In another thread (Re: Fillet) it became apparent that scripts that
successfully ran on one system, did not run properly on another. I think
it would be useful if the values entered in preferences, and elsewhere,
could be produced as a separate text file, so that when these
differences occur, comparisons between these settings could be readily
made. It appears that the version number is not enough (for example
cgal/manifold, can produce different results.)
If we create those text files, why not allow them to also be imported,
so Raymond can send me his settings, and I can try them?
think it would be useful if the values entered in preferences, and
elsewhere, could be produced as a separate text file, so that when
these differences occur, comparisons between these settings could be
readily made. It appears that the version number is not enough (for
example cgal/manifold, can produce different results.)
