Hello,
many thanks to all. It is so much like C that I forgot that is only partly like this. But: If there are
no variables you have allways to take a new name to change it or is this only for vectors
coirrect? Only variables with the value 'undef' are to be used on left side?
Thanks again
Manfred
With a named constant you can reassign a new value to the name and the last
value assigned is used for the entire script. You can do that also with a
whole list but you can't change an element in a list, without making a new
one.
On 9 January 2017 at 12:03, Manfred Preussig PreussigM@web.de wrote:
Hello,
like this. But: If there are no variables you have allways to take a new
name to change it or is this only for vectors coirrect? Only variables with
Thanks again
Manfred
Because of scope rules, it is no problem to write code like this:
for (i=[0:10])
k = i*i;
echo(k);
but you can't sum up things easily. So this will not work as expected
k = 1;
for (i=[0:10])
k = k+k*k;
echo(k); // ECHO: 2
to sum up, you either have to use some algebraic a sum formula ( Gauß
https://de.wikipedia.org/wiki/Gau%C3%9Fsche_Summenformel ), which is
always the best from a numeric point of view, or some - admittedly strange -
recursive function.
k=1;
for (i=[0:10])
k = sum(k+i); // k+k*k
echo(k);
function sum(k) =
k<=0?0
: k==1?2
:sum(k-1)+ sum(k-1)*sum(k-1);
View this message in context: http://forum.openscad.org/Error-in-Code-Don-t-know-what-s-wrong-there-tp19952p19970.html
There is no formal definition of variables in OpenSCAD like in C. Or you may
think a variable is defined the first time it appears on the left of an
assignment. 'undef' is a value that you may use in any expression and the
system returns for invalid expressions (like vector[-1]). Therefore, a
variable with an 'undef' value is a defined variable with a well defined
value.
View this message in context: http://forum.openscad.org/Error-in-Code-Don-t-know-what-s-wrong-there-tp19952p19971.html
ManfredP wrote
If there are no variables you have allways to take a new name to change it
or is this only for vectors coirrect? Only variables with the value
I had a more complex answer, but again others have replied before me.
I may post my complex answer tomorrow, after I re-read it, without the red
wine.
In short, conceptually, yes, only previously undefined (ie new) variables on
the left, should be used in a scope level. And yes, also you can't assign to
an element of a vector, a[1]=0 is not valid.
View this message in context: http://forum.openscad.org/Error-in-Code-Don-t-know-what-s-wrong-there-tp19952p19972.html
Hello,
many thanks to all. Now it works. Only the stick to the plate is now allready a problem ... as I
will solve that I can print this part.
greetings
Manfred
Am 9 Jan 2017 um 5:54 hat MichaelAtOz geschrieben:
red wine. In short, conceptually, yes, only previously undefined (ie
new) variables on the left, should be used in a scope level. And yes,
also you can't assign to an element of a vector, a[1]=0 is not valid.
Admin - PM me if you need anything, or if I've done something
stupid...
http://www.ourfairdeal.org/ time is running out! -- View this
message in context:
tp19952p19972.html Sent from the OpenSCAD mailing list archive at
Nabble.com.
