I could not see any chamfer or fillet here.
Anything missing?
On Tue, 14 Jan 2025 at 18:04, Raymond West via Discuss <
This gives a flat fillet (which I've called a bevel - depends if you think
it is internal or external, draughtsman or carpenter)
module tube(d){
linear_extrude(100)
circle(d=d);
circle (d=d-0.0001);
hull(){
intersection(){
tube(30); //upright tube
translate([-0,0,50])
rotate([0,90,0])
tube(20+bevel);
intersection(){
tube(30+bevel); // side tube
rotate([0,90,0])
tube(20);
$fn=100;
cylinder(d=30,h=100);
rotate([0,90,0])
cylinder(d=20,h=50);
bevel=6; // greater than 2.
On 1/14/2025 6:26 AM, Jon Bondy via Discuss wrote:
Perhaps I am mistaken, but I thought that fillets were possible in
many cases using the BOSL2 library.
There are several techniques for fillets and chamfers/roundoffs. They
are just rarely easy. BOSL2 does offer a lot of options, which it does
the hard way (by constructing polyhedra) and then hides the difficulty.
Hiding the difficulty. That's what I want!
does the hard way (by constructing polyhedra) and then hides the
difficulty.
On Tue, Jan 14, 2025 at 6:45 AM Sanjeev Prabhakar via Discuss <
Anything missing?
think it is internal or external, draughtsman or carpenter)
That inset is too big for my copy of OpenSCAD (version 2024.03.01,
macOS). Changing it to circle (d=d-0.01); works.
