editor anomaly
Mon, Mar 2, 2015 4:13 PM
When I run the 2/25 release of OpenSCAD, I see line numbers in the
editor (good!).  Better would be if those numbers could be of a
different color (gray vs black?).  Even better would be if the line
number for the line after 99 showed up as 100 rather than as 00
When I run the 2/25 release of OpenSCAD, I see line numbers in the editor (good!). Better would be if those numbers could be of a different color (gray vs black?). Even better would be if the line number for the line after 99 showed up as 100 rather than as 00 Jon
Mon, Mar 2, 2015 6:12 PM
Thanks for the report. Both fixed in master.
On Mar 2, 2015, at 11:13 AM, jon <jon@jonbondy.com> wrote: > When I run the 2/25 release of OpenSCAD, I see line numbers in the editor (good!). Better would be if those numbers could be of a different color (gray vs black?). Even better would be if the line number for the line after 99 showed up as 100 rather than as 00 > Thanks for the report. Both fixed in master. -Marius
Mon, Mar 2, 2015 7:57 PM
Interesting, doesn't happen on my system, I get 100.
View this message in context: http://forum.openscad.org/editor-anomaly-tp11822p11831.html
jon_bondy wrote > Even better would be if the line > number for the line after 99 showed up as 100 rather than as 00 Interesting, doesn't happen on my system, I get 100. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/editor-anomaly-tp11822p11831.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Mar 2, 2015 8:18 PM
This issue was dependent on font and font size.
On Mar 2, 2015, at 14:57 PM, MichaelAtOz <oz.at.michael@gmail.com> wrote: > Interesting, doesn't happen on my system, I get 100. > This issue was dependent on font and font size. -Marius
