Snippets with QScintilla for OpenSCAD?
BH
brad hopper
Thu, Apr 16, 2015 4:48 PM
Hey folks,
Now that OpenSCAD has a new underlying editor - QScintilla, I wonder if there might already be support for "snippets", by which I mean shortcut strings which resolve to longer code templates. (If you google for "snippets" and Qscintilla, you'll get a lot of hits for what I think is actually just mini tutorials on how to use QScintilla, which isn't what I mean)
For example, in OpenSCAD, when I type "for", 99% of the time I will continue to type:
for(i=[-1,1]){    translate([i*0,0,0]) (something like cylinder() );}
and of course, if I type "cyl..." I will almost always want to get
cylinder(r=0,h=0); etc
I think a lot of editors do this type of thing - I used to use Sublime Text 2 and still use Notepad++ but just got tired of using two apps instead of one, especially now that OpenSCAD has nice looking syntax hilighting, theming etc.
I'm thinking that QScintilla might already have this feature and it may be a matter of editing/making a configuration file somewhere... true?
Thanks!
Brad
Hey folks, Now that OpenSCAD has a new underlying editor - QScintilla, I wonder if there might already be support for "snippets", by which I mean shortcut strings which resolve to longer code templates. (If you google for "snippets" and Qscintilla, you'll get a lot of hits for what I think is actually just mini tutorials on how to use QScintilla, which isn't what I mean) For example, in OpenSCAD, when I type "for", 99% of the time I will continue to type: for(i=[-1,1]){    translate([i*0,0,0]) (something like cylinder() );} and of course, if I type "cyl..." I will almost always want to get cylinder(r=0,h=0); etc I think a lot of editors do this type of thing - I used to use Sublime Text 2 and still use Notepad++ but just got tired of using two apps instead of one, especially now that OpenSCAD has nice looking syntax hilighting, theming etc. I'm thinking that QScintilla might already have this feature and it may be a matter of editing/making a configuration file somewhere... true? Thanks! Brad
BH
brad hopper
Thu, Apr 16, 2015 5:01 PM
While I'm on the topic of QScintilla, I'm wondering if, again, there's an underlying configuration file which controls the behavior of the auto indentation?
I would love to have auto-indent and I'm sure it's just a matter of style but what's there by default drives me batty!
I like my indentations to look thusly:
module myModule() {    some code here}
It helps me a lot to be able to see which statement the } closes by just looking straight up.
Using the inbuilt autoindent it takes a crazy number of arrows and backspaces and re-tabbing to get to what I want. Much less trouble at the moment to just turn it off.
While I'm on the topic of QScintilla, I'm wondering if, again, there's an underlying configuration file which controls the behavior of the auto indentation? I would love to have auto-indent and I'm sure it's just a matter of style but what's there by default drives me batty! I like my indentations to look thusly: module myModule() {    some code here} It helps me a lot to be able to see which statement the } closes by just looking straight up. Using the inbuilt autoindent it takes a crazy number of arrows and backspaces and re-tabbing to get to what I want. Much less trouble at the moment to just turn it off.
Thu, Apr 16, 2015 5:03 PM
This is an attempt are smth. similar:
https://github.com/openscad/openscad/pull/905
On Apr 16, 2015, at 12:48 PM, brad hopper <braddo_99@yahoo.com> wrote: > Now that OpenSCAD has a new underlying editor - QScintilla, I wonder if there might already be support for "snippets", by which I mean shortcut strings which resolve to longer code templates. (If you google for "snippets" and Qscintilla, you'll get a lot of hits for what I think is actually just mini tutorials on how to use QScintilla, which isn't what I mean) > This is an attempt are smth. similar: https://github.com/openscad/openscad/pull/905 -Marius
Thu, Apr 16, 2015 5:05 PM
There is some configuration in Preferences.
If you try tweaking those, and then describe in more detail what you want, we could take a look at it.
On Apr 16, 2015, at 13:01 PM, brad hopper <braddo_99@yahoo.com> wrote: > While I'm on the topic of QScintilla, I'm wondering if, again, there's an underlying configuration file which controls the behavior of the auto indentation? > There is some configuration in Preferences. If you try tweaking those, and then describe in more detail what you want, we could take a look at it. -Marius
