aaf1b6bbeee968f
and executing with xcsg I find booleans to now require about 130
seconds, then add about 60 seconds for fixing non-triangular faces
afterwards. Maximum required memory is about 4GB, generating 1448960
triangles, ref. image in gist link.
On 21. mai 2018 11:56, Rogier Wolff wrote: > Now from a theoretical point-of-view, the algorithm will > probably still be O(N^2) But from a practical point-of-view, in say > the case where you are unioning a bunch of near-perfect spheres, you > will be able to handle 90 or 99% of the items in O(N) time. This > improves the "feasable dataset size" by a big margin. > > In practise, I work at low $fn, until for the final render I increase > it. There was a discussion about "unioning a bunch of near-perfect spheres" last year http://forum.openscad.org/Performance-test-manyballs-td21455.html In comparison with OpenSCAD 2018.04.19.nightly on Linux Kubuntu with 4 CPUs and 32GB ram and referring to a case of only 7x7x7 intersecting spheres, booleans with https://github.com/arnholm/xcsg are now ~69x faster, as OpenSCAD only uses one CPU and xcsg using all 4 CPUs plus generating geodesic spheres (fewer triangles). Defining 16x16x16 intersecting spheres https://gist.github.com/arnholm/23739f7e0fb48f477aaf1b6bbeee968f and executing with xcsg I find booleans to now require about 130 seconds, then add about 60 seconds for fixing non-triangular faces afterwards. Maximum required memory is about 4GB, generating 1448960 triangles, ref. image in gist link. Carsten Arnholm
JS
John Sprockets
Mon, May 21, 2018 2:49 PM
Thank you for the pointers.
I have been running some tests and should be posting results later today to
the original thread.
setting.
boils down to -
$fa=360/fn;
Thank you for the pointers. I have been running some tests and should be posting results later today to the original thread. On May 21, 2018 4:28 AM, "Gadgetmind" <lists@foxhill.co.uk> wrote: > On 20/05/18 16:58, Still_learning wrote: > > My laptop computer is currently crunching numbers for an OpenSCAD STL file > which can be described as including a number of spheres, with an $fn=250 > setting. > > Ouch, I never go above $fn=120 and even that can be very slow. > > I also don't use $fn but instead use $fs and $fa. > > My logic is complex because I do the high quality from make files, but it > boils down to - > > fn=60; // or 120 for HQ > > $fa=360/fn; > > fs=0.5; // or 0.1 for HQ > > >
S
Still_learning
Mon, May 21, 2018 6:11 PM
Thanks to all for the insights, comments and suggestions.
As the initial file crunching was a test to gain some idea of
the time involved for crunching the subsequent versions
(which are even bigger and more complex), I killed the 2.5
day computation process to check my code and test
some options.
I looked over the coding and came across some possible
bugaboos, and fixed them.  I will explain the errors and
solution after further testing of alternatives.
I ran additional tests on the same file with different $fn=
settings and here are the results:
When  $fn= was set to:            Crunch Time Was
 25                                                6 minutes
 50                                              25 minutes
100                                   1 hour 39 minutes
200                                   > 17 hours when processing stopped
The more I learn, the more I get curious about.
Thanks to all for the insights, comments and suggestions. As the initial file crunching was a test to gain some idea of the time involved for crunching the subsequent versions (which are even bigger and more complex), I killed the 2.5 day computation process to check my code and test some options. I looked over the coding and came across some possible bugaboos, and fixed them. I will explain the errors and solution after further testing of alternatives. I ran additional tests on the same file with different $fn= settings and here are the results: When $fn= was set to: Crunch Time Was 25 6 minutes 50 25 minutes 100 1 hour 39 minutes 200 > 17 hours when processing stopped ----- The more I learn, the more I get curious about. -- Sent from: http://forum.openscad.org/
S
Still_learning
Mon, May 21, 2018 6:29 PM
Other test was to determine if "nested" $fn= commands had any impact
on imported modules.
Example:
File_a.scad code contains general instruction of $fn=10, and calls to
module_b.scad (which contains an instruction of $fn=20)
Is there a compunding effect?
No, not as far as I can tell.
If the values above are reversed, the lower value is used and
displayed when rendered.  This means that imported files
are treated as completely separate entities.  Good to know.
Other test was to determine if "nested" $fn= commands had any impact on imported modules. Example: File_a.scad code contains general instruction of $fn=10, and calls to module_b.scad (which contains an instruction of $fn=20) Is there a compunding effect? No, not as far as I can tell. If the values above are reversed, the lower value is used and displayed when rendered. This means that imported files are treated as completely separate entities. Good to know. ----- The more I learn, the more I get curious about. -- Sent from: http://forum.openscad.org/
AC
Alan Cox
Tue, May 22, 2018 1:10 PM
On Sun, 20 May 2018 20:29:58 -0400
jon jon@jonbondy.com wrote:
There was a thread a while back about how performance was degraded
because one of the RAM caches was overflowing.  Getting dirt cheap RAM
is not always as good a deal as you might imagine
I have no idea what you are talking about here.
Caches are part of the processor not the RAM. And in fact generally
speaking Xeons have bigger caches than client parts.
The most important thing is to have enough RAM. People often get the idea
that swap is a little bit slower than memory. The old analogy of swap
being like your filing cabinet is (in a modern system) better replaced by
swap being sending documents to and from a warehouse on the far side of
town in a truck, and probably in the middle of rush hour.
The scale of memory versus swap performance is enormous
Alan
On Sun, 20 May 2018 20:29:58 -0400 jon <jon@jonbondy.com> wrote: > There was a thread a while back about how performance was degraded > because one of the RAM caches was overflowing.  Getting dirt cheap RAM > is not always as good a deal as you might imagine I have no idea what you are talking about here. Caches are part of the processor not the RAM. And in fact generally speaking Xeons have bigger caches than client parts. The most important thing is to have enough RAM. People often get the idea that swap is a little bit slower than memory. The old analogy of swap being like your filing cabinet is (in a modern system) better replaced by swap being sending documents to and from a warehouse on the far side of town in a truck, and probably in the middle of rush hour. The scale of memory versus swap performance is *enormous* Alan
Tue, May 22, 2018 6:47 PM
I think that was discussing the cache setting in OpenSCAD for
already rendered sub-trees. If that value is set too low, this
can cause performance impact even with more RAM available as
identical sub-trees are calculated multiple times.
On 05/22/2018 03:10 PM, Alan Cox wrote: > On Sun, 20 May 2018 20:29:58 -0400 > jon <jon@jonbondy.com> wrote: > >> There was a thread a while back about how performance was degraded >> because one of the RAM caches was overflowing.  Getting dirt cheap RAM >> is not always as good a deal as you might imagine > > I have no idea what you are talking about here. > I think that was discussing the cache setting in OpenSCAD for already rendered sub-trees. If that value is set too low, this can cause performance impact even with more RAM available as identical sub-trees are calculated multiple times. ciao, Torsten.
Tue, May 22, 2018 7:01 PM
This is what I was recalling...
http://forum.openscad.org/OpenSCAD-performance-mystery-td23248.html
This is what I was recalling... http://forum.openscad.org/OpenSCAD-performance-mystery-td23248.html Jon On 5/22/2018 2:47 PM, Torsten Paul wrote: > On 05/22/2018 03:10 PM, Alan Cox wrote: >> On Sun, 20 May 2018 20:29:58 -0400 >> jon <jon@jonbondy.com> wrote: >> >>> There was a thread a while back about how performance was degraded >>> because one of the RAM caches was overflowing.  Getting dirt cheap RAM >>> is not always as good a deal as you might imagine >> >> I have no idea what you are talking about here. >> > I think that was discussing the cache setting in OpenSCAD for > already rendered sub-trees. If that value is set too low, this > can cause performance impact even with more RAM available as > identical sub-trees are calculated multiple times. > > ciao, >   Torsten. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Tue, May 22, 2018 7:10 PM
I meant this discussion:
http://forum.openscad.org/Geometry-cache-thrashing-td23978.html
which is relevant too, but as mentioned before "just" a
configuration setting in OpenSCAD.
Anyone feeling to collect all that information into something
that can be added to the FAQ?
I meant this discussion: http://forum.openscad.org/Geometry-cache-thrashing-td23978.html which is relevant too, but as mentioned before "just" a configuration setting in OpenSCAD. Anyone feeling to collect all that information into something that can be added to the FAQ? ciao, Torsten.
