Nothing wrong with the scad/stl (but warning wrt assign DEPRECATED: The
assign() module will be removed in future releases. Use a regular
assignment instead. in file , line 16
It will print fine, provided you've got the correct settings in cura for
your printer and filament. You need to run some tests to set it up properly
