Frustrating unexpected behavior
linkreincarnate
Mon, Apr 6, 2015 9:37 PM
So I am trying to make a lid for a hinged box.  I am getting some
unpredictable results with it though.  I need to be able to make a cutout
of the lip of the box at the level where the lid ends and the lip begins and
to place a hinge part there.  But when I change the numbers around to
anything other than a 1:1 ratio on the two numbers that control the
thickness I am unable to predict where the transition from lid to lip
begins.  I have been working on this particular problem since yesterday and
I am being stumped.  What am I missing here?
boxLength = 90.4;
boxWidth = 81.25;
boxHeight = 19.2;
boxBottomThickness = .67;
boxWallThickness = .67;
boxArcHeight = 3.5;
boxArcRadius=1;
boxControlArmHoleZOffset = 3.5;
boxControlArmHoleYOffset = 3;
boxHingePinDiameter = 3;
boxHingeDiameter= 5;
boxHingeZOffset = 0;
boxHingeYOffset = 0;
boxHingeTolerance = .1;
boxHingeSupportZOffset= -5;
boxHingeSupportYOffset = -4.5;
boxHingeNumberOfSplits = 7;
boxHingeClearance=1;
//the following variables determine the details of the cylinder (or sphere)
used for minkowski sums
boxCornerRoundness = 7;
boxCornerSmoothness = 16;
boxRoundCorners = true;
controlArmLength = 0;
controlArmHeight = 0;
conrolArmThickness = 0;
controlArmPinDiameter = 2;
controlArmHoleZOffset = 0;
controlArmHoleYOffset = 0;
controlArmPinTolerance = .1;
lidLipHeight = 2;
lidThickness = 2;
lidTolerance = 1;
lidHingeZOffset = 0;
lidHingeYOffset = 0;
lidHingeTolerance = 1;
lidOverlap = 2;
dispenserHoleLength = 72; //also used for dist between tracks
dispenserHoleWidth = 11.5;
dispenserHoleXOffset = 0;
dispenserHoleYOffset = 0;
trackPanelLength = 76;
trackPanelHeight = 19;
trackPanelThickness = 3;
trackWidth = 2.5;
trackLength = 61;
trackHeight = 14;
rollerDiameter = 7;
rollerLength = 71;
rollerPinDiameter = 2;
hingePinDiameter = 1.6;
pinLength= 71;
pinTolerance = 1;
cigaretteDiameter = 7.75;
cigaretteLength = 70;
booleanOverlap = .01; //to ensure that the faces used to difference() dont
line up
lowRollingClearance = 5; //the distance from the center of the rolling pin
to the lid at the lowest point.
hightRollingClearance = 12.6;
arched = false;
//uses math to determine the arc radius of the curve of the box and creates
the appropriate cylinder
$fn=boxCornerSmoothness;
minkowski(){
cube([lidOverlap + boxLength + lidTolerance - (2 *
boxCornerRoundness),
lidOverlap + boxWidth + lidTolerance - (2 *
((lidThickness + lidLipHeight)/2)], center=true);
cylinder(r=boxCornerRoundness,
h=((lidThickness + lidLipHeight)/2),
center=true);
                translate([0,0,-lidThickness/2 ])
                    minkowski()
                     cube([boxLength + lidTolerance - (2 *
boxCornerRoundness) ,
lidLipHeight+booleanOverlap],center = true);
cylinder(r=boxCornerRoundness,h=lidLipHeight/2,
center = true);
translate([0,(boxCornerRoundness + lidTolerance +
lidOverlap+booleanOverlap),-lidThickness/2])
lidLipHeight +booleanOverlap],center = true);
View this message in context: http://forum.openscad.org/Frustrating-unexpected-behavior-tp12321.html
So I am trying to make a lid for a hinged box. I am getting some unpredictable results with it though. I need to be able to make a cutout of the lip of the box at the level where the lid ends and the lip begins and to place a hinge part there. But when I change the numbers around to anything other than a 1:1 ratio on the two numbers that control the thickness I am unable to predict where the transition from lid to lip begins. I have been working on this particular problem since yesterday and I am being stumped. What am I missing here? boxLength = 90.4; boxWidth = 81.25; boxHeight = 19.2; boxBottomThickness = .67; boxWallThickness = .67; boxArcHeight = 3.5; boxArcRadius=1; boxControlArmHoleZOffset = 3.5; boxControlArmHoleYOffset = 3; boxHingePinDiameter = 3; boxHingeDiameter= 5; boxHingeZOffset = 0; boxHingeYOffset = 0; boxHingeTolerance = .1; boxHingeSupportZOffset= -5; boxHingeSupportYOffset = -4.5; boxHingeNumberOfSplits = 7; boxHingeClearance=1; //the following variables determine the details of the cylinder (or sphere) used for minkowski sums boxCornerRoundness = 7; boxCornerSmoothness = 16; boxRoundCorners = true; controlArmLength = 0; controlArmHeight = 0; conrolArmThickness = 0; controlArmPinDiameter = 2; controlArmHoleZOffset = 0; controlArmHoleYOffset = 0; controlArmPinTolerance = .1; lidLipHeight = 2; lidThickness = 2; lidTolerance = 1; lidHingeZOffset = 0; lidHingeYOffset = 0; lidHingeTolerance = 1; lidOverlap = 2; dispenserHoleLength = 72; //also used for dist between tracks dispenserHoleWidth = 11.5; dispenserHoleXOffset = 0; dispenserHoleYOffset = 0; trackPanelLength = 76; trackPanelHeight = 19; trackPanelThickness = 3; trackWidth = 2.5; trackLength = 61; trackHeight = 14; rollerDiameter = 7; rollerLength = 71; rollerPinDiameter = 2; hingePinDiameter = 1.6; pinLength= 71; pinTolerance = 1; cigaretteDiameter = 7.75; cigaretteLength = 70; booleanOverlap = .01; //to ensure that the faces used to difference() dont line up lowRollingClearance = 5; //the distance from the center of the rolling pin to the lid at the lowest point. hightRollingClearance = 12.6; arched = false; //uses math to determine the arc radius of the curve of the box and creates the appropriate cylinder difference(){ $fn=boxCornerSmoothness; minkowski(){ cube([lidOverlap + boxLength + lidTolerance - (2 * boxCornerRoundness), lidOverlap + boxWidth + lidTolerance - (2 * boxCornerRoundness), ((lidThickness + lidLipHeight)/2)], center=true); cylinder(r=boxCornerRoundness, h=((lidThickness + lidLipHeight)/2), center=true); } translate([0,0,-lidThickness/2 ]) { $fn=boxCornerSmoothness; minkowski() { cube([boxLength + lidTolerance - (2 * boxCornerRoundness) , boxWidth + lidTolerance - (2 * boxCornerRoundness), lidLipHeight+booleanOverlap],center = true); cylinder(r=boxCornerRoundness,h=lidLipHeight/2, center = true); } } translate([0,(boxCornerRoundness + lidTolerance + lidOverlap+booleanOverlap),-lidThickness/2]) cube([boxLength + lidTolerance - (2 * boxCornerRoundness) , boxWidth + lidTolerance - (2 * boxCornerRoundness), lidLipHeight +booleanOverlap],center = true); } -- View this message in context: http://forum.openscad.org/Frustrating-unexpected-behavior-tp12321.html Sent from the OpenSCAD mailing list archive at Nabble.com.
PF
Peter Falke
Mon, Apr 6, 2015 11:11 PM
I`m sorry. I cant quiet understand what you problem is.
What numbers? What are you trying to do?
2015-04-06 23:37 GMT+02:00 linkreincarnate linkreincarnate@gmail.com:
and
boxLength = 90.4;
boxWidth = 81.25;
boxHeight = 19.2;
boxArcHeight = 3.5;
boxArcRadius=1;
lidLipHeight = 2;
lidThickness = 2;
lidTolerance = 1;
lidOverlap = 2;
trackWidth = 2.5;
trackLength = 61;
trackHeight = 14;
rollerDiameter = 7;
rollerLength = 71;
pinLength= 71;
pinTolerance = 1;
line up
arched = false;
minkowski(){
center=true);
center=true);
                     minkowski()
center = true);
true);
schreiben.
Enjoy!
I`m sorry. I cant quiet understand what you problem is. What numbers? What are you trying to do? 2015-04-06 23:37 GMT+02:00 linkreincarnate <linkreincarnate@gmail.com>: > So I am trying to make a lid for a hinged box. I am getting some > unpredictable results with it though. I need to be able to make a cutout > of the lip of the box at the level where the lid ends and the lip begins > and > to place a hinge part there. But when I change the numbers around to > anything other than a 1:1 ratio on the two numbers that control the > thickness I am unable to predict where the transition from lid to lip > begins. I have been working on this particular problem since yesterday and > I am being stumped. What am I missing here? > > boxLength = 90.4; > boxWidth = 81.25; > boxHeight = 19.2; > boxBottomThickness = .67; > boxWallThickness = .67; > boxArcHeight = 3.5; > boxArcRadius=1; > boxControlArmHoleZOffset = 3.5; > boxControlArmHoleYOffset = 3; > boxHingePinDiameter = 3; > boxHingeDiameter= 5; > boxHingeZOffset = 0; > boxHingeYOffset = 0; > boxHingeTolerance = .1; > boxHingeSupportZOffset= -5; > boxHingeSupportYOffset = -4.5; > boxHingeNumberOfSplits = 7; > boxHingeClearance=1; > //the following variables determine the details of the cylinder (or sphere) > used for minkowski sums > boxCornerRoundness = 7; > boxCornerSmoothness = 16; > boxRoundCorners = true; > > controlArmLength = 0; > controlArmHeight = 0; > conrolArmThickness = 0; > controlArmPinDiameter = 2; > controlArmHoleZOffset = 0; > controlArmHoleYOffset = 0; > controlArmPinTolerance = .1; > > lidLipHeight = 2; > lidThickness = 2; > lidTolerance = 1; > lidHingeZOffset = 0; > lidHingeYOffset = 0; > lidHingeTolerance = 1; > lidOverlap = 2; > > dispenserHoleLength = 72; //also used for dist between tracks > dispenserHoleWidth = 11.5; > dispenserHoleXOffset = 0; > dispenserHoleYOffset = 0; > > trackPanelLength = 76; > trackPanelHeight = 19; > trackPanelThickness = 3; > trackWidth = 2.5; > trackLength = 61; > trackHeight = 14; > > rollerDiameter = 7; > rollerLength = 71; > > rollerPinDiameter = 2; > hingePinDiameter = 1.6; > pinLength= 71; > > pinTolerance = 1; > cigaretteDiameter = 7.75; > cigaretteLength = 70; > > booleanOverlap = .01; //to ensure that the faces used to difference() dont > line up > > lowRollingClearance = 5; //the distance from the center of the rolling pin > to the lid at the lowest point. > hightRollingClearance = 12.6; > > arched = false; > //uses math to determine the arc radius of the curve of the box and creates > the appropriate cylinder > > > difference(){ > $fn=boxCornerSmoothness; > minkowski(){ > cube([lidOverlap + boxLength + lidTolerance - (2 * > boxCornerRoundness), > lidOverlap + boxWidth + lidTolerance - (2 * > boxCornerRoundness), > ((lidThickness + lidLipHeight)/2)], > center=true); > cylinder(r=boxCornerRoundness, > h=((lidThickness + lidLipHeight)/2), > center=true); > } > > translate([0,0,-lidThickness/2 ]) > { > $fn=boxCornerSmoothness; > minkowski() > { > cube([boxLength + lidTolerance - (2 * > boxCornerRoundness) , > boxWidth + lidTolerance - (2 * > boxCornerRoundness), > lidLipHeight+booleanOverlap],center = true); > cylinder(r=boxCornerRoundness,h=lidLipHeight/2, > center = true); > } > } > translate([0,(boxCornerRoundness + lidTolerance + > lidOverlap+booleanOverlap),-lidThickness/2]) > cube([boxLength + lidTolerance - (2 * > boxCornerRoundness) , > boxWidth + lidTolerance - (2 * > boxCornerRoundness), > lidLipHeight +booleanOverlap],center = > true); > } > > > > -- > View this message in context: > http://forum.openscad.org/Frustrating-unexpected-behavior-tp12321.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > -- stempeldergeschichte@googlemail.com <karsten@rohrbach.de> P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu schreiben. Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. P.S. In case my e-mail is shorter than you enjoy: I am currently trying short replies instead of no replies at all. Please let me know, if you like to read more. Enjoy!
linkreincarnate
Tue, Apr 7, 2015 12:11 AM
I found the issue actually.  I missed a divide by 2 in the box I was
subtracting so that box grew faster than the other for large ratios.  It's
fixed now.  Thanks for the rubberduck code review.
View this message in context: http://forum.openscad.org/Frustrating-unexpected-behavior-tp12321p12324.html
I found the issue actually. I missed a divide by 2 in the box I was subtracting so that box grew faster than the other for large ratios. It's fixed now. Thanks for the rubberduck code review. -- View this message in context: http://forum.openscad.org/Frustrating-unexpected-behavior-tp12321p12324.html Sent from the OpenSCAD mailing list archive at Nabble.com.
linkreincarnate
Tue, Apr 7, 2015 3:36 AM
OK So I can make the lid just fine but when my lidThickness to lidLipHeight
ratio is not 1:1 the hinge placement and cutouts get skewed in the direction
of the bigger number.
It's probably easier to show it than to keep trying to explain though.
http://forum.openscad.org/file/n12325/IdealHingePlacement.png
This is a pic of the hinge in it's proper placement.  So long as my
lidThickness = lidLipHeight the hinge always gets aligned to the right spot
no matter what the two number are.
http://forum.openscad.org/file/n12325/lidLipHeightTooHigh_.png
This is a pic of the hinge when lidThickness is smaller than lidLipHeight.
As you can see the hinge is higher off of the lid and the cutouts are very
shallow.
http://forum.openscad.org/file/n12325/lidThicknessTooHigh.png
This is a picture of the hinge when the lidThickness is larger than the
lidLipHeight.  As you can see now the hinge is too low and there is not
enough clearance for proper operation.
How can I fix my file so that no matter what values I enter for lidThickness
and lidLipHeight the hinge will always be at the proper height?
View this message in context: http://forum.openscad.org/Frustrating-unexpected-behavior-tp12321p12325.html
OK So I can make the lid just fine but when my lidThickness to lidLipHeight ratio is not 1:1 the hinge placement and cutouts get skewed in the direction of the bigger number. It's probably easier to show it than to keep trying to explain though. <http://forum.openscad.org/file/n12325/IdealHingePlacement.png> This is a pic of the hinge in it's proper placement. So long as my lidThickness = lidLipHeight the hinge always gets aligned to the right spot no matter what the two number are. <http://forum.openscad.org/file/n12325/lidLipHeightTooHigh_.png> This is a pic of the hinge when lidThickness is smaller than lidLipHeight. As you can see the hinge is higher off of the lid and the cutouts are very shallow. <http://forum.openscad.org/file/n12325/lidThicknessTooHigh.png> This is a picture of the hinge when the lidThickness is larger than the lidLipHeight. As you can see now the hinge is too low and there is not enough clearance for proper operation. How can I fix my file so that no matter what values I enter for lidThickness and lidLipHeight the hinge will always be at the proper height? -- View this message in context: http://forum.openscad.org/Frustrating-unexpected-behavior-tp12321p12325.html Sent from the OpenSCAD mailing list archive at Nabble.com.
linkreincarnate
Tue, Apr 7, 2015 3:44 AM
//Here is the entire openscad file it uses no external libraries or modules
so you should be able to just copy paste it from here
//3d printable cigarette rolling machine
//Created By LinkReincarnate
//CC Share Alike Attribution Non-Commercial
//*****VARIABLE DECLARATION SECTION all values are in mm
boxLength = 90.4;
boxWidth = 81.25;
boxHeight = 19.2;
boxArcHeight = 3.5;
boxArcRadius=1;
lidLipHeight = 5;
lidThickness = 5;
lidTolerance = 1;
lidHingeZOffset = -boxHeight/2;
lidOverlap = 2;
hingeSlotXOffset = 0;
hingeSlotYOffset = 0;
hingeSlotZOffset = 0;
trackWidth = 2.5;
trackLength = 61;
trackHeight = 14;
rollerDiameter = 7;
rollerLength = 71;
pinLength= 71;
pinTolerance = 1;
line up
arched = false;
//uses math to determin the arc radius of the curve of the box and creates
//MODULE DECLARATION SECTION**************
module CreateArc(            arcLength,
arcHeight,
cylinderHeight)
carveRadius = ((arcHeight/2)+((arcLength *
arcLength)/arcHeight * 8)/(53));
                            rotate(a=[90,180,90]){
                                translate([0,-carveRadius + arcHeight -
(boxHeight/2),0]){
cylinder(r=carveRadius,
h=cylinderHeight+booleanOverlap, $fn=1024, center=true);
module CreateNonArchedBody(  boxLength,
boxWidth,
boxHeight,
boxBottomThickness,
boxWallThickness,
boxRoundCorners,
boxCornerRoundness,
boxCornerSmoothness,
boxHingeDiameter,
boxHingePinDiameter,
boxHingeZOffset,
boxHingeYOffset,
boxHingeTolerance,
boxHingeClearance,
boxHingeNumberOfSplits,
pinTolerance,
controlArmPinDiameter,
boxControlArmHoleZOffset,
boxControlArmHoleYOffset,
controlArmPinTolerance,
boxHingeSupportZOffset,
boxHingeSupportYOffset,
booleanOverlap){
//union joins the difference of the outer and inner bodies with a pinhole
for the arms and the hinge parts
union(){
//create body
if (boxRoundCorners){
translate([0,0,boxHingeSupportZOffset])
minkowski(){
cube([boxLength-(2boxCornerRoundness),boxWidth -
(2
boxCornerRoundness),boxHeight/2],
center = true);
cylinder(r=boxCornerRoundness,h=boxHeight/2);
translate([0,0,(boxBottomThickness/2)]) {
minkowski()
cube([boxLength -
boxWallThickness-(2boxCornerRoundness),
boxWidth - boxWallThickness
-(2
(((boxHeight/2) - boxBottomThickness) +
booleanOverlap)],
center = true);
//create pinholes to connect control arms
rotate(a=[0, -90, 0]){
translate([boxControlArmHoleZOffset,boxControlArmHoleYOffset,0]){
cylinder(d= (controlArmPinDiameter +
controlArmPinTolerance),
boxLength + booleanOverlap,
center=true );
     } else {
                cube([boxLength,boxWidth,boxHeight],
                     center = true);
                    cube([boxLength - boxWallThickness,
                          boxWidth - boxWallThickness,
                          ((boxHeight - boxBottomThickness) +
booleanOverlap)],
center = true);
center=true );
     CreateHinge(boxRoundCorners,
                 boxWidth,
                 boxLength,
                 boxHeight,
                 boxHingeDiameter,
                 boxHingeZOffset,
                 boxHingeYOffset,
                 boxHingeTolerance,
                 boxHingeClearance,
                 pinTolerance,
                 lidHingeZOffset,
                 lidHingeYOffset,
                 lidHingeTolerance,
                 booleanOverlap);
 }// end of union body and hinge
}//end of module
module CreateArchedBody(    boxLength,
boxWidth,
boxHeight,
boxBottomThickness,
boxWallThickness,
boxRoundCorners,
boxCornerRoundness,
boxHingeDiameter,
boxHingeZOffset,
boxHingeYOffset,
boxHingeTolerance,
boxHingeClearance,
pinTolerance,
booleanOverlap,
boxArcHeight,
boxArcRadius
union(){
//create body
translate([0,0,boxHingeSupportZOffset+boxArcHeight+1])
intersection(){
minkowski(){
boxWidth -
(2
boxHeight+boxArcHeight/2],
center = true);
cylinder(r=boxCornerRoundness,h=boxHeight + boxArcHeight/2);
translate([0,0,-boxHeight+boxArcHeight])
CreateArc(boxWidth,
boxArcHeight, boxLength);
translate([0,0,(boxBottomThickness/2)]){
intersection(){
minkowski(){
cube([boxLength -
boxWidth -
boxWallThickness -(2
(((boxHeight+boxArcHeight/2) - boxBottomThickness) + booleanOverlap)],
center =
true);
CreateArc(boxWidth,
control arms
cylinder(d=
boxLength +
booleanOverlap,
center=true
                                        CreateArc(boxWidth,
boxArcHeight, boxLength+booleanOverlap);
//insert objects here to
difference them from the main body
} else {
intersection(){
cube([boxLength,boxWidth,boxHeight+boxArcHeight],
center = true);
translate([0,0,-boxHeight+boxArcHeight]){
CreateArc(boxWidth,
                                        intersection(){
cube([boxLength -
boxWallThickness,
boxWidth -
boxWallThickness,
((boxHeight
+boxArcHeight - boxBottomThickness) + booleanOverlap)],
center = true);
CreateArc(boxWidth,
control arms
cylinder(d=
boxLength +
booleanOverlap,
center=true
CreateArc(boxWidth,boxArcHeight,boxLength + booleanOverlap);
//insert here to difference with
body
//Create Hinge and hinge support
CreateHinge( boxRoundCorners,
boxWidth,
boxLength,
boxHeight,
boxHingeDiameter,
boxHingeZOffset,
boxHingeYOffset,
boxHingeTolerance,
boxHingeClearance,
pinTolerance,
lidHingeZOffset,
lidHingeYOffset,
lidHingeTolerance,
booleanOverlap);
//insert new parts to be added to the body
here
}//end of module
module CreateNonArchedLid(          lidLipHeight,
lidThickness,
lidTolerance,
lidHingeZOffset,
lidHingeYOffset,
lidHingeTolerance,
lidOverlap,
hingeSlotXOffset,
hingeSlotYOffset,
hingeSlotZOffset,
boxLength,
boxWidth,
boxHeight,
boxRoundCorners,
boxCornerRoundness,
boxHingeDiameter,
dispenserHoleLength,
dispenserHoleWidth,
dispenserHoleXOffset,
dispenserHoleYOffset,
rollerLength,
booleanOverlap)
minkowski(){
cylinder(r=boxCornerRoundness,h=((lidThickness +
                translate([0,0,(-lidThickness/2)-booleanOverlap ]){
                    minkowski()
lidLipHeight/2],center = true);
center = true);
                //hingeslots
                //here the part to be subtracted from the hinge is
created
                    translate([0,((boxWidth / 2)+(lidHingeYOffset +
(boxHingeDiameter/2))),((boxHeight/2)+lidHingeZOffset)]){
rotate(a=[0,270,0])
translate([0,0,-boxLength/2 ]){
for ( i = [0 :
boxHingeNumberOfSplits/2] )
                                                        translate([0, 0,
boxLength/boxHingeNumberOfSplits * i *2])
cylinder(d=boxHingeDiameter+boxHingeTolerance+booleanOverlap +
boxHingeClearance,
(boxLength/boxHingeNumberOfSplits) + boxHingeTolerance + lidHingeTolerance,
center=true);
                    translate([boxLength/2-lidOverlap -
lidTolerance,0,0]){
cube([boxCornerRoundness+booleanOverlap+lidTolerance,1000,1000],
center=true);
translate([-(boxLength/2-lidOverlap -
lidTolerance),0,0]){
center=true);
                }//end of hinge slot subtration
         } // end of difference
     } else {
                     center = true);
booleanOverlap)],
center = true);
center=true );
}//end of Lid Module
module CreateArchedLid(            lidLipHeight,
lidThickness,
lidTolerance,
lidHingeZOffset,
lidHingeYOffset,
lidHingeTolerance,
boxLength,
boxWidth,
boxHeight,
boxRoundCorners,
boxCornerRoundness,
boxHingeDiameter,
dispenserHoleWidth,
rollerLength,
boxArcHeight,
boxArcRadius,
booleanOverlap){}
module CreateControlArm(){}
module CreateControlTrack(){}
module CreateRoller(){}
module CreateLidHinge(  boxRoundCorners,
boxWidth,
boxLength,
boxHeight,
boxHingeDiameter,
boxHingeZOffset,
boxHingeYOffset,
boxHingeTolerance,
boxHingeClearance,
pinTolerance,
lidHingeZOffset,
lidHingeYOffset,
lidHingeTolerance,
booleanOverlap)
union(){
//hingepart is created here
rotate(a=[0,-90,0]){
cylinder(d=boxHingeDiameter, boxLength -
(boxCornerRoundness * 2),center=true);
    } else {
cylinder(d=boxHingeDiameter, boxLength,center=true);
//add geometry to the hinge here
//hingehole
cylinder(d=boxHingePinDiameter, boxLength +
booleanOverlap,center=true);
//hingeslots
//here the part to be subtracted from the hinge is created
rotate(a=[0,270,0])
for ( i = [0 : boxHingeNumberOfSplits/2]
                                        translate([0, 0,
boxHingeClearance,
center=true);
} //end of hinge slots
}//end of difference (hinge, hingehole, hingeslots)
module CreateHinge(  boxRoundCorners,
boxWidth,
boxLength,
boxHeight,
boxHingeDiameter,
boxHingeZOffset,
boxHingeYOffset,
boxHingeTolerance,
boxHingeClearance,
pinTolerance,
lidHingeZOffset,
lidHingeYOffset,
lidHingeTolerance,
booleanOverlap)
//difference to create hole in hinge and hinge slots
   union(){
        translate([0,((boxWidth / 2)+(boxHingeYOffset +
(boxHingeDiameter/2))),((boxHeight/2)+boxHingeZOffset)]){
    } else {
           translate([0,((boxWidth / 2)+(boxHingeYOffset+ +
//support part is created here, also this part is unioned to the
hingepart
if(boxRoundCorners){
2)+(boxHingeYOffset+boxHingeSupportYOffset)),((boxHeight/2)+boxHingeZOffset
+boxHingeSupportZOffset)]){
rotate(a=[0,0,-25]){
cylinder(d=boxHingeDiameter4,
(boxLength-(boxCornerRoundness * 2)), $fn=4,center=true);
rotate(a=[0,0,45]){
translate([-4.5, -4.5,0]){
6, boxLength+1,
$fn=4,center=true);
translate([21.1,-1,0]){
cylinder(d=boxHingeDiameter*6, boxLength+1,
$fn=4,center=true);
     }else{
cylinder(d=boxHingeDiameter4, boxLength,
$fn=4,center=true);
rotate(a=[0,0,45]){
6, boxLength+1,
$fn=4,center=true);
$fn=4,center=true);
}//end of else  end of addition of geomotry
//hingehole
translate([0, ((boxWidth / 2) + (boxHingeYOffset+boxHingeDiameter/2)),
cylinder(d=boxHingePinDiameter, boxLength + booleanOverlap,center=true);
//hingeslots
rotate(a=[0,90,0])
translate([0,0,(-boxLength/2) ]){
for ( i = [0 : boxHingeNumberOfSplits/2] ){
                        translate([0, 0,
boxHingeClearance,
boxHingeTolerance,
center=true);
}//end of Hinge Module
//END OF
DECLARATIONS
if(arched){
boxWidth,
boxHeight,
boxBottomThickness,
boxWallThickness,
boxRoundCorners,
boxCornerRoundness,
boxHingeDiameter,
boxHingeZOffset,
boxHingeYOffset,
boxHingeTolerance,
boxHingeClearance,
pinTolerance,
booleanOverlap,
boxArcHeight,
boxArcRadius
}else{
boxWidth,
boxHeight,
boxBottomThickness,
boxWallThickness,
boxRoundCorners,
boxCornerRoundness,
boxHingeDiameter,
boxHingeZOffset,
boxHingeYOffset,
boxHingeTolerance,
boxHingeClearance,
pinTolerance,
booleanOverlap,
boxArcHeight,
boxArcRadius);
translate([0,0,boxHeight/2])
union(){
boxWidth,
boxLength,
boxHeight,
boxHingeDiameter,
boxHingeZOffset,
boxHingeYOffset,
boxHingeTolerance,
boxHingeClearance,
pinTolerance,
lidHingeZOffset,
lidHingeYOffset,
lidHingeTolerance,
booleanOverlap);
                                    lidThickness,
                                    lidTolerance,
                                    lidHingeZOffset,
                                    lidHingeYOffset,
                                    lidHingeTolerance,
                                    lidOverlap,
                                    hingeSlotXOffset,
                                    hingeSlotYOffset,
                                    hingeSlotZOffset,
                                    boxLength,
                                    boxWidth,
                                    boxHeight,
                                    boxRoundCorners,
                                    boxCornerRoundness,
                                    boxHingeDiameter,
                                    dispenserHoleWidth,
                                    rollerLength,
                                    booleanOverlap);
View this message in context: http://forum.openscad.org/Frustrating-unexpected-behavior-tp12321p12326.html
//Here is the entire openscad file it uses no external libraries or modules so you should be able to just copy paste it from here //3d printable cigarette rolling machine //Created By LinkReincarnate //CC Share Alike Attribution Non-Commercial //*************VARIABLE DECLARATION SECTION******** all values are in mm { boxLength = 90.4; boxWidth = 81.25; boxHeight = 19.2; boxBottomThickness = .67; boxWallThickness = .67; boxArcHeight = 3.5; boxArcRadius=1; boxControlArmHoleZOffset = 3.5; boxControlArmHoleYOffset = 3; boxHingePinDiameter = 3; boxHingeDiameter= 5; boxHingeZOffset = 0; boxHingeYOffset = 0; boxHingeTolerance = .1; boxHingeSupportZOffset= -5; boxHingeSupportYOffset = -4.5; boxHingeNumberOfSplits = 7; boxHingeClearance=1; //the following variables determine the details of the cylinder (or sphere) used for minkowski sums boxCornerRoundness = 7; boxCornerSmoothness = 16; boxRoundCorners = true; controlArmLength = 0; controlArmHeight = 0; conrolArmThickness = 0; controlArmPinDiameter = 2; controlArmHoleZOffset = 0; controlArmHoleYOffset = 0; controlArmPinTolerance = .1; lidLipHeight = 5; lidThickness = 5; lidTolerance = 1; lidHingeZOffset = -boxHeight/2; lidHingeYOffset = 0; lidHingeTolerance = 1; lidOverlap = 2; hingeSlotXOffset = 0; hingeSlotYOffset = 0; hingeSlotZOffset = 0; dispenserHoleLength = 72; //also used for dist between tracks dispenserHoleWidth = 11.5; dispenserHoleXOffset = 0; dispenserHoleYOffset = 0; trackPanelLength = 76; trackPanelHeight = 19; trackPanelThickness = 3; trackWidth = 2.5; trackLength = 61; trackHeight = 14; rollerDiameter = 7; rollerLength = 71; rollerPinDiameter = 2; hingePinDiameter = 1.6; pinLength= 71; pinTolerance = 1; cigaretteDiameter = 7.75; cigaretteLength = 70; booleanOverlap = .01; //to ensure that the faces used to difference() dont line up lowRollingClearance = 5; //the distance from the center of the rolling pin to the lid at the lowest point. hightRollingClearance = 12.6; arched = false; //uses math to determin the arc radius of the curve of the box and creates the appropriate cylinder } //*************MODULE DECLARATION SECTION*************************** module CreateArc( arcLength, arcHeight, cylinderHeight) { carveRadius = ((arcHeight/2)+((arcLength * arcLength)/arcHeight * 8)/(53)); rotate(a=[90,180,90]){ translate([0,-carveRadius + arcHeight - (boxHeight/2),0]){ cylinder(r=carveRadius, h=cylinderHeight+booleanOverlap, $fn=1024, center=true); } } } module CreateNonArchedBody( boxLength, boxWidth, boxHeight, boxBottomThickness, boxWallThickness, boxRoundCorners, boxCornerRoundness, boxCornerSmoothness, boxHingeDiameter, boxHingePinDiameter, boxHingeZOffset, boxHingeYOffset, boxHingeTolerance, boxHingeClearance, boxHingeNumberOfSplits, pinTolerance, controlArmPinDiameter, boxControlArmHoleZOffset, boxControlArmHoleYOffset, controlArmPinTolerance, boxHingeSupportZOffset, boxHingeSupportYOffset, booleanOverlap){ //union joins the difference of the outer and inner bodies with a pinhole for the arms and the hinge parts union(){ //create body if (boxRoundCorners){ translate([0,0,boxHingeSupportZOffset]) difference(){ $fn=boxCornerSmoothness; minkowski(){ cube([boxLength-(2*boxCornerRoundness),boxWidth - (2*boxCornerRoundness),boxHeight/2], center = true); cylinder(r=boxCornerRoundness,h=boxHeight/2); } translate([0,0,(boxBottomThickness/2)]) { $fn=boxCornerSmoothness; minkowski() { cube([boxLength - boxWallThickness-(2*boxCornerRoundness), boxWidth - boxWallThickness -(2*boxCornerRoundness), (((boxHeight/2) - boxBottomThickness) + booleanOverlap)], center = true); cylinder(r=boxCornerRoundness,h=boxHeight/2); } } //create pinholes to connect control arms rotate(a=[0, -90, 0]){ translate([boxControlArmHoleZOffset,boxControlArmHoleYOffset,0]){ cylinder(d= (controlArmPinDiameter + controlArmPinTolerance), boxLength + booleanOverlap, center=true ); } } } } else { difference(){ cube([boxLength,boxWidth,boxHeight], center = true); translate([0,0,(boxBottomThickness/2)]) { cube([boxLength - boxWallThickness, boxWidth - boxWallThickness, ((boxHeight - boxBottomThickness) + booleanOverlap)], center = true); } //create pinholes to connect control arms rotate(a=[0, -90, 0]){ translate([boxControlArmHoleZOffset,boxControlArmHoleYOffset,0]){ cylinder(d= (controlArmPinDiameter + controlArmPinTolerance), boxLength + booleanOverlap, center=true ); } } } } CreateHinge(boxRoundCorners, boxWidth, boxLength, boxHeight, boxHingeDiameter, boxHingePinDiameter, boxHingeZOffset, boxHingeYOffset, boxHingeTolerance, boxHingeClearance, boxHingeNumberOfSplits, pinTolerance, boxHingeSupportZOffset, boxHingeSupportYOffset, lidHingeZOffset, lidHingeYOffset, lidHingeTolerance, booleanOverlap); }// end of union body and hinge }//end of module module CreateArchedBody( boxLength, boxWidth, boxHeight, boxBottomThickness, boxWallThickness, boxRoundCorners, boxCornerRoundness, boxCornerSmoothness, boxHingeDiameter, boxHingePinDiameter, boxHingeZOffset, boxHingeYOffset, boxHingeTolerance, boxHingeClearance, boxHingeNumberOfSplits, pinTolerance, controlArmPinDiameter, boxControlArmHoleZOffset, boxControlArmHoleYOffset, controlArmPinTolerance, boxHingeSupportZOffset, boxHingeSupportYOffset, booleanOverlap, boxArcHeight, boxArcRadius ){ union(){ //create body if (boxRoundCorners){ translate([0,0,boxHingeSupportZOffset+boxArcHeight+1]) difference(){ intersection(){ $fn=boxCornerSmoothness; minkowski(){ cube([boxLength-(2*boxCornerRoundness), boxWidth - (2*boxCornerRoundness), boxHeight+boxArcHeight/2], center = true); cylinder(r=boxCornerRoundness,h=boxHeight + boxArcHeight/2); } translate([0,0,-boxHeight+boxArcHeight]) CreateArc(boxWidth, boxArcHeight, boxLength); } translate([0,0,(boxBottomThickness/2)]){ intersection(){ $fn=boxCornerSmoothness; minkowski(){ cube([boxLength - boxWallThickness-(2*boxCornerRoundness), boxWidth - boxWallThickness -(2*boxCornerRoundness), (((boxHeight+boxArcHeight/2) - boxBottomThickness) + booleanOverlap)], center = true); cylinder(r=boxCornerRoundness,h=boxHeight/2); } translate([0,0,-boxHeight+boxArcHeight]) CreateArc(boxWidth, boxArcHeight, boxLength); } } //create pinholes to connect control arms rotate(a=[0, -90, 0]){ translate([boxControlArmHoleZOffset,boxControlArmHoleYOffset,0]){ cylinder(d= (controlArmPinDiameter + controlArmPinTolerance), boxLength + booleanOverlap, center=true ); } } CreateArc(boxWidth, boxArcHeight, boxLength+booleanOverlap); //insert objects here to difference them from the main body } } else { difference(){ intersection(){ cube([boxLength,boxWidth,boxHeight+boxArcHeight], center = true); translate([0,0,-boxHeight+boxArcHeight]){ CreateArc(boxWidth, boxArcHeight, boxLength); } } intersection(){ translate([0,0,(boxBottomThickness/2)]){ cube([boxLength - boxWallThickness, boxWidth - boxWallThickness, ((boxHeight +boxArcHeight - boxBottomThickness) + booleanOverlap)], center = true); } translate([0,0,-boxHeight+boxArcHeight]){ CreateArc(boxWidth, boxArcHeight, boxLength); } } //create pinholes to connect control arms rotate(a=[0, -90, 0]){ translate([boxControlArmHoleZOffset,boxControlArmHoleYOffset,0]){ cylinder(d= (controlArmPinDiameter + controlArmPinTolerance), boxLength + booleanOverlap, center=true ); } } CreateArc(boxWidth,boxArcHeight,boxLength + booleanOverlap); //insert here to difference with body } } //Create Hinge and hinge support CreateHinge( boxRoundCorners, boxWidth, boxLength, boxHeight, boxHingeDiameter, boxHingePinDiameter, boxHingeZOffset, boxHingeYOffset, boxHingeTolerance, boxHingeClearance, boxHingeNumberOfSplits, pinTolerance, boxHingeSupportZOffset, boxHingeSupportYOffset, lidHingeZOffset, lidHingeYOffset, lidHingeTolerance, booleanOverlap); //insert new parts to be added to the body here } }//end of module module CreateNonArchedLid( lidLipHeight, lidThickness, lidTolerance, lidHingeZOffset, lidHingeYOffset, lidHingeTolerance, lidOverlap, hingeSlotXOffset, hingeSlotYOffset, hingeSlotZOffset, boxLength, boxWidth, boxHeight, boxRoundCorners, boxCornerRoundness, boxCornerSmoothness, boxHingeDiameter, boxHingePinDiameter, dispenserHoleLength, dispenserHoleWidth, dispenserHoleXOffset, dispenserHoleYOffset, rollerLength, booleanOverlap) { if (boxRoundCorners){ difference(){ $fn=boxCornerSmoothness; minkowski(){ cube([lidOverlap + boxLength + lidTolerance - (2 * boxCornerRoundness), lidOverlap + boxWidth + lidTolerance - (2 * boxCornerRoundness), ((lidThickness + lidLipHeight)/2)], center=true); cylinder(r=boxCornerRoundness,h=((lidThickness + lidLipHeight)/2), center=true); } translate([0,0,(-lidThickness/2)-booleanOverlap ]){ $fn=boxCornerSmoothness; minkowski() { cube([boxLength + lidTolerance - (2 * boxCornerRoundness) , boxWidth + lidTolerance - (2 * boxCornerRoundness), lidLipHeight/2],center = true); cylinder(r=boxCornerRoundness,h=lidLipHeight/2, center = true); } } translate([0,(boxCornerRoundness + lidTolerance + lidOverlap+booleanOverlap),-lidThickness/2]) cube([boxLength + lidTolerance - (2 * boxCornerRoundness) , boxWidth + lidTolerance - (2 * boxCornerRoundness), lidLipHeight +booleanOverlap],center = true); //hingeslots //here the part to be subtracted from the hinge is created difference(){ translate([0,((boxWidth / 2)+(lidHingeYOffset + (boxHingeDiameter/2))),((boxHeight/2)+lidHingeZOffset)]){ rotate(a=[0,270,0]) translate([0,0,-boxLength/2 ]){ for ( i = [0 : boxHingeNumberOfSplits/2] ) { translate([0, 0, boxLength/boxHingeNumberOfSplits * i *2]) cylinder(d=boxHingeDiameter+boxHingeTolerance+booleanOverlap + boxHingeClearance, (boxLength/boxHingeNumberOfSplits) + boxHingeTolerance + lidHingeTolerance, center=true); } } } translate([boxLength/2-lidOverlap - lidTolerance,0,0]){ cube([boxCornerRoundness+booleanOverlap+lidTolerance,1000,1000], center=true); } translate([-(boxLength/2-lidOverlap - lidTolerance),0,0]){ cube([boxCornerRoundness+booleanOverlap+lidTolerance,1000,1000], center=true); } }//end of hinge slot subtration } // end of difference } else { difference(){ cube([boxLength,boxWidth,boxHeight], center = true); translate([0,0,(boxBottomThickness/2)]) { cube([boxLength - boxWallThickness, boxWidth - boxWallThickness, ((boxHeight - boxBottomThickness) + booleanOverlap)], center = true); } //create pinholes to connect control arms rotate(a=[0, -90, 0]){ translate([boxControlArmHoleZOffset,boxControlArmHoleYOffset,0]){ cylinder(d= (controlArmPinDiameter + controlArmPinTolerance), boxLength + booleanOverlap, center=true ); } } } } }//end of Lid Module module CreateArchedLid( lidLipHeight, lidThickness, lidTolerance, lidHingeZOffset, lidHingeYOffset, lidHingeTolerance, boxLength, boxWidth, boxHeight, boxRoundCorners, boxCornerRoundness, boxCornerSmoothness, boxHingeDiameter, boxHingePinDiameter, dispenserHoleLength, dispenserHoleWidth, dispenserHoleXOffset, dispenserHoleYOffset, rollerLength, boxArcHeight, boxArcRadius, booleanOverlap){} module CreateControlArm(){} module CreateControlTrack(){} module CreateRoller(){} module CreateLidHinge( boxRoundCorners, boxWidth, boxLength, boxHeight, boxHingeDiameter, boxHingePinDiameter, boxHingeZOffset, boxHingeYOffset, boxHingeTolerance, boxHingeClearance, boxHingeNumberOfSplits, pinTolerance, boxHingeSupportZOffset, boxHingeSupportYOffset, lidHingeZOffset, lidHingeYOffset, lidHingeTolerance, booleanOverlap) { difference(){ union(){ //hingepart is created here if (boxRoundCorners){ translate([0,((boxWidth / 2)+(lidHingeYOffset + (boxHingeDiameter/2))),((boxHeight/2)+lidHingeZOffset)]){ rotate(a=[0,-90,0]){ cylinder(d=boxHingeDiameter, boxLength - (boxCornerRoundness * 2),center=true); } } } else { translate([0,((boxWidth / 2)+(lidHingeYOffset + (boxHingeDiameter/2))),((boxHeight/2)+lidHingeZOffset)]){ rotate(a=[0,-90,0]){ cylinder(d=boxHingeDiameter, boxLength,center=true); } } } //add geometry to the hinge here } //hingehole translate([0,((boxWidth / 2)+(lidHingeYOffset + (boxHingeDiameter/2))),((boxHeight/2)+lidHingeZOffset)]){ rotate(a=[0,-90,0]){ cylinder(d=boxHingePinDiameter, boxLength + booleanOverlap,center=true); } } //hingeslots //here the part to be subtracted from the hinge is created translate([0,((boxWidth / 2)+(lidHingeYOffset + (boxHingeDiameter/2))),((boxHeight/2)+lidHingeZOffset)]){ rotate(a=[0,270,0]) translate([0,0,-boxLength/2 ]){ for ( i = [0 : boxHingeNumberOfSplits/2] ) { translate([0, 0, boxLength/boxHingeNumberOfSplits * i *2]) cylinder(d=boxHingeDiameter+boxHingeTolerance+booleanOverlap + boxHingeClearance, (boxLength/boxHingeNumberOfSplits) + boxHingeTolerance + lidHingeTolerance, center=true); } } } //end of hinge slots }//end of difference (hinge, hingehole, hingeslots) } module CreateHinge( boxRoundCorners, boxWidth, boxLength, boxHeight, boxHingeDiameter, boxHingePinDiameter, boxHingeZOffset, boxHingeYOffset, boxHingeTolerance, boxHingeClearance, boxHingeNumberOfSplits, pinTolerance, boxHingeSupportZOffset, boxHingeSupportYOffset, lidHingeZOffset, lidHingeYOffset, lidHingeTolerance, booleanOverlap) { //Create Hinge and hinge support //difference to create hole in hinge and hinge slots difference(){ union(){ //hingepart is created here if (boxRoundCorners){ translate([0,((boxWidth / 2)+(boxHingeYOffset + (boxHingeDiameter/2))),((boxHeight/2)+boxHingeZOffset)]){ rotate(a=[0,-90,0]){ cylinder(d=boxHingeDiameter, boxLength - (boxCornerRoundness * 2),center=true); } } } else { translate([0,((boxWidth / 2)+(boxHingeYOffset+ + (boxHingeDiameter/2))),((boxHeight/2)+boxHingeZOffset)]){ rotate(a=[0,-90,0]){ cylinder(d=boxHingeDiameter, boxLength,center=true); } } } //support part is created here, also this part is unioned to the hingepart if(boxRoundCorners){ translate([0,((boxWidth / 2)+(boxHingeYOffset+boxHingeSupportYOffset)),((boxHeight/2)+boxHingeZOffset +boxHingeSupportZOffset)]){ rotate(a=[0,-90,0]){ difference(){ rotate(a=[0,0,-25]){ cylinder(d=boxHingeDiameter*4, (boxLength-(boxCornerRoundness * 2)), $fn=4,center=true); } rotate(a=[0,0,45]){ translate([-4.5, -4.5,0]){ cylinder(d=boxHingeDiameter*6, boxLength+1, $fn=4,center=true); } translate([21.1,-1,0]){ cylinder(d=boxHingeDiameter*6, boxLength+1, $fn=4,center=true); } } } } } }else{ translate([0,((boxWidth / 2)+(boxHingeYOffset+boxHingeSupportYOffset)),((boxHeight/2)+boxHingeZOffset +boxHingeSupportZOffset)]){ rotate(a=[0,-90,0]){ difference(){ rotate(a=[0,0,-25]){ cylinder(d=boxHingeDiameter*4, boxLength, $fn=4,center=true); } rotate(a=[0,0,45]){ translate([-4.5, -4.5,0]){ cylinder(d=boxHingeDiameter*6, boxLength+1, $fn=4,center=true); } translate([21.1,-1,0]){ cylinder(d=boxHingeDiameter*6, boxLength+1, $fn=4,center=true); } } } } } }//end of else end of addition of geomotry } //hingehole translate([0, ((boxWidth / 2) + (boxHingeYOffset+boxHingeDiameter/2)), ((boxHeight/2)+boxHingeZOffset)]){ rotate(a=[0,-90,0]){ cylinder(d=boxHingePinDiameter, boxLength + booleanOverlap,center=true); } } //hingeslots //here the part to be subtracted from the hinge is created translate([0,((boxWidth / 2)+(boxHingeYOffset + (boxHingeDiameter/2))),((boxHeight/2)+boxHingeZOffset)]){ rotate(a=[0,90,0]) translate([0,0,(-boxLength/2) ]){ for ( i = [0 : boxHingeNumberOfSplits/2] ){ translate([0, 0, boxLength/boxHingeNumberOfSplits * i *2]) cylinder(d=boxHingeDiameter+boxHingeTolerance+booleanOverlap + boxHingeClearance, (boxLength/boxHingeNumberOfSplits) + boxHingeTolerance, center=true); } } } //end of hinge slots }//end of difference (hinge, hingehole, hingeslots) }//end of Hinge Module //**********************END OF DECLARATIONS*********************************** /* if(arched){ CreateArchedBody( boxLength, boxWidth, boxHeight, boxBottomThickness, boxWallThickness, boxRoundCorners, boxCornerRoundness, boxCornerSmoothness, boxHingeDiameter, boxHingePinDiameter, boxHingeZOffset, boxHingeYOffset, boxHingeTolerance, boxHingeClearance, boxHingeNumberOfSplits, pinTolerance, controlArmPinDiameter, boxControlArmHoleZOffset, boxControlArmHoleYOffset, controlArmPinTolerance, boxHingeSupportZOffset, boxHingeSupportYOffset, booleanOverlap, boxArcHeight, boxArcRadius ); }else{ CreateNonArchedBody( boxLength, boxWidth, boxHeight, boxBottomThickness, boxWallThickness, boxRoundCorners, boxCornerRoundness, boxCornerSmoothness, boxHingeDiameter, boxHingePinDiameter, boxHingeZOffset, boxHingeYOffset, boxHingeTolerance, boxHingeClearance, boxHingeNumberOfSplits, pinTolerance, controlArmPinDiameter, boxControlArmHoleZOffset, boxControlArmHoleYOffset, controlArmPinTolerance, boxHingeSupportZOffset, boxHingeSupportYOffset, booleanOverlap, boxArcHeight, boxArcRadius); } */ translate([0,0,boxHeight/2]) { union(){ CreateLidHinge( boxRoundCorners, boxWidth, boxLength, boxHeight, boxHingeDiameter, boxHingePinDiameter, boxHingeZOffset, boxHingeYOffset, boxHingeTolerance, boxHingeClearance, boxHingeNumberOfSplits, pinTolerance, boxHingeSupportZOffset, boxHingeSupportYOffset, lidHingeZOffset, lidHingeYOffset, lidHingeTolerance, booleanOverlap); CreateNonArchedLid( lidLipHeight, lidThickness, lidTolerance, lidHingeZOffset, lidHingeYOffset, lidHingeTolerance, lidOverlap, hingeSlotXOffset, hingeSlotYOffset, hingeSlotZOffset, boxLength, boxWidth, boxHeight, boxRoundCorners, boxCornerRoundness, boxCornerSmoothness, boxHingeDiameter, boxHingePinDiameter, dispenserHoleLength, dispenserHoleWidth, dispenserHoleXOffset, dispenserHoleYOffset, rollerLength, booleanOverlap); } } -- View this message in context: http://forum.openscad.org/Frustrating-unexpected-behavior-tp12321p12326.html Sent from the OpenSCAD mailing list archive at Nabble.com.
