Looking at the documentation, it looks like all I need to do is to download
the libraries into "$HOME/.local/share/OpenSCAD/libraries", but either that
is not working properly or BOSL2 examples are broken (I suspect I'm doing
it wrong). I am also not sure if that is considered best practice.
For example, when I try to render BOSL2logo.scad I get the following
warnings and errors:
Used file cache size: 1 files
WARNING: variable pitch_angle not specified as parameter in file
BOSL2logo.scad, line 24
<24,/home/ebo/.local/share/OpenSCAD/libraries/BOSL2/examples/BOSL2logo.scad>
WARNING: variable spiral_angle not specified as parameter in file
ERROR: Assertion '((all_integer([teeth, mate_teeth]) && (teeth >= 3)) &&
(mate_teeth >= 3))' failed: "Must give teeth and mate_teeth, integers
greater than or equal to 3" in file ../gears.scad, line 2433
<2433,/home/ebo/.local/share/OpenSCAD/libraries/BOSL2/gears.scad>
TRACE: called by 'bevel_gear' in file ../gears.scad, line 2600
<2600,/home/ebo/.local/share/OpenSCAD/libraries/BOSL2/gears.scad>
TRACE: called by 'bevel_gear' in file BOSL2logo.scad, line 24
TRACE: called by 'children' in file ../color.scad, line 47
<47,/home/ebo/.local/share/OpenSCAD/libraries/BOSL2/color.scad>
TRACE: called by 'recolor' in file BOSL2logo.scad, line 23
<23,/home/ebo/.local/share/OpenSCAD/libraries/BOSL2/examples/BOSL2logo.scad>
TRACE: called by 'children' in file ../distributors.scad, line 1883
<1883,/home/ebo/.local/share/OpenSCAD/libraries/BOSL2/distributors.scad>
TRACE: called by 'translate' in file ../distributors.scad, line 1883
TRACE: called by 'for' in file ../distributors.scad, line 1880
<1880,/home/ebo/.local/share/OpenSCAD/libraries/BOSL2/distributors.scad>
TRACE: called by 'xdistribute' in file BOSL2logo.scad, line 10
<10,/home/ebo/.local/share/OpenSCAD/libraries/BOSL2/examples/BOSL2logo.scad>
and with a number of others I also get the error:
CGAL_Nef_Polyhedron.
Does anyone have any suggestions?
EBo --
download the libraries into "$HOME/.local/share/OpenSCAD/libraries",
but either that is not working properly or BOSL2 examples are broken
(I suspect I'm doing it wrong). I am also not sure if that is
Yep, I get that too.
My guess is that the example got stale, that it didn't keep up with the
evolution of the library.
I think that some of the examples (e.g. boolean_geometry.scad) are not
intended to be 3D objects. I see a couple of errors on some of the
others in that directory (e.g. spherical_patch.scad previews OK but
doesn't want to render).
Revar? Adrian?
Well, that's embarrassing. Yes, the examples got stale. I've checked in fixes for both errors I saw in the examples folder.
On Mar 3, 2024, at 6:36 PM, Jordan Brown via Discuss discuss@lists.openscad.org wrote:
Looking at the documentation, it looks like all I need to do is to download the libraries into "$HOME/.local/share/OpenSCAD/libraries", but either that is not working properly or BOSL2 examples are broken (I suspect I'm doing it wrong). I am also not sure if that is considered best practice.
For example, when I try to render BOSL2logo.scad I get the following warnings and errors:
WARNING: variable pitch_angle not specified as parameter in file BOSL2logo.scad, line 24 x-msg://4/24,/home/ebo/.local/share/OpenSCAD/libraries/BOSL2/examples/BOSL2logo.scad
WARNING: variable spiral_angle not specified as parameter in file BOSL2logo.scad, line 24 x-msg://4/24,/home/ebo/.local/share/OpenSCAD/libraries/BOSL2/examples/BOSL2logo.scad
My guess is that the example got stale, that it didn't keep up with the evolution of the library.
I think that some of the examples (e.g. boolean_geometry.scad) are not intended to be 3D objects. I see a couple of errors on some of the others in that directory (e.g. spherical_patch.scad previews OK but doesn't want to render).
Revar? Adrian?
Revar, no biggie. It happens to the best of us. Let me know if you need
help breaking anything else ;-)
On Mar 3, 2024, at 6:36 PM, Jordan Brown via Discuss <
practice.
to render).
Revar? Adrian?
