Re: [OpenSCAD] STL file generation non-deterministic?
N
nophead
Mon, Jun 10, 2019 10:30 AM
It seems that OpenCSG PNG generation is also non-deterministic. Odd pixels
change at the edges on consecutive runs on the same computer. Perhaps it is
related to the STL problem. I.e. perhaps the tessellation is
non-deterministic and that leads to slightly different jaggies on diagonal
lines when the triangles are drawn.
It seems that OpenCSG PNG generation is also non-deterministic. Odd pixels change at the edges on consecutive runs on the same computer. Perhaps it is related to the STL problem. I.e. perhaps the tessellation is non-deterministic and that leads to slightly different jaggies on diagonal lines when the triangles are drawn. -- Sent from: http://forum.openscad.org/
S
Serge
Mon, Jun 10, 2019 5:28 PM
AI is taking over OpenSCAD? lol. I bet it's just a rounding error.
Sometimes in INKscape I set exact number say to 65 mm and later after
saving file it's 64.99998 or something like that. Maybe OpenSCAD
Preview cam has same type of error.
AI is taking over OpenSCAD? lol. I bet it's just a rounding error. Sometimes in INKscape I set exact number say to 65 mm and later after saving file it's 64.99998 or something like that. Maybe OpenSCAD Preview cam has same type of error. On 6/10/19, nophead <nop.head@gmail.com> wrote: > It seems that OpenCSG PNG generation is also non-deterministic. Odd pixels > change at the edges on consecutive runs on the same computer. Perhaps it is > related to the STL problem. I.e. perhaps the tessellation is > non-deterministic and that leads to slightly different jaggies on diagonal > lines when the triangles are drawn. > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Mon, Jun 10, 2019 5:44 PM
This is being run from the command line by a Python script so all the
numbers should be exactly the same each run, including the camera setting.
pixels
is
diagonal
This is being run from the command line by a Python script so all the numbers should be exactly the same each run, including the camera setting. On Mon, 10 Jun 2019 at 18:29, Serge <moneyforidea@gmail.com> wrote: > AI is taking over OpenSCAD? lol. I bet it's just a rounding error. > Sometimes in INKscape I set exact number say to 65 mm and later after > saving file it's 64.99998 or something like that. Maybe OpenSCAD > Preview cam has same type of error. > > On 6/10/19, nophead <nop.head@gmail.com> wrote: > > It seems that OpenCSG PNG generation is also non-deterministic. Odd > pixels > > change at the edges on consecutive runs on the same computer. Perhaps it > is > > related to the STL problem. I.e. perhaps the tessellation is > > non-deterministic and that leads to slightly different jaggies on > diagonal > > lines when the triangles are drawn. > > > > > > > > -- > > Sent from: http://forum.openscad.org/ > > > > _______________________________________________ > > OpenSCAD mailing list > > Discuss@lists.openscad.org > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
