New unofficial tool release: OpenSCAD Make
paulirotta
Thu, Feb 28, 2019 3:37 PM
http://forum.openscad.org/file/t2469/openscad-make.png
I've created a simple build system for making multiple OpenSCAD models in
parallel. I hope this is helpful to some of you also.
Pre-built binaries for Windows and Linux are included. OSX should work also.
Very limited testing so far but no know issues.
It made batch builds of  http://pelablocks.org http://pelablocks.org
drop from 6 hours to 1 hour vs a previous shell script I was using. Enjoy!
https://github.com/LEGO-compatible-gadgets/openscad-make
<http://forum.openscad.org/file/t2469/openscad-make.png> I've created a simple build system for making multiple OpenSCAD models in parallel. I hope this is helpful to some of you also. Pre-built binaries for Windows and Linux are included. OSX should work also. Very limited testing so far but no know issues. It made batch builds of http://pelablocks.org <http://pelablocks.org> drop from 6 hours to 1 hour vs a previous shell script I was using. Enjoy! https://github.com/LEGO-compatible-gadgets/openscad-make <https://github.com/LEGO-compatible-gadgets/openscad-make> -- Sent from: http://forum.openscad.org/
TO
Trevor Orr
Thu, Feb 28, 2019 4:00 PM
Cool, I will definitely give this a try.  I have some scripts that run for
several hours generating hundreds of stl files, would be nice to drop that
time to an hour or so.
also.
Cool, I will definitely give this a try. I have some scripts that run for several hours generating hundreds of stl files, would be nice to drop that time to an hour or so. On Thu, Feb 28, 2019 at 7:43 AM paulirotta <paulirotta@gmail.com> wrote: > <http://forum.openscad.org/file/t2469/openscad-make.png> > > I've created a simple build system for making multiple OpenSCAD models in > parallel. I hope this is helpful to some of you also. > > Pre-built binaries for Windows and Linux are included. OSX should work > also. > Very limited testing so far but no know issues. > > It made batch builds of http://pelablocks.org <http://pelablocks.org> > drop from 6 hours to 1 hour vs a previous shell script I was using. Enjoy! > > https://github.com/LEGO-compatible-gadgets/openscad-make > <https://github.com/LEGO-compatible-gadgets/openscad-make> > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
paulirotta
Fri, Mar 1, 2019 5:50 AM
There was some lively discussion on Reddit including alternative ways to
parallelize OpenSCAD builds in shell scripts.
https://www.reddit.com/r/rust/comments/avskhl/6x_speedup_in_openscad_batch_builds_by_using/
There was some lively discussion on Reddit including alternative ways to parallelize OpenSCAD builds in shell scripts. https://www.reddit.com/r/rust/comments/avskhl/6x_speedup_in_openscad_batch_builds_by_using/ -- Sent from: http://forum.openscad.org/
G
Gadgetmind
Fri, Mar 1, 2019 1:46 PM
I just write make files and use Gnu make, often with -j whatever.
On 01/03/2019 05:50, paulirotta wrote: > There was some lively discussion on Reddit including alternative ways to > parallelize OpenSCAD builds in shell scripts. > I just write make files and use Gnu make, often with -j whatever.
