Fri, Feb 9, 2024 11:59 PM
Greetings all;
I can't make this work:
in module making the sub call
translate([.25,0,-15])color("pink")yunion_screws(0);
in module yunion_screws:
module yunion_screws(n)
ysep=16; //xsep= spacing on sides
xsep=14.5; //ysep=spacing between sides
slen=20; //length of screws
if(n==0)sdia=1.85; // dia of screw for base part
if(n==1)sdia=2.4; // dia of same screw for linear carrier s/b just
barely a slip fit
Its desired to make the head hole big enough to strip the trash out of
the hole, while the part it screws to is self threading, its a 2mm
special screw for plastic. Obviusly I'm doing sth wrong but what
Thank you for any insight.
Cheers, Gene Heskett, CET.
Greetings all;
barely a slip fit
- Louis D. Brandeis
JG
Jonathan Gilbert
Sat, Feb 10, 2024 12:02 AM
I think your paste got truncated; your yunion_screws() module looks
incomplete.
In any case, with the bits you HAVE pasted, it may be that you're looking
for, assuming 'n' will only ever be 0 or 1:
sdia = (n==0) ? 1.85 : 2.4;
On Fri, Feb 9, 2024 at 3:59 PM gene heskett via Discuss <
Greetings all;
barely a slip fit
incomplete.
> Greetings all;
> barely a slip fit
> - Louis D. Brandeis
- Jon Gilbert
jong@jong.org / jgilbertsjc@gmail.com
Sat, Feb 10, 2024 12:56 AM
incomplete.
looking for, assuming 'n' will only ever be 0 or 1:
So my dirct approach is bass ackwards, and this works as advertised.
ing
Thank you Jonathan Gilbert, the printer will be warm up shortly.
<discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
Greetings all;
just
barely a slip fit
respectable.
- Louis D. Brandeis
> incomplete.
ing
> <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote:
> Greetings all;
> just
> barely a slip fit
> respectable.
> - Louis D. Brandeis
> <mailto:discuss-leave@lists.openscad.org>
> - Jon Gilbert
> jong@jong.org <mailto:jong@jong.org> / jgilbertsjc@gmail.com
> <mailto:jgilbertsjc@gmail.com>
- Louis D. Brandeis
Mon, Feb 12, 2024 9:40 AM
Just giving a working snippet doesn't help in the long run if you
don't explain why it doesn't work.
The scope of the variable "sdia" ...
if(n==0) {
sdia=1.85;
... is exaclty the body of the "if" statement. A new sdia variable is
created. If there might be an sdia variable available outside of the
if, then that variable is not affected in any way by the assingment,
and that variable is no longer available inside the if statement.
Your shortening of the body of the if, leaving out the braces and not
putting anything else in the body of the if... makes that creation
and destruction of the new sdia variable a no-op.
Greetings all;
just
barely a slip fit
-- "There are four boxes to be used in defense of liberty:
respectable.
- Louis D. Brandeis
if(n==0) {
sdia=1.85;
> > Greetings all;
> > just
> > barely a slip fit
> > respectable.
> > - Louis D. Brandeis
> > - Jon Gilbert
> - Louis D. Brandeis
Mon, Feb 12, 2024 1:24 PM
if(n==0) {
sdia=1.85;
It was not previously known in the program
Its part of an almost 1300 LOC file, covering most of the mods being
made to a bigger printer I'm building out of an $1100 tronxy, that came
with a busted marlin, and never succesfully printed anything. tronxy's
support is a vast wasteland, so I'm using the frame as raw materiel to
build a real printer. Fur instance, its a corexy, but two weeks ago I
found all the flying weight parts were 90% solid steel with the X
transport bar alone weighing about a pound. obvioudly a candidate to be
replaced with a CF tube weighing about an ounce and two linear bearings
weighing maybe 4 ounces each, one above the cf tube and another below to
get real torsional rigidity. Moving an all printed hotend carriage
carrying an orbiter v2, a few grams of prox switch for bed leveling and
a triangle labs e3v6 clone with a 70 watt coaxial heater and another
gram of a kusba acceleration sensor to calibrate the input shaper.
And pestering triangle labs and qidi tech for a carbide nozzle so I can
use cf based petg. Even better than industrial diamond as the diamond
starts going away from ablation at around 250C. Carbide just grins and
keeps on cutting titanium at 700C. Triangle Labs isn't answering the
mail, and qidi tech says they are working on it. Later this spring has
been mentioned.
Thank you. Take care Roger.
> if(n==0) {
> sdia=1.85;
1. It was not previously known in the program
2. Its part of an almost 1300 LOC file, covering most of the mods being
been mentioned.
Understood.
> Roger.
- Louis D. Brandeis
