JW
Joe Weinpert
Thu, Jan 13, 2022 9:04 PM
Been looking at the suggestions in using the BOSL2 mods and functions. Ran
through the "star" demo.
As to the odd shapes I referred to in a previous email, it was suggested to
use something like this:
include<BOSL2/std.scad>
include<BOSL2/rounding.scad>
shape = [[3,4],[10,10],...etc]; // Shape defined as list of (x,y)
coordinates,
without repeating the first point.
offset_sweep(shape, height=1INCH, top=os_circle(r=1/4INCH));
Because I am importing pre-designed odd shapes (not generating them), is
there a way to generate a list of points from a 2D imported svg shape that
can be used in the above offset_sweep function?
coordinates,
offset_sweep(shape, height=1*INCH, top=os_circle(r=1/4*INCH));
DS
Daniel Shriver
Fri, Jan 14, 2022 3:01 AM
I'm kind of thinking aloud here and not completely sure if my suggestions
will work or not.
Isn't there some OpenSCAD function (like offset, can't remember the name)
where you can use a closed polygon, and get back a "concentric" inner
polygon?
If so, then you can do that and iterate over several linear extrudes to
generate a ziggurat top to your shape.
Alternately, you can look into the various "sweep" functions. At least one
of them (maybe even the one in your email) can apply one "shape/curvature"
to another one. I don't know if that means the rounded top will get
smaller as your polygon "narrows" at the "end points" or not.
Ran through the "star" demo.
suggested to use something like this:
shape = [[3,4],[10,10],...etc]; // Shape defined as list of (x,y) coordinates,
will work or not.
polygon?
Fri, Jan 14, 2022 5:01 AM
If you use the pathfinder library ( https://github.com/dinther/pathbuilder ) you should be able to take the path from the SVG path element and use pathfinder to decode it into an OpenSCAD path. You can then pass that to BOSL2.
-Revar
On Jan 13, 2022, at 1:05 PM, Joe Weinpert joe.weinpert@gmail.com wrote:
Been looking at the suggestions in using the BOSL2 mods and functions. Ran through the "star" demo.
As to the odd shapes I referred to in a previous email, it was suggested to use something like this:
shape = [[3,4],[10,10],...etc]; // Shape defined as list of (x,y) coordinates, without repeating the first point.
Because I am importing pre-designed odd shapes (not generating them), is there a way to generate a list of points from a 2D imported svg shape that can be used in the above offset_sweep function?
-Revar
JW
Joe Weinpert
Fri, Jan 14, 2022 7:18 PM
When running the* points_first_demo.scad demo:*
include <pathbuilder.scad>
pb_petal = "m0 -1c-25-30 25-30 0,0 z";
$pb_spline=66; // We want 36 line
segments on each spline.
pts = svgPoints(pb_petal); // Generate points list
for the svg path.
// Do your thing to the points here
for(a=[0:120:360]) rotate([0,15,a]) polygon(pts);
I get this error:
ERROR: Unable to convert points[0] = [[0, -1], [0, -1], [-1.08523,
-2.34298], [-2.07029, -3.64463], [-2.9583, -4.90496], [-3.7524, -6.12397],
[-4.45571, -7.30165], [-5.07137, -8.43802], [-5.60251, -9.53306],
[-6.05226, -10.5868], [-6.42374, -11.5992], [-6.72009, -12.5702],
[-6.94444, -13.5], [-7.09992, -14.3884], [-7.18967, -15.2355], [-7.2168,
-16.0413], [-7.18445, -16.8058], [-7.09575, -17.5289], [-6.95384,
-18.2107], [-6.76183, -18.8512], [-6.52287, -19.4504], [-6.24009,
-20.0083], [-5.9166, -20.5248], [-5.55556, -21], [-5.16007, -21.4339],
[-4.73328, -21.8264], [-4.27832, -22.1777], [-3.79831, -22.4876],
[-3.29639, -22.7562], [-2.77569, -22.9835], [-2.23934, -23.1694],
[-1.69046, -23.314], [-1.13219, -23.4174], [-0.56766, -23.4793], [0,
-23.5], [0.56766, -23.4793], [1.13219, -23.4174], [1.69046, -23.314],
[2.23934, -23.1694], [2.77569, -22.9835], [3.29639, -22.7562], [3.79831,
-22.4876], [4.27832, -22.1777], [4.73328, -21.8264], [5.16007, -21.4339],
[5.55556, -21], [5.9166, -20.5248], [6.24009, -20.0083], [6.52287,
-19.4504], [6.76183, -18.8512], [6.95384, -18.2107], [7.09575, -17.5289],
[7.18445, -16.8058], [7.2168, -16.0413], [7.18967, -15.2355], [7.09992,
-14.3884], [6.94444, -13.5], [6.72009, -12.5702], [6.42374, -11.5992],
[6.05226, -10.5868], [5.60251, -9.53306], [5.07137, -8.43802], [4.45571,
-7.30165], [3.7524, -6.12397], [2.9583, -4.90496], [2.07029, -3.64463],
[1.08523, -2.34298], [0, -1]] to a vec2 of numbers in file
points_first_demo.scad, line 7
Any ideas?
BOSL2.
-Revar
When running the* points_first_demo.scad *demo*:*
for the svg path.
I get this error:
Any ideas?
> BOSL2.
> -Revar
Sat, Jan 15, 2022 1:10 AM
You don't give your point list, so I can only guess, but from the
error it appears maybe your point list is nested too deeply, like it's
a list of lists of points instead of just a list of points. If my
guess is right then it would work if you did polygon(pts[0]).
On Fri, Jan 14, 2022 at 2:18 PM Joe Weinpert joe.weinpert@gmail.com wrote:
When running the points_first_demo.scad demo:
$pb_spline=66; // We want 36 line segments on each spline.
pts = svgPoints(pb_petal); // Generate points list for the svg path.
I get this error:
ERROR: Unable to convert points[0] = [[0, -1], [0, -1], [-1.08523, -2.34298], [-2.07029, -3.64463], [-2.9583, -4.90496], [-3.7524, -6.12397], [-4.45571, -7.30165], [-5.07137, -8.43802], [-5.60251, -9.53306], [-6.05226, -10.5868], [-6.42374, -11.5992], [-6.72009, -12.5702], [-6.94444, -13.5], [-7.09992, -14.3884], [-7.18967, -15.2355], [-7.2168, -16.0413], [-7.18445, -16.8058], [-7.09575, -17.5289], [-6.95384, -18.2107], [-6.76183, -18.8512], [-6.52287, -19.4504], [-6.24009, -20.0083], [-5.9166, -20.5248], [-5.55556, -21], [-5.16007, -21.4339], [-4.73328, -21.8264], [-4.27832, -22.1777], [-3.79831, -22.4876], [-3.29639, -22.7562], [-2.77569, -22.9835], [-2.23934, -23.1694], [-1.69046, -23.314], [-1.13219, -23.4174], [-0.56766, -23.4793], [0, -23.5], [0.56766, -23.4793], [1.13219, -23.4174], [1.69046, -23.314], [2.23934, -23.1694], [2.77569, -22.9835], [3.29639, -22.7562], [3.79831, -22.4876], [4.27832, -22.1777], [4.73328, -21.8264], [5.16007, -21.4339], [5.55556, -21], [5.9166, -20.5248], [6.24009, -20.0083], [6.52287, -19.4504], [6.76183, -18.8512], [6.95384, -18.2107], [7.09575, -17.5289], [7.18445, -16.8058], [7.2168, -16.0413], [7.18967, -15.2355], [7.09992, -14.3884], [6.94444, -13.5], [6.72009, -12.5702], [6.42374, -11.5992], [6.05226, -10.5868], [5.60251, -9.53306], [5.07137, -8.43802], [4.45571, -7.30165], [3.7524, -6.12397], [2.9583, -4.90496], [2.07029, -3.64463], [1.08523, -2.34298], [0, -1]] to a vec2 of numbers in file points_first_demo.scad, line 7
Any ideas?
-Revar
> I get this error:
> Any ideas?
>> -Revar
JW
Joe Weinpert
Sat, Jan 15, 2022 2:20 AM
Yes, that is correct. I looked closer and found the list is actually
wrapped in an extra pair of brackets, so using an index 0 array works fine.
I get this error:
> for the svg path.
> > I get this error:
> > Any ideas?
> >> -Revar
Sat, Jan 15, 2022 2:37 AM
My guess is that sometimes the SVG may contain more than one polygon,
and then there will be several pieces, hence multiple point lists are
needed.
On Fri, Jan 14, 2022 at 9:21 PM Joe Weinpert joe.weinpert@gmail.com wrote:
Yes, that is correct. I looked closer and found the list is actually wrapped in an extra pair of brackets, so using an index 0 array works fine.
I get this error:
Any ideas?
-Revar
needed.
>> > I get this error:
>> > Any ideas?
>> >> -Revar
JW
Joe Weinpert
Sat, Jan 15, 2022 3:15 AM
Ah ... very good point.
needed.
I get this error:
> needed.
> >> > I get this error:
> >> > Any ideas?
> >> >> -Revar
