puzzlecutlib rendering problem & STL export error Current top level object is empty.
Sun, May 29, 2016 10:38 AM
For me kisslicer is a good indicator tool to find out where a stl is
degenerate. This is what it indicates with your STL:
http://forum.openscad.org/file/n17460/Puzzle.png
View this message in context: http://forum.openscad.org/puzzlecutlib-rendering-problem-STL-export-error-Current-top-level-object-is-empty-tp17440p17460.html
For me kisslicer is a good indicator tool to find out where a stl is degenerate. This is what it indicates with your STL: <http://forum.openscad.org/file/n17460/Puzzle.png> -- View this message in context: http://forum.openscad.org/puzzlecutlib-rendering-problem-STL-export-error-Current-top-level-object-is-empty-tp17440p17460.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, May 29, 2016 10:42 AM
So, what does a 'blade edge' mean?
View this message in context: http://forum.openscad.org/puzzlecutlib-rendering-problem-STL-export-error-Current-top-level-object-is-empty-tp17440p17461.html
So, what does a 'blade edge' mean? ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/puzzlecutlib-rendering-problem-STL-export-error-Current-top-level-object-is-empty-tp17440p17461.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, May 29, 2016 12:35 PM
"blade edge sharp crease" is what it says and mostly results from numerical
errors. (Almost) degenerated triangles will most probably not show up as
'desired' in the sliced path. A closer look at the triangulation (CTRL+1)
unveals what has happend.
Kisslicer indicates those errors, but silently gets around most of them.
Redness of colors indicate severity of errors.
http://forum.openscad.org/file/n17463/puzzle1.png
View this message in context: http://forum.openscad.org/puzzlecutlib-rendering-problem-STL-export-error-Current-top-level-object-is-empty-tp17440p17463.html
"blade edge sharp crease" is what it says and mostly results from numerical errors. (Almost) degenerated triangles will most probably not show up as 'desired' in the sliced path. A closer look at the triangulation (CTRL+1) unveals what has happend. Kisslicer indicates those errors, but silently gets around most of them. Redness of colors indicate severity of errors. <http://forum.openscad.org/file/n17463/puzzle1.png> -- View this message in context: http://forum.openscad.org/puzzlecutlib-rendering-problem-STL-export-error-Current-top-level-object-is-empty-tp17440p17463.html Sent from the OpenSCAD mailing list archive at Nabble.com.
