I notice when I do a preview operation, it is some time before the previous
image is erased, and then some more time before the new one is completed
and rendered. What is the system "doing" after you start the render, but
before it erases the screen? I'd think that it would either erase right at
the beginning or the end, but not in the middle.
Jim
Good point, I would rather it at the end so you can see the effect of the
change.
previous image is erased, and then some more time before the new one is
completed and rendered. What is the system "doing" after you start the
render, but before it erases the screen? I'd think that it would either
erase right at the beginning or the end, but not in the middle.
Jim
I take screenshots :)
change.
Jim
Total agreement with nop head.
the change.
one is completed and rendered. What is the system "doing" after
you start the render, but before it erases the screen? I'd think
that it would either erase right at the beginning or the end, but
not in the middle.
Jim
Not sure, but I’ve noticed that if you try to rotate/move the camera while it’s working on it, that seems to make it go blank immediately.
On Feb 7, 2022, 11:56 -0800, Jim Witte jim.witte@gmail.com, wrote:
I notice when I do a preview operation, it is some time before the previous image is erased, and then some more time before the new one is completed and rendered. What is the system "doing" after you start the render, but before it erases the screen? I'd think that it would either erase right at the beginning or the end, but not in the middle.
Jim
