I don't think zero thickness faces will ever survive being put into an STL
file. I don't think there is enough information to recover the topology
when the triangles overlap. Even if it is 2 manifold mathematically (which
I am not sure of) it isn't a valid 3D solid, so even if OpenScad can handle
it internally, it won't be representable in all 3D file formats or work
properly in programs that operate on solids.
On 7 November 2015 at 09:12, Neon22 mschafer@wireframe.biz wrote:
Looking at @wolf's code the vertex location calc is done 4(I think) times
for
each vertex.
I.e. 4 faces join at a vertex but that vertex is calculated 4 times instead
of once.
Perhaps a way to do it where the vertices are shared, is to calculate all
the points once, in a list, and then build the faces list using those
vertices.
Then there will be no floating point error as the vertices will really be
shared. And therefore it will be a solid.
Sorry don't have time to do it right now :(
View this message in context:
http://forum.openscad.org/Polyhedron-and-cube-Not-a-Valid-2-Manifold-tp14283p14296.html
First, to kintel's comment: The financial industry sits with the same
problem: floating point accuracy is not good enough to add up trillions of
dollar without essentially unpredictable consequences for the last cents. If
I can find the methods, used there to make sure rounding errors do not
happen, again, I will let you know.
My approach to rounding errors would be to define, internally, a unit length
roughly equivalent to the diameter of an atom, and thus all numbers used to
be represented by integers. Externally, in user space, this can readily be
converted into the customary millimeter, or, if you want, inches and feet.
Thus all vertices are treated as vectors made up of integers, the smallest
value representable being the diameter of a single atom. This way internal
accuracy can be assured, down to the smallest possible unit to represent in
a real world solid. Where floating point numbers are unavoidable (sines, pi,
logarithms, roots, etc), infinite accuracy algorithms are available to
calculate those numbers to the accuracy needed. Guessing a user's intention
by merging close, but separate vertices into a single one violates, in my
view, the reasons behind creating a functional language in the first place:
separation.
Should an integer representation for internal unit length place unacceptable
limits on the upper length limits, that can always be extended by replacing
integers (=list of bits in a register) with lists of memory entries
(=strings of digits). But that would seen unlikely to me, since a 64 bit
signed integer can represent double the distance Earth - Moon down to atomic
accuracy - more than enough I should think.
To Neon22's comment: Yes, the vertices are calculated multiple times, once
for each quadrangle defined by a pair of [u,v] values. If I may ignore the
exceptional situation at the poles, where half the triangles degenerate into
lines and therefore are excluded from being rendered, each pair of
red/yellow triangles has its vertices calculated separately. But that also
means that one third of the edges separating faces are based upon the same
vertices, and the different vertex counts by OpenSCAD and MeshLab remain
unexplained. On average, this means that each vertex is calculated slightly
more than twice (pole exception!) for each vertex rendered.
In terms of execution speed, multiple calculation of vertices makes no
contribution to overall rendering time, as time is consumed measurably only
by the polyhedron() instructions. But, of course, there are other reasons to
prefer reading data from a list rather than recreating them afresh every
time they are needed.
You could create such a list using external software. That is a crutch not
acceptable to me.
I am looking for a way to do that inside OpenSCAD, inside user space. As we
all know, the manual currently says exporting a value from a module onto,
e.g. a list, is not possible. Whether that is true in light of what has
recently been said in this forum about tail recursion remains to be tested.
To nophead: Zero thickness faces are a standard feature of OpenSCAD, as all
rendering is done using CGAL's implementation of Nef polyhedra. To quote
http://doc.cgal.org/latest/Nef_3/index.html : "In our implementation of
Nef polyhedra in 3D, we offer a B-rep data structure that is closed under
Boolean operations and with all their generality." Unquote. May I suggest
that you read the documentation? Since polyhedron() became available, open
data structures (an alternative name for "Open Data Structure" is
"Non-Manifold Model") have also become available in OpenSCAD. And many users
cannot handle them, as this forum shows again and again. But that only means
that the manual is inadequate, that many users (me included) do not
understand the entry for polyhedron().
In spite of what many participants in this forum claim, OpenSCAD is not
Constructive Solid Geometry (CSG). It has the properties of CSG, in that it
can handle union(), difference() and intersection(), i.e. the boolean
operations mentioned above. It also does Boundary Representation (B-rep),
since it uses CGAL's Nef polyhedra. It even does Functional Representation
(F-rep), as my little piece of software shows.
It does it all. OpenSCAD is not limited to the one or the other. OpenSCAD's
limitations arise principally from the mindset of some of its most
loquacious users, which restricts its use to 3D-printing and laser cutting.
Sheet-metal folding, for example, is served well using non-manifold models
https://en.wikipedia.org/wiki/Boundary_representation . And building a
cube with rounded edges is computationally rather expensive in OpenSCAD, as
it is done either the using expensive functions (hull(), minkowski()) or, if
done using a union of cylinders, spheres and cubes, the computation of many
vertices and faces that are later discarded.
Wolf
View this message in context: http://forum.openscad.org/Polyhedron-and-cube-Not-a-Valid-2-Manifold-tp14283p14299.html
It doesn't matter whether OpenScan can represent zero thickness walls or
work in infinite precision, STL can't, so you can't export it in STL
without problems. It is just a jumble of triangles which downstream
programs expect to share each edge with one other. There is no information
about which triangles meet other than numerically comparing the vertices in
floating point format. So if the wall has no thickness triangles can easily
be sharing too many edges and may intersect. Then it is down to how clever
the program reading it is at untangling the mess to make a mesh.
It has been said many times OpenScad could do a better job writing STLs by
using a topologically aware truncation scheme to make sure vertices that
are distinct are still distinct after truncation to floats, which means
fudging them a little in such a way that the topology is preserved. I think
that would be far from trivial.
You can easily build lists of vertices in OpenScad using recursive
functions, or list comprehensions. You don't need external programs.
Any real object you can make, sheet metal or otherwise, will be manifold.
Openscad doesn't need to be able to handle non manifold geometry.
If
length
pi,
separation.
unacceptable
atomic
into
to
acceptable to me.
users
means
if
Wolf
If you look through the archive this was discussed a long time back,
using something like 32:32 fixed format because it can be handled very
fast by a modern processor, and would potentially even allow an ARM based
tablet device to run OpenSCAD usefully.
Read the existing CGAL code and documentation for mathematical
representations of points.
If you write the CGAL numeric classes to support fixed point then the
rest shoudldn't matter for any realistically complex object. Export is a
different problem. STL is basically broken by design so you have to fudge
your exports.
Yes - some of the other equivalents did (IMhO) a rather nicer job of
things like rounding and flanges by using implicit functions and different
algorithms to generate any mesh output.
ImplicitCAD unfortunately seems to have mostly died, although it got a
few fixes over the last couple of months
https://github.com/colah/ImplicitCAD
Alan
Wolf, I replied to your message in the other thread. This is not a valid
OpenSCAD program. It doesn't construct a 3D solid, just a cloud of
non-manifold objects. It produces CGAL error messages in 2014.03, but not
in 2015.03, and I consider it a bug that we don't report an error in
2015.03.
You said: "I have placed a piece of code that demonstrates that nophead and
Neon22's comments are at variance with how polyhedron() actually behaves."
Nophead and Neon22 are correct. The underlying problem is that polyhedron()
fails to report an error for invalid arguments, and returns something that
is not a valid solid. In general, OpenSCAD is very sloppy at detecting and
reporting errors.
On 6 November 2015 at 15:36, wolf wv99999@gmail.com wrote:
In another thread
http://forum.openscad.org/3d-hull-with-2d-primitives-needed-tp5845p14276.html
I have placed a piece of code that demonstrates that nophead and Neon22's
In that code, change any of the StartVal_ or EndVal_ parameters and see
how
an ellipsoid changes into a vase. If you count the vertices or faces, there
are exactly as many as there should be, and thus the shape is watertight.
But it does not have a volume, irrespective of what OpenSCAD reports, as
all
faces are of zero thickness.
But if you create an stl and export it into MeshLab, the number of vertices
triples, and the ellipsoid / vase would no longer be watertight. Whose
messages are then to be trusted?
To me, it means that someone has buggered the C++ code, either in creating
the stl mesh, or in reading it. Does anybody have an idea how to find the
bug, preferably without me first learning C++?
Wolf
http://forum.openscad.org/Polyhedron-and-cube-Not-a-Valid-2-Manifold-tp14283p14293.html
This is my first day actually modeling my custom shape. It is more complex
than the following example Test, but F5 looked fine and F6 would get
"WARNING: Object may not be a valid 2-manifold and may need repair!"
So I found this https://github.com/openscad/openscad/issues/1023 as well as
this forum's topic from sukrit_gupta.
I then tested the following and got the same error.
//Begin Test
l = 1;
w = 2;
h = 3;
points = [
[0,0,0],
[l,0,0],
[l,w,0],
[0,w,0],
[0,0,h],
[l,0,h],
[l,w,h],
[0,w,h],
faces = [
[0,1,2,3],
[0,1,5,4],
[1,2,6,5],
[2,3,7,6],
[3,0,4,7],
[4,5,6,7]
polyhedron(points, faces);
cube([3,2,1]);
//End Test
The polyhedron by itself is fine with F5 and F6; and the cube by itself is
fine with F5 and F6. Together as above, F5 is fine but F6 gets "WARNING:
Object may not be a valid 2-manifold and may need repair!" and then all that
can be seen is the cube and face [4,5,6,7]. I asterisked one then the other
and also commented each out before preparing this post. Then F6 claimed to
be correct, but only the cube and the face [4,5,6,7] is visible. Then I
went back to my complex code and F6 was also not complaining, but visually
it looks wrong.
Since this is a polyhedron and a cube, I don't see how to apply the github
solution.
My concern with the complex model was just touching faces of 2 different
objects. If I add translate before the cube:
translate([1,0,0])
cube([3,2,1]);
F5 looks fine and F6 has no errors, but visually F6 shows the cube and two
faces [0,1,2,3] and [4,5,6,7].
This page actually got me modeling my custom shape
http://www.tridimake.com/2014/09/how-to-use-openscad-tricks-and-tips-to.html
and there is a warning about "The danger of CSG subtraction: dreaded
undefined surfaces!" so I was concerned about faces just touching, but I'm
not doing any subtraction and the test overlaps two objects.
What am I doing wrong?
Also is there an md5 checksum I can do on my download to at least check that
the download was fine?
Thanks.
OSX 10.10.5
OpenSCAD 2015.03-3
View this message in context: http://forum.openscad.org/Polyhedron-and-cube-Not-a-Valid-2-Manifold-tp14283p17958.html
Your polygon has most faces flipped (the vertices have wrong winding order).
See https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Primitive_Solids#Mis-ordered_faces
and https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#Why_is_my_model_showing_up_with_F5_but_not_F6.3F
Wow! I was totally inconsistent with that. Thanks. I thought I was doing
all outward normals.
I got lax when I read "prefers". Maybe that should be "requires", (higher
up on the polyhedron documentation) even though I still blew it?
"OpenSCAD /requires/ clockwise when looking at each face from outside
inwards."
I jumped in before reading the debugging instructions.
This test case is fixed and so is my more complex model. Thanks again for
the quick reply to my newbie mistake.
View this message in context: http://forum.openscad.org/Polyhedron-and-cube-Not-a-Valid-2-Manifold-tp14283p17960.html
OpenSCAD will work fine with either CW or CCW, just don't* /mix/* them in the
same polyhedron
View this message in context: http://forum.openscad.org/Polyhedron-and-cube-Not-a-Valid-2-Manifold-tp14283p17988.html
